[Ovmsdev] What causes factory reset?
Wed Jun 20 16:15:44 HKT 2018
SDCARD factoryreset.txt
Hold the program button down for several seconds
Command-line
Maybe not a factory reset but a corrupt config partition? Can you try to change config. Then reboot. Then check config is still there?
> On 20 Jun 2018, at 3:56 PM, Stephen Casner <casner at acm.org> wrote:
> This evening I connected my new OVMS v3.1 to my laptop and went
> through the setup wizard.  That seemed to go smoothly.  I copied over
> my ssh key and things seemed to be working fine.  I installed an SD
> card so I could do logging if needed, and then unplugged the module to
> install it in the car.  But it didn't come up!
> After I brought it back to the desk and connected to the laptop again,
> I see a message on the console that it has factory reset itself.
> What are the ways to trigger a factory reset?  I must have
> unintentionally hit one.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180620/07a9f7da/attachment.htm>
