[Ovmsdev] Developer Manual?
Mon Jun 4 04:15:27 HKT 2018
Fran,
the master branch is correct.
You normally can use the defaults for all sdkconfig variables we haven't added to the template yet.
I've attached my current sdkconfig. It only excludes bluetooth because that currently needs too much memory.
Am 03.06.2018 um 19:42 schrieb Fran Terry:
> Hi Mark,
> Also having the same issues here, if you follow the instructions,the 2.1 branch doesn't contain components/heap, have switched to master branch,
> however support/sdkconfig.default.hw31 seems to be missing a lot of configuration, get asked lots of questions, such as:
> 'make' warns on undefined variables (MAKE_WARN_UNDEFINED_VARIABLES) [Y/n/?] (NEW)
> * Bootloader config
> Bootloader log verbosity
>   1. No output (LOG_BOOTLOADER_LEVEL_NONE)
>   2. Error (LOG_BOOTLOADER_LEVEL_ERROR)
> > 3. Warning (LOG_BOOTLOADER_LEVEL_WARN)
>   4. Info (LOG_BOOTLOADER_LEVEL_INFO)
>   5. Debug (LOG_BOOTLOADER_LEVEL_DEBUG)
>   6. Verbose (LOG_BOOTLOADER_LEVEL_VERBOSE)
> choice[1-6?]: 3
> SPI Flash WP Pin when customising pins via efuse (read help) (BOOTLOADER_SPI_WP_PIN) [7] (NEW)
> VDDSDIO LDO voltage
>   1. 1.8V (BOOTLOADER_VDDSDIO_BOOST_1_8V) (NEW)
> > 2. 1.9V (BOOTLOADER_VDDSDIO_BOOST_1_9V) (NEW)
> choice[1-2?]:
> I've tried to answer as many as I believe are to be correct, however I guess the question is, is the master branch correct for esp-idf and does anyone have a
> sdkconfig that has all the correct answers for this version?
> Thanks
> Fran
> On 23 April 2018 at 01:33, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>     Michael,
>     Do you still have the old sdkconfig around? If so, please do a ‘diff -u support/sdkconfig.default.hw31 sdkconfig’ so we can see what is different.
>     Regards, Mark
>     > On 22 Apr 2018, at 4:44 PM, Michael Stegen <michael at stegen.com <mailto:michael at stegen.com>> wrote:
>     > Mark,
>     > Copying support/sdkconfig.default.hw31 to sdkconfig fixed the issue, thanks!
>     > -Mike
>     > Op 21-4-2018 om 16:46 schreef Mark Webb-Johnson:
>     >> Can you try copy support/sdkconfig.default.hw31 to sdkconfig to give a standard set of defaults (those used for production). You will then need to
>     adjust the UART path appropriately.
>     >> Also, please ‘git pull’ on each of the projects, to make sure you have the latest sources.
>     >> Regards, Mark.
>     >>> On 21 Apr 2018, at 10:30 PM, Michael Stegen <michael at stegen.com <mailto:michael at stegen.com>> wrote:
>     >>> Steve,
>     >>> Thanks for your suggestion.
>     >>> I tried it ( git submodule update --init) and it did install mongoose in the correct folder.
>     >>> However, as you already noticed, this was not the solution to the problem.
>     >>> Exact same error also happens on a Ubuntu 16.04 installation i did.
>     >>> I'm clearly missing something... but what?
>     >>> -Mike
>     >>> Op 21-4-2018 om 8:43 schreef Stephen Casner:
>     >>>> Mike,
>     >>>> Separately cloning mongoose is not the usual procedure.  Normally it
>     >>>> is just "git submodule update" after cloning OVMS.  That is not an
>     >>>> explanation for the compilation error you encountered, though.
>     >>>> Something else is missing.
>     >>>>                                                         -- Steve
>     >>>> On Fri, 20 Apr 2018, Michael Stegen wrote:
>     >>>>> Hi OVMS v3 devs,
>     >>>>> In preparation of receiveing the module, i'm trying to compile what's
>     >>>>> currently on github.
>     >>>>> But while doing so, i'm running into problems
>     >>>>> I did the following:
>     >>>>> Install the toolchain (windows)
>     >>>>> cd ~/esp
>     >>>>> git clone --recursive https://github.com/openvehicles/esp-idf.git <https://github.com/openvehicles/esp-idf.git>
>     >>>>> cd ..
>     >>>>> git clone https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3.git>
>     >>>>> then in the  /components/mongoose/ folder did:
>     >>>>> git clone https://github.com/openvehicles/mongoose.git <https://github.com/openvehicles/mongoose.git>
>     >>>>> It now does compile up to the following error message:
>     >>>>> In file included from
>     >>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/simcom.h:34:0,
>     >>>>>                  from
>     >>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/ovms_peripherals.h:67,
>     >>>>>                  from
>     >>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/esp32can/src/esp32can.cpp:42:
>     >>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:63:5:
>     >>>>> error: 'ppp_pcb' does not name a type
>     >>>>>      ppp_pcb*     m_ppp;
>     >>>>> C:/msys32/home/Mike/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/simcom/src/gsmpppos.h:64:18:
>     >>>>> error: field 'm_ppp_netif' has incomplete type 'netif'
>     >>>>>      struct netif m_ppp_netif;
>     >>>>> Any idea what i'm missing?
>     >>>>> -Mike
>     >>>> _______________________________________________
>     >>>> OvmsDev mailing list
>     >>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
>     >>>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev <http://lists.openvehicles.com/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180603/882dcb5c/attachment.htm>
# Automatically generated file; DO NOT EDIT.
# Espressif IoT Development Framework Configuration
# SDK tool configuration
CONFIG_TOOLPREFIX="xtensa-esp32-elf-"
CONFIG_PYTHON="python"
CONFIG_MAKE_WARN_UNDEFINED_VARIABLES=y
# Bootloader config
CONFIG_LOG_BOOTLOADER_LEVEL_NONE=
CONFIG_LOG_BOOTLOADER_LEVEL_ERROR=
CONFIG_LOG_BOOTLOADER_LEVEL_WARN=y
CONFIG_LOG_BOOTLOADER_LEVEL_INFO=
CONFIG_LOG_BOOTLOADER_LEVEL_DEBUG=
CONFIG_LOG_BOOTLOADER_LEVEL_VERBOSE=
CONFIG_LOG_BOOTLOADER_LEVEL=2
CONFIG_BOOTLOADER_SPI_WP_PIN=7
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_8V=
CONFIG_BOOTLOADER_VDDSDIO_BOOST_1_9V=y
# Security features
CONFIG_SECURE_BOOT_ENABLED=
CONFIG_FLASH_ENCRYPTION_ENABLED=
# Serial flasher config
CONFIG_ESPTOOLPY_PORT="/dev/ttyUSB0"
CONFIG_ESPTOOLPY_BAUD_115200B=
CONFIG_ESPTOOLPY_BAUD_230400B=
CONFIG_ESPTOOLPY_BAUD_921600B=y
CONFIG_ESPTOOLPY_BAUD_2MB=
CONFIG_ESPTOOLPY_BAUD_OTHER=
CONFIG_ESPTOOLPY_BAUD_OTHER_VAL=115200
CONFIG_ESPTOOLPY_BAUD=921600
CONFIG_ESPTOOLPY_COMPRESSED=y
CONFIG_FLASHMODE_QIO=y
CONFIG_FLASHMODE_QOUT=
CONFIG_FLASHMODE_DIO=
CONFIG_FLASHMODE_DOUT=
CONFIG_ESPTOOLPY_FLASHMODE="dio"
CONFIG_ESPTOOLPY_FLASHFREQ_80M=
CONFIG_ESPTOOLPY_FLASHFREQ_40M=y
CONFIG_ESPTOOLPY_FLASHFREQ_26M=
CONFIG_ESPTOOLPY_FLASHFREQ_20M=
CONFIG_ESPTOOLPY_FLASHFREQ="40m"
CONFIG_ESPTOOLPY_FLASHSIZE_1MB=
CONFIG_ESPTOOLPY_FLASHSIZE_2MB=
CONFIG_ESPTOOLPY_FLASHSIZE_4MB=
CONFIG_ESPTOOLPY_FLASHSIZE_8MB=
CONFIG_ESPTOOLPY_FLASHSIZE_16MB=y
CONFIG_ESPTOOLPY_FLASHSIZE="16MB"
CONFIG_ESPTOOLPY_FLASHSIZE_DETECT=y
CONFIG_ESPTOOLPY_BEFORE_RESET=y
CONFIG_ESPTOOLPY_BEFORE_NORESET=
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
CONFIG_ESPTOOLPY_AFTER_NORESET=
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_MONITOR_BAUD_9600B=
CONFIG_MONITOR_BAUD_57600B=
CONFIG_MONITOR_BAUD_115200B=y
CONFIG_MONITOR_BAUD_230400B=
CONFIG_MONITOR_BAUD_921600B=
CONFIG_MONITOR_BAUD_2MB=
CONFIG_MONITOR_BAUD_OTHER=
CONFIG_MONITOR_BAUD_OTHER_VAL=115200
CONFIG_MONITOR_BAUD=115200
# Partition Table
CONFIG_PARTITION_TABLE_SINGLE_APP=
CONFIG_PARTITION_TABLE_TWO_OTA=
CONFIG_PARTITION_TABLE_CUSTOM=y
CONFIG_PARTITION_TABLE_CUSTOM_FILENAME="partitions.csv"
CONFIG_PARTITION_TABLE_CUSTOM_APP_BIN_OFFSET=0x10000
CONFIG_PARTITION_TABLE_FILENAME="partitions.csv"
CONFIG_APP_OFFSET=0x10000
CONFIG_PARTITION_TABLE_MD5=y
# Compiler options
CONFIG_OPTIMIZATION_LEVEL_DEBUG=y
CONFIG_OPTIMIZATION_LEVEL_RELEASE=
CONFIG_OPTIMIZATION_ASSERTIONS_ENABLED=y
CONFIG_OPTIMIZATION_ASSERTIONS_SILENT=
CONFIG_OPTIMIZATION_ASSERTIONS_DISABLED=
CONFIG_CXX_EXCEPTIONS=
CONFIG_STACK_CHECK_NONE=y
CONFIG_STACK_CHECK_NORM=
CONFIG_STACK_CHECK_STRONG=
CONFIG_STACK_CHECK_ALL=
CONFIG_STACK_CHECK=
CONFIG_WARN_WRITE_STRINGS=
# Component config
# Application Level Tracing
CONFIG_ESP32_APPTRACE_DEST_TRAX=
CONFIG_ESP32_APPTRACE_DEST_NONE=y
CONFIG_ESP32_APPTRACE_ENABLE=
CONFIG_ESP32_APPTRACE_LOCK_ENABLE=y
# FreeRTOS SystemView Tracing
CONFIG_AWS_IOT_SDK=
# Bluetooth
CONFIG_BT_ENABLED=
CONFIG_BTDM_CONTROLLER_PINNED_TO_CORE=0
CONFIG_BT_RESERVE_DRAM=0
# ADC configuration
CONFIG_ADC_FORCE_XPD_FSM=
CONFIG_ADC2_DISABLE_DAC=y
# ESP32-specific
CONFIG_ESP32_DEFAULT_CPU_FREQ_80=
CONFIG_ESP32_DEFAULT_CPU_FREQ_160=
CONFIG_ESP32_DEFAULT_CPU_FREQ_240=y
CONFIG_ESP32_DEFAULT_CPU_FREQ_MHZ=240
CONFIG_SPIRAM_SUPPORT=y
# SPI RAM config
CONFIG_SPIRAM_BOOT_INIT=y
CONFIG_SPIRAM_IGNORE_NOTFOUND=
CONFIG_SPIRAM_USE_MEMMAP=
CONFIG_SPIRAM_USE_CAPS_ALLOC=y
CONFIG_SPIRAM_USE_MALLOC=
CONFIG_SPIRAM_TYPE_ESPPSRAM32=y
CONFIG_SPIRAM_SIZE=4194304
CONFIG_SPIRAM_SPEED_40M=y
CONFIG_SPIRAM_MEMTEST=y
CONFIG_SPIRAM_CACHE_WORKAROUND=y
CONFIG_WIFI_LWIP_ALLOCATION_FROM_SPIRAM_FIRST=y
CONFIG_MEMMAP_TRACEMEM=
CONFIG_MEMMAP_TRACEMEM_TWOBANKS=
CONFIG_ESP32_TRAX=
CONFIG_TRACEMEM_RESERVE_DRAM=0x0
CONFIG_ESP32_ENABLE_COREDUMP_TO_FLASH=
CONFIG_ESP32_ENABLE_COREDUMP_TO_UART=
CONFIG_ESP32_ENABLE_COREDUMP_TO_NONE=y
CONFIG_ESP32_ENABLE_COREDUMP=
CONFIG_TWO_UNIVERSAL_MAC_ADDRESS=
CONFIG_FOUR_UNIVERSAL_MAC_ADDRESS=y
CONFIG_NUMBER_OF_UNIVERSAL_MAC_ADDRESS=4
CONFIG_SYSTEM_EVENT_QUEUE_SIZE=32
CONFIG_SYSTEM_EVENT_TASK_STACK_SIZE=4096
CONFIG_MAIN_TASK_STACK_SIZE=4096
CONFIG_IPC_TASK_STACK_SIZE=1024
CONFIG_TIMER_TASK_STACK_SIZE=3584
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CRLF=y
CONFIG_NEWLIB_STDOUT_LINE_ENDING_LF=
CONFIG_NEWLIB_STDOUT_LINE_ENDING_CR=
CONFIG_NEWLIB_STDIN_LINE_ENDING_CRLF=
CONFIG_NEWLIB_STDIN_LINE_ENDING_LF=
CONFIG_NEWLIB_STDIN_LINE_ENDING_CR=y
CONFIG_NEWLIB_NANO_FORMAT=
CONFIG_CONSOLE_UART_DEFAULT=y
CONFIG_CONSOLE_UART_CUSTOM=
CONFIG_CONSOLE_UART_NONE=
CONFIG_CONSOLE_UART_NUM=0
CONFIG_CONSOLE_UART_BAUDRATE=115200
CONFIG_ULP_COPROC_ENABLED=
CONFIG_ULP_COPROC_RESERVE_MEM=0
CONFIG_ESP32_PANIC_PRINT_HALT=
CONFIG_ESP32_PANIC_PRINT_REBOOT=y
CONFIG_ESP32_PANIC_SILENT_REBOOT=
CONFIG_ESP32_PANIC_GDBSTUB=
CONFIG_ESP32_PANIC_CALLBACK=y
CONFIG_ESP32_DEBUG_OCDAWARE=y
CONFIG_INT_WDT=y
CONFIG_INT_WDT_TIMEOUT_MS=500
CONFIG_INT_WDT_CHECK_CPU1=y
CONFIG_TASK_WDT=y
CONFIG_TASK_WDT_PANIC=y
CONFIG_TASK_WDT_TIMEOUT_S=60
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU0=y
CONFIG_TASK_WDT_CHECK_IDLE_TASK_CPU1=y
CONFIG_BROWNOUT_DET=y
CONFIG_BROWNOUT_DET_LVL_SEL_0=y
CONFIG_BROWNOUT_DET_LVL_SEL_1=
CONFIG_BROWNOUT_DET_LVL_SEL_2=
CONFIG_BROWNOUT_DET_LVL_SEL_3=
CONFIG_BROWNOUT_DET_LVL_SEL_4=
CONFIG_BROWNOUT_DET_LVL_SEL_5=
CONFIG_BROWNOUT_DET_LVL_SEL_6=
CONFIG_BROWNOUT_DET_LVL_SEL_7=
CONFIG_BROWNOUT_DET_LVL=0
CONFIG_ESP32_TIME_SYSCALL_USE_RTC_FRC1=y
CONFIG_ESP32_TIME_SYSCALL_USE_RTC=
CONFIG_ESP32_TIME_SYSCALL_USE_FRC1=
CONFIG_ESP32_TIME_SYSCALL_USE_NONE=
CONFIG_ESP32_RTC_CLOCK_SOURCE_INTERNAL_RC=y
CONFIG_ESP32_RTC_CLOCK_SOURCE_EXTERNAL_CRYSTAL=
CONFIG_ESP32_RTC_CLK_CAL_CYCLES=1024
CONFIG_ESP32_RTC_XTAL_BOOTSTRAP_CYCLES=100
CONFIG_ESP32_DEEP_SLEEP_WAKEUP_DELAY=0
CONFIG_ESP32_XTAL_FREQ_40=
CONFIG_ESP32_XTAL_FREQ_26=
CONFIG_ESP32_XTAL_FREQ_AUTO=y
CONFIG_ESP32_XTAL_FREQ=0
CONFIG_DISABLE_BASIC_ROM_CONSOLE=
CONFIG_NO_BLOBS=
CONFIG_ESP_TIMER_PROFILING=
CONFIG_COMPATIBLE_PRE_V2_1_BOOTLOADERS=
CONFIG_ESP_ERR_TO_NAME_LOOKUP=y
# Wi-Fi
CONFIG_ESP32_WIFI_STATIC_RX_BUFFER_NUM=4
CONFIG_ESP32_WIFI_DYNAMIC_RX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_STATIC_TX_BUFFER=
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER=y
CONFIG_ESP32_WIFI_TX_BUFFER_TYPE=1
CONFIG_ESP32_WIFI_DYNAMIC_TX_BUFFER_NUM=16
CONFIG_ESP32_WIFI_AMPDU_TX_ENABLED=y
CONFIG_ESP32_WIFI_TX_BA_WIN=6
CONFIG_ESP32_WIFI_AMPDU_RX_ENABLED=y
CONFIG_ESP32_WIFI_RX_BA_WIN=6
CONFIG_ESP32_WIFI_NVS_ENABLED=y
# PHY
CONFIG_ESP32_PHY_CALIBRATION_AND_DATA_STORAGE=y
CONFIG_ESP32_PHY_INIT_DATA_IN_PARTITION=
CONFIG_ESP32_PHY_MAX_WIFI_TX_POWER=20
CONFIG_ESP32_PHY_MAX_TX_POWER=20
# Power Management
CONFIG_PM_ENABLE=
CONFIG_ESPCAN=y
CONFIG_ESP_CAN_RXD_PIN_NUM=26
CONFIG_ESP_CAN_TXD_PIN_NUM=25
CONFIG_CAN_SPEED_100KBPS=y
CONFIG_CAN_SPEED_125KBPS=
CONFIG_CAN_SPEED_250KBPS=
CONFIG_CAN_SPEED_500KBPS=
CONFIG_CAN_SPEED_800KBPS=
CONFIG_CAN_SPEED_1000KBPS=
CONFIG_CAN_SPEED_USER_KBPS=
# ADC-Calibration
CONFIG_ADC_CAL_EFUSE_TP_ENABLE=y
CONFIG_ADC_CAL_EFUSE_VREF_ENABLE=y
CONFIG_ADC_CAL_LUT_ENABLE=y
# Ethernet
CONFIG_DMA_RX_BUF_NUM=10
CONFIG_DMA_TX_BUF_NUM=10
CONFIG_EMAC_L2_TO_L3_RX_BUF_MODE=
CONFIG_EMAC_TASK_PRIORITY=20
# FAT Filesystem support
CONFIG_FATFS_CODEPAGE_DYNAMIC=
CONFIG_FATFS_CODEPAGE_437=
CONFIG_FATFS_CODEPAGE_720=
CONFIG_FATFS_CODEPAGE_737=
CONFIG_FATFS_CODEPAGE_771=
CONFIG_FATFS_CODEPAGE_775=
CONFIG_FATFS_CODEPAGE_850=y
CONFIG_FATFS_CODEPAGE_852=
CONFIG_FATFS_CODEPAGE_855=
CONFIG_FATFS_CODEPAGE_857=
CONFIG_FATFS_CODEPAGE_860=
CONFIG_FATFS_CODEPAGE_861=
CONFIG_FATFS_CODEPAGE_862=
CONFIG_FATFS_CODEPAGE_863=
CONFIG_FATFS_CODEPAGE_864=
CONFIG_FATFS_CODEPAGE_865=
CONFIG_FATFS_CODEPAGE_866=
CONFIG_FATFS_CODEPAGE_869=
CONFIG_FATFS_CODEPAGE_932=
CONFIG_FATFS_CODEPAGE_936=
CONFIG_FATFS_CODEPAGE_949=
CONFIG_FATFS_CODEPAGE_950=
CONFIG_FATFS_CODEPAGE=850
CONFIG_FATFS_LFN_NONE=
CONFIG_FATFS_LFN_HEAP=y
CONFIG_FATFS_LFN_STACK=
CONFIG_FATFS_MAX_LFN=128
CONFIG_FATFS_API_ENCODING_ANSI_OEM=y
CONFIG_FATFS_API_ENCODING_UTF_16=
CONFIG_FATFS_API_ENCODING_UTF_8=
CONFIG_FATFS_FS_LOCK=0
CONFIG_FATFS_TIMEOUT_MS=10000
CONFIG_FATFS_PER_FILE_CACHE=
# FreeRTOS
CONFIG_FREERTOS_UNICORE=
CONFIG_FREERTOS_CORETIMER_0=y
CONFIG_FREERTOS_CORETIMER_1=
CONFIG_FREERTOS_HZ=100
CONFIG_FREERTOS_ASSERT_ON_UNTESTED_FUNCTION=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_NONE=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_PTRVAL=
CONFIG_FREERTOS_CHECK_STACKOVERFLOW_CANARY=y
CONFIG_FREERTOS_WATCHPOINT_END_OF_STACK=
CONFIG_FREERTOS_INTERRUPT_BACKTRACE=y
CONFIG_FREERTOS_THREAD_LOCAL_STORAGE_POINTERS=1
CONFIG_FREERTOS_ASSERT_FAIL_ABORT=y
CONFIG_FREERTOS_ASSERT_FAIL_PRINT_CONTINUE=
CONFIG_FREERTOS_ASSERT_DISABLE=
CONFIG_FREERTOS_IDLE_TASK_STACKSIZE=1024
CONFIG_FREERTOS_ISR_STACKSIZE=1536
CONFIG_FREERTOS_LEGACY_HOOKS=
CONFIG_FREERTOS_MAX_TASK_NAME_LEN=16
CONFIG_SUPPORT_STATIC_ALLOCATION=
CONFIG_TIMER_TASK_PRIORITY=1
CONFIG_TIMER_TASK_STACK_DEPTH=3072
CONFIG_TIMER_QUEUE_LENGTH=10
CONFIG_FREERTOS_QUEUE_REGISTRY_SIZE=0
CONFIG_FREERTOS_USE_TRACE_FACILITY=y
CONFIG_FREERTOS_USE_STATS_FORMATTING_FUNCTIONS=
CONFIG_FREERTOS_GENERATE_RUN_TIME_STATS=
CONFIG_FREERTOS_DEBUG_INTERNALS=
# Heap memory debugging
CONFIG_HEAP_POISONING_DISABLED=
CONFIG_HEAP_POISONING_LIGHT=y
CONFIG_HEAP_POISONING_COMPREHENSIVE=
CONFIG_HEAP_TRACING=
CONFIG_HEAP_TASK_TRACKING=y
# libsodium
CONFIG_LIBSODIUM_USE_MBEDTLS_SHA=y
# Log output
CONFIG_LOG_DEFAULT_LEVEL_NONE=
CONFIG_LOG_DEFAULT_LEVEL_ERROR=
CONFIG_LOG_DEFAULT_LEVEL_WARN=
CONFIG_LOG_DEFAULT_LEVEL_INFO=y
CONFIG_LOG_DEFAULT_LEVEL_DEBUG=
CONFIG_LOG_DEFAULT_LEVEL_VERBOSE=
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_LOG_COLORS=y
# LWIP
CONFIG_L2_TO_L3_COPY=
CONFIG_LWIP_IRAM_OPTIMIZATION=
CONFIG_LWIP_MAX_SOCKETS=10
CONFIG_LWIP_SO_REUSE=y
CONFIG_LWIP_SO_REUSE_RXTOALL=y
CONFIG_LWIP_SO_RCVBUF=
CONFIG_LWIP_DHCP_MAX_NTP_SERVERS=1
CONFIG_LWIP_IP_FRAG=
CONFIG_LWIP_IP_REASSEMBLY=
CONFIG_LWIP_STATS=
CONFIG_LWIP_ETHARP_TRUST_IP_MAC=y
CONFIG_TCPIP_RECVMBOX_SIZE=32
CONFIG_LWIP_DHCP_DOES_ARP_CHECK=
# DHCP server
CONFIG_LWIP_DHCPS_LEASE_UNIT=60
CONFIG_LWIP_DHCPS_MAX_STATION_NUM=8
CONFIG_LWIP_AUTOIP=
CONFIG_LWIP_NETIF_LOOPBACK=y
CONFIG_LWIP_LOOPBACK_MAX_PBUFS=8
# TCP
CONFIG_LWIP_MAX_ACTIVE_TCP=16
CONFIG_LWIP_MAX_LISTENING_TCP=8
CONFIG_TCP_MAXRTX=12
CONFIG_TCP_SYNMAXRTX=6
CONFIG_TCP_MSS=1436
CONFIG_TCP_MSL=60000
CONFIG_TCP_SND_BUF_DEFAULT=5744
CONFIG_TCP_WND_DEFAULT=5744
CONFIG_TCP_RECVMBOX_SIZE=6
CONFIG_TCP_QUEUE_OOSEQ=y
CONFIG_TCP_OVERSIZE_MSS=y
CONFIG_TCP_OVERSIZE_QUARTER_MSS=
CONFIG_TCP_OVERSIZE_DISABLE=
# UDP
CONFIG_LWIP_MAX_UDP_PCBS=16
CONFIG_UDP_RECVMBOX_SIZE=6
CONFIG_TCPIP_TASK_STACK_SIZE=2560
CONFIG_PPP_SUPPORT=y
CONFIG_PPP_PAP_SUPPORT=y
CONFIG_PPP_CHAP_SUPPORT=y
CONFIG_PPP_MSCHAP_SUPPORT=
CONFIG_PPP_MPPE_SUPPORT=
CONFIG_PPP_DEBUG_ON=
# ICMP
CONFIG_LWIP_MULTICAST_PING=
CONFIG_LWIP_BROADCAST_PING=
# LWIP RAW API
CONFIG_LWIP_MAX_RAW_PCBS=16
CONFIG_OVMS=y
CONFIG_OVMS_VERSION_TAG="main"
# Hardware Support
CONFIG_OVMS_HW_BASE_3_0=
CONFIG_OVMS_HW_BASE_3_1=y
CONFIG_OVMS_HW_SPIMEM_AGGRESSIVE=y
# Library Support
CONFIG_OVMS_SC_JAVASCRIPT_NONE=
CONFIG_OVMS_SC_JAVASCRIPT_DUKTAPE=y
CONFIG_OVMS_SC_GPL_MONGOOSE=y
CONFIG_MG_ENABLE_FILESYSTEM=y
CONFIG_MG_ENABLE_DIRECTORY_LISTING=y
CONFIG_MG_ENABLE_DEBUG=
CONFIG_OVMS_SC_GPL_WOLF=y
# Vehicle Support
CONFIG_OVMS_VEHICLE_NONE=y
CONFIG_OVMS_VEHICLE_OBDII=y
CONFIG_OVMS_VEHICLE_TRACK=y
CONFIG_OVMS_VEHICLE_DEMO=y
CONFIG_OVMS_VEHICLE_TESLAROADSTER=y
CONFIG_OVMS_VEHICLE_TESLAMODELS=y
CONFIG_OVMS_VEHICLE_NISSANLEAF=y
CONFIG_OVMS_VEHICLE_RENAULTTWIZY=y
CONFIG_OVMS_VEHICLE_KIASOULEV=y
CONFIG_OVMS_VEHICLE_VOLTAMPERA=y
CONFIG_OVMS_VEHICLE_RXTASK_STACK=6144
# Component Options
CONFIG_OVMS_COMP_WIFI=y
CONFIG_OVMS_COMP_MAX7317=y
CONFIG_OVMS_COMP_ESP32CAN=y
CONFIG_OVMS_COMP_MCP2515=y
CONFIG_OVMS_COMP_ADC=y
CONFIG_OVMS_COMP_EXT12V=y
CONFIG_OVMS_COMP_SERVER=y
CONFIG_OVMS_COMP_SERVER_V2=y
CONFIG_OVMS_COMP_SERVER_V3=y
CONFIG_OVMS_COMP_OTA=y
CONFIG_OVMS_COMP_LOCATION=y
CONFIG_OVMS_COMP_WEBSERVER=y
CONFIG_OVMS_COMP_MDNS=y
CONFIG_OVMS_COMP_TELNET=
CONFIG_OVMS_COMP_SSH=y
CONFIG_OVMS_COMP_MODEM_SIMCOM=y
CONFIG_OVMS_COMP_SDCARD=y
CONFIG_OVMS_COMP_OBD2ECU=y
CONFIG_OVMS_COMP_RE_TOOLS=y
CONFIG_OVMS_COMP_EDITOR=y
CONFIG_OVMS_COMP_CANOPEN=y
CONFIG_OVMS_COMP_CANOPEN_RX_STACK=4096
CONFIG_OVMS_COMP_CANOPEN_WRK_STACK=3072
# Developer Options
CONFIG_OVMS_DEV_CONFIGVFS=
CONFIG_OMMS_DEV_SDCARDSCRIPTS=
CONFIG_OVMS_DEV_DEBUGEVENTS=
CONFIG_OVMS_DEV_DEBUGNOTIFICATIONS=
# mbedTLS
CONFIG_MBEDTLS_SSL_MAX_CONTENT_LEN=4096
CONFIG_MBEDTLS_DEBUG=
CONFIG_MBEDTLS_HARDWARE_AES=y
CONFIG_MBEDTLS_HARDWARE_MPI=
CONFIG_MBEDTLS_HARDWARE_SHA=
CONFIG_MBEDTLS_HAVE_TIME=y
CONFIG_MBEDTLS_HAVE_TIME_DATE=
CONFIG_MBEDTLS_TLS_SERVER_AND_CLIENT=y
CONFIG_MBEDTLS_TLS_SERVER_ONLY=
CONFIG_MBEDTLS_TLS_CLIENT_ONLY=
CONFIG_MBEDTLS_TLS_DISABLED=
CONFIG_MBEDTLS_TLS_SERVER=y
CONFIG_MBEDTLS_TLS_CLIENT=y
CONFIG_MBEDTLS_TLS_ENABLED=y
# TLS Key Exchange Methods
CONFIG_MBEDTLS_PSK_MODES=
CONFIG_MBEDTLS_KEY_EXCHANGE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_DHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ELLIPTIC_CURVE=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_RSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDHE_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_ECDSA=y
CONFIG_MBEDTLS_KEY_EXCHANGE_ECDH_RSA=y
CONFIG_MBEDTLS_SSL_RENEGOTIATION=y
CONFIG_MBEDTLS_SSL_PROTO_SSL3=
CONFIG_MBEDTLS_SSL_PROTO_TLS1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_1=y
CONFIG_MBEDTLS_SSL_PROTO_TLS1_2=y
CONFIG_MBEDTLS_SSL_PROTO_DTLS=
CONFIG_MBEDTLS_SSL_ALPN=y
CONFIG_MBEDTLS_SSL_SESSION_TICKETS=y
# Symmetric Ciphers
CONFIG_MBEDTLS_AES_C=y
CONFIG_MBEDTLS_CAMELLIA_C=
CONFIG_MBEDTLS_DES_C=
CONFIG_MBEDTLS_RC4_DISABLED=y
CONFIG_MBEDTLS_RC4_ENABLED_NO_DEFAULT=
CONFIG_MBEDTLS_RC4_ENABLED=
CONFIG_MBEDTLS_BLOWFISH_C=
CONFIG_MBEDTLS_XTEA_C=
CONFIG_MBEDTLS_CCM_C=y
CONFIG_MBEDTLS_GCM_C=y
CONFIG_MBEDTLS_RIPEMD160_C=
# Certificates
CONFIG_MBEDTLS_PEM_PARSE_C=y
CONFIG_MBEDTLS_PEM_WRITE_C=y
CONFIG_MBEDTLS_X509_CRL_PARSE_C=y
CONFIG_MBEDTLS_X509_CSR_PARSE_C=y
CONFIG_MBEDTLS_ECP_C=y
CONFIG_MBEDTLS_ECDH_C=y
CONFIG_MBEDTLS_ECDSA_C=y
CONFIG_MBEDTLS_ECP_DP_SECP192R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP521R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP192K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP224K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_SECP256K1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP256R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP384R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_BP512R1_ENABLED=y
CONFIG_MBEDTLS_ECP_DP_CURVE25519_ENABLED=y
CONFIG_MBEDTLS_ECP_NIST_OPTIM=y
# OpenSSL
CONFIG_OPENSSL_DEBUG=
CONFIG_OPENSSL_ASSERT_DO_NOTHING=y
CONFIG_OPENSSL_ASSERT_EXIT=
# PThreads
CONFIG_ESP32_PTHREAD_TASK_PRIO_DEFAULT=5
CONFIG_ESP32_PTHREAD_TASK_STACK_SIZE_DEFAULT=3072
# SPI Flash driver
CONFIG_SPI_FLASH_VERIFY_WRITE=y
CONFIG_SPI_FLASH_LOG_FAILED_WRITE=
CONFIG_SPI_FLASH_WARN_SETTING_ZERO_TO_ONE=
CONFIG_SPI_FLASH_ENABLE_COUNTERS=
CONFIG_SPI_FLASH_ROM_DRIVER_PATCH=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ABORTS=y
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_FAILS=
CONFIG_SPI_FLASH_WRITING_DANGEROUS_REGIONS_ALLOWED=
# SPIFFS Configuration
CONFIG_SPIFFS_MAX_PARTITIONS=3
# SPIFFS Cache Configuration
CONFIG_SPIFFS_CACHE=y
CONFIG_SPIFFS_CACHE_WR=y
CONFIG_SPIFFS_CACHE_STATS=
CONFIG_SPIFFS_PAGE_CHECK=y
CONFIG_SPIFFS_GC_MAX_RUNS=10
CONFIG_SPIFFS_GC_STATS=
CONFIG_SPIFFS_PAGE_SIZE=256
CONFIG_SPIFFS_OBJ_NAME_LEN=32
CONFIG_SPIFFS_USE_MAGIC=y
CONFIG_SPIFFS_USE_MAGIC_LENGTH=y
CONFIG_SPIFFS_META_LENGTH=4
CONFIG_SPIFFS_USE_MTIME=y
# Debug Configuration
CONFIG_SPIFFS_DBG=
CONFIG_SPIFFS_API_DBG=
CONFIG_SPIFFS_GC_DBG=
CONFIG_SPIFFS_CACHE_DBG=
CONFIG_SPIFFS_CHECK_DBG=
CONFIG_SPIFFS_TEST_VISUALISATION=
# tcpip adapter
CONFIG_IP_LOST_TIMER_INTERVAL=60
# Wear Levelling
CONFIG_WL_SECTOR_SIZE_512=
CONFIG_WL_SECTOR_SIZE_4096=y
CONFIG_WL_SECTOR_SIZE=4096
