[Ovmsdev] What causes factory reset?
Thu Jun 21 07:56:04 HKT 2018
I think the AutoInit: factory reset detected, starting public AP net 'OVMS' with password ‘OVMSinit’ message is perhaps misleading. It isn’t specifically detecting a factory reset. More that the auto/wifi.mode is “ap” (which is the default if that parameter has not been defined), and that auto/wifi.ssid.ap is undefined, and that wifi.ap/OVMS is empty, and that there is no module password defined).
I did have one report of a user who could not save his config settings. Supposedly he configured the module, unplugged it, moved it to the car, plugged it in, and it was back to factory defaults. I had him do a ‘module factory reset’ to make sure the config partition was correctly formatted. That solved his problem.
But, if it was a config mounting problem we would see that reported in the logs around the point "ovms_main: Mounting CONFIG…”. Yours looks clean.
> On 21 Jun 2018, at 4:45 AM, Stephen Casner <casner at acm.org> wrote:
> Michael,
> Thanks for reviewing the log. Did you notice the part in the second
> session (second time doing the wizard) where there were multiple
> instances of this message:
> W (38852769) webserver: HandleLogin: auth failure for username 'admin'
> This was while I was successfully logged into the webserver and in one
> of the wizard steps where the wizard is repeatedly querying for
> progress. I was able to go to the status page after that without
> having to authenticate again. This seems strange.
> Oh, I have an idea: I plugged in my v3.0 module so I could get the ssh
> key from its config, and it may have brought up AP with the same
> SSID. I don't know what happens to the client if there are two APs
> competing in that way.
> -- Steve
> On Wed, 20 Jun 2018, Michael Balzer wrote:
>> It's always the missing log... your logs look perfectly normal, no hint of anything going wrong on the first setup.
>> Option 2 can be excluded if you had the SD inserted all the time, as the button status is only checked when no SD is inserted.
>> Am 20.06.2018 um 21:37 schrieb Stephen Casner:
>>> Mark,
>>> Thanks for the prompt reply.
>>>> 1. SDCARD factoryreset.txt
>>>> 2. Hold the program button down for several seconds
>>>> 3. Command-line
>>> I certainly didn't intentionally do 1 or 3. I do have the module
>>> installed in the 3D-printed case for the v3.0 module that I have
>>> modified with a plastic button extension that allows me to push the
>>> reset button with the module enclosed in the case. (I mentioned this
>>> a while back; the extension is the plastic part that performed the
>>> same role in a defunct GFCI plug on a hair dryer.) It is conceivable
>>> that this extension pushed on the program button instead of the reset
>>> button, but that is not likely because of the physical geometry and
>>> the button is still working properly as a reset.
>>>> Maybe not a factory reset but a corrupt config partition? Can you
>>>> try to change config. Then reboot. Then check config is still there?
>>> We don't have any "shutdown" operation to stop the module cleanly, so
>>> after the configuration I just unplugged it from the USB cable thereby
>>> removing power. Is there some likelihood that /store would not have
>>> been stable?
>>> As I mentioned, when I brought the module back to my desk after it did
>>> not come up in the car, I saw this:
>>> W (550) esp32wifi: AutoInit: factory reset detected, starting public AP net 'OVMS' with password 'OVMSinit'
>>> A full log via USB is attached in case there might be anything
>>> interesting in it. It shows the session where I did the wizard setup
>>> initially, then the session where I brought it back and found it back
>>> to factory reset, then a third session where I disconnected from power
>>> and plugged back in without loss of the config.
>>> -- Steve
