[Ovmsdev] Nissan Leaf 2018 cable
    Mon Jun 25 09:55:34 HKT 2018
I got this enquiry regarding the cable for the 2018 Nissan Leaf.
It seems that the OBDII pinout has changed? Anyone know anything about this?
> Begin forwarded message:
> ...But if this is correct, it will probably not work on the 2018 Nissan Leaf, because ODB2-Pins 12 and 13 are not assigned (see the image from the service manual attached - page 17) and when I take a look at the connector I can clearly see, that 12 and 13 have no metal clip - no electrical connection possible.
> Do I have to - somehow - connect the OVMS to the CAN Bus the TCU is connected to?
> Or do I have to select something special in the web-interface of the OVMS module, like the model-year?
Type: application/pdf
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180625/b8055050/attachment-0001.pdf>
