Tue Jul 10 09:30:01 HKT 2018
I don't see “Password:” overwriting “OVMS>” but I see "Secure mode"
overwriting "Password:".  Since "Secure mode" is a printf, not a
write, I would expect \n to be massaged into \r\n somewhere along the
path.  It can't be expected that all output strings get \r\n instead
of \n.  So I have to retract my assertion of having fixed the problem.
On Tue, 10 Jul 2018, Mark Webb-Johnson wrote:
> Still not working for me. I get:
> “Password:” overwriting “OVMS>” when I type “enable”.
> First line of output overwrites command prompt whenever I type a command.
> Pressing ENTER at “OVMS#” prompt seemingly does nothing.
> Looking through the code, we send \n, not \r\n, in multiple places (for example in ovms_command.cpp enableInsert() function that handles password entry. A ‘find in project’ for \n shows 11,350 results! Simple_monitor works just fine.
> > On 10 Jul 2018, at 4:35 AM, Stephen Casner <casner at acm.org> wrote:
> > This problem of no newline is related to the somewhat tricky way I
> > implemented alert output being written above the current command input
> > line.  I truncate the newline from the last or only line of an alert
> > message so that when it is followed by microrl putting out a new
> > prompt, which is preceded by a newline, we don't get a blank line.
> > I've just committed a fix.  The problem was that the terminal monitor
> > discards a newline that does not follow carriage return, and microrl's
> > terminal_newline() function was written to output the same string to
> > go to the next line as it takes for input to indicate the end of a
> > command.  We need the input end-of-line to be just a newline
> > character, so that is all that terminal_newline() put out before the
> > prompt.  My fix was to change terminal_newline() to output the
> > explicit string "\r\n" rather than the macro ENDL.
> >                                                        -- Steve
> > OvmsDev mailing list
