[Ovmsdev] What causes factory reset?
Stephen Casner
casner at acm.org
Thu Jun 21 04:45:50 HKT 2018
Michael,
Thanks for reviewing the log. Did you notice the part in the second
session (second time doing the wizard) where there were multiple
instances of this message:
W (38852769) webserver: HandleLogin: auth failure for username 'admin'
This was while I was successfully logged into the webserver and in one
of the wizard steps where the wizard is repeatedly querying for
progress. I was able to go to the status page after that without
having to authenticate again. This seems strange.
Oh, I have an idea: I plugged in my v3.0 module so I could get the ssh
key from its config, and it may have brought up AP with the same
SSID. I don't know what happens to the client if there are two APs
competing in that way.
On Wed, 20 Jun 2018, Michael Balzer wrote:
> It's always the missing log... your logs look perfectly normal, no hint of anything going wrong on the first setup.
> Option 2 can be excluded if you had the SD inserted all the time, as the button status is only checked when no SD is inserted.
> Am 20.06.2018 um 21:37 schrieb Stephen Casner:
> > Mark,
> > Thanks for the prompt reply.
> >> 1. SDCARD factoryreset.txt
> >> 2. Hold the program button down for several seconds
> >> 3. Command-line
> > I certainly didn't intentionally do 1 or 3. I do have the module
> > installed in the 3D-printed case for the v3.0 module that I have
> > modified with a plastic button extension that allows me to push the
> > reset button with the module enclosed in the case. (I mentioned this
> > a while back; the extension is the plastic part that performed the
> > same role in a defunct GFCI plug on a hair dryer.) It is conceivable
> > that this extension pushed on the program button instead of the reset
> > button, but that is not likely because of the physical geometry and
> > the button is still working properly as a reset.
> >> Maybe not a factory reset but a corrupt config partition? Can you
> >> try to change config. Then reboot. Then check config is still there?
> > We don't have any "shutdown" operation to stop the module cleanly, so
> > after the configuration I just unplugged it from the USB cable thereby
> > removing power. Is there some likelihood that /store would not have
> > been stable?
> > As I mentioned, when I brought the module back to my desk after it did
> > not come up in the car, I saw this:
> > W (550) esp32wifi: AutoInit: factory reset detected, starting public AP net 'OVMS' with password 'OVMSinit'
> > A full log via USB is attached in case there might be anything
> > interesting in it. It shows the session where I did the wizard setup
> > initially, then the session where I brought it back and found it back
> > to factory reset, then a third session where I disconnected from power
> > and plugged back in without loss of the config.
> > -- Steve
> > OvmsDev mailing list
