Mon Jul 9 06:14:51 HKT 2018
Sorry, no user feedback up to now on the wifi issues. As I don't have them myself, I need to wait for feedback. But no news means it's at least not worse than
before ;)
Anyway, I've pushed the changes and esp-idf update.
@all: you need to update your esp-idf to build the current version:
  * cd $IDF_PATH
  * git pull
  * git submodule update --recursive
Am 08.07.2018 um 10:59 schrieb Mark Webb-Johnson:
>> I even have some more free IRAM now, it used to be down to ~1K and is now ~7K.
> That is very very good news. Using RELEASE build (rather than DEBUG), I got mine down to a usable level, but this should give us some breathing room.
> Any noticeable improvement to the wifi issues?
>> On 8 Jul 2018, at 4:49 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>> The new esp-idf works good, I think I'll push the changes this evening.
>> Remaining crashes recorded up to now:
>>   * 3.1.008-32-g2fa3ab8-dirty/ota_1/edge (build idf v3.2-dev-168-g0fb2019f Jul 6 2018 20:49:00),7,Crash,8,14,1,0,IllegalInstruction,0,0x00000000 0x00000000
>>     0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
>>     0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 ,
>>   * 3.1.008-32-g2fa3ab8-dirty/ota_0/edge (build idf v3.2-dev-168-g0fb2019f Jul 6 2018 20:49:00),98,Crash,8,14,1,0,LoadProhibited,1,0x401165fc 0x00060230
>>     0x80106004 0x3fff0d40 0x3ffc4794 0x00000000 0x3f4020ac 0x3fff1080 0x3fff1060 0x00000008 0x3ffed634 0x00000000 0x00000001 0x3ffc41f5 0x000000ff 0x0000ff00
>>     0x00ff0000 0xff000000 0x00000004 0x0000001c 0x00000064 0x4009ee01 0x4009ee11 0xffffffff ,0x401165fc 0x40106001 0x400d3f9b 0x400d3ab5
>>>>     Using elf file: tmp/3.1.008-32-g2fa3ab8-dirty-elf/ovms3.elf
>>     0x401165fc is in _vfprintf_r (../../../.././newlib/libc/stdio/vfprintf.c:1855).
>>     0x40106001 is in _siprintf_r (../../../.././newlib/libc/stdio/siprintf.c:124).
>>     0x400d3f9b is in std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_construct<char*>(char*, char*,
>>     std::forward_iterator_tag) (/home/balzer/esp/xtensa-esp32-elf/xtensa-esp32-elf/include/c++/5.2.0/bits/basic_string.tcc:215).
>>     210          basic_string<_CharT, _Traits, _Alloc>::
>>     211          _M_construct(_InIterator __beg, _InIterator __end,
>>     212               std::forward_iterator_tag)
>>     213          {
>>     214        // NB: Not required, but considered best practice.
>>     215        if (__gnu_cxx::__is_null_pointer(__beg) && __beg != __end)
>>     216          std::__throw_logic_error(__N("basic_string::"
>>     217                           "_M_construct null not valid"));
>>     218
>>     219        size_type __dnew = static_cast<size_type>(std::distance(__beg, __end));
>>     0x400d3ab5 is in canlog::LogStatus(canbus*, CAN_LogEntry_t, CAN_status_t const*)
>>     (/home/balzer/esp/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/can/src/canlog.cpp:297).
>>     292        return;
>>     293      if (CheckFilter(bus, type))
>>     294        {
>>     295        CAN_LogMsg_t msg;
>>     296        msg.timestamp = esp_log_timestamp();
>>     297        msg.bus = bus;
>>     298        msg.type = type;
>>     299        msg.status = *status;
>>     300        m_msgcount++;
>>     301        if (xQueueSend(m_queue, &msg, 0) != pdTRUE)
>>   * 3.1.008-32-g2fa3ab8-dirty/ota_1/edge (build idf v3.2-dev-168-g0fb2019f Jul 6 2018 20:49:00),11,Crash,12,12,3,0,abort(),0,,0x40095e74 0x4009606f
>>     0x400ddaf7 0x40084e15 0x401e271d
>>     → watchdog timeout, no more info
>> Am 06.07.2018 um 22:07 schrieb Michael Balzer:
>>> I've been using APCLIENT all the time and only had one crash that looked like a wifi problem. This really is a very specific problem. I also have a very
>>> good wifi signal, I can perfectly use my module's web UI while the car is in my garage two floors below. But I live in an uncrowded area, not much wifi
>>> competition.
>>> I have updated my esp-idf to the latest upstream master (it's v3.2 now) and could build without any memory issues. The wifi driver now, besided loads of bug
>>> fixes, also supports CSI. Our code only needs a minor adjustment if you'd like to compile yourself, add…
>>> #define _SOC_SPI_PERIPH_H_ // don't include spi_periph.h (type conflict)
>>> …in components/spinodma/spi_master_nodma.h before #include "driver/spi_common.h".
>>> If you don't want to compile, the new build (with CSI enabled) is also on my server:
>>> http://ovms.dexters-web.de/firmware/ota/v3.1/edge/
>>> …and now being installed by my beta testers.
>>> Am 06.07.2018 um 16:28 schrieb Mark Webb-Johnson:
>>>> My 2c:
>>>> For the access points I normally use, it works 100% of the time for me. The only issue I had was when the SSID password was wrong on one of my access
>>>> points (sharing the same SSID) and that was randomly causing me connection issues (every time the ESP32 picked it).
>>>> I also don’t use APCLIENT, and only use SCLIENT mode. I’ve found APCLIENT to be buggy as hell.
>>>> But, I do have problems connecting to some access points. In particular phone hotspots. I suspect either bugs in the wifi stack, or some issue with channels.
>>>> The only thing I am wary of is that our current code does this:
>>>>     esp_wifi_set_config…
>>>>     esp_wifi_start…
>>>>     esp_wifi_connect...
>>>> But the Espressif examples have:
>>>>     esp_wifi_start…
>>>>     Wait for SYSTEM_EVENT_STA_START
>>>>         esp_wifi_connect...
>>>> I had that working the Espressif way in my big wifi refactor that never made it to production. But our current code doesn’t wait for the
>>>> SYSTEM_EVENT_STA_START before calling esp_wifi_connect.
>>>> Regards, Mark.
>>>>> On 6 Jul 2018, at 9:04 PM, Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>> wrote:
>>>>> I've had similar reports regarding poor wifi connectivity, and this seems to affect some modules more than others (or may be channel/frequency
>>>>> dependant?). One
>>>>> user has just 1-2 bars AP wifi signal with the module placed ~ 50 cm away from the phone.
>>>>> I also still get reports of spurious strange crashes, that mostly seem to be related to situations with poor wifi signal. Some crash backtraces just are
>>>>> complete blank / null, and there is no crash report on the USB output for these before reboot.
>>>>> Yesterday, Frank tried to perform some wifi scans. The first scan went fine, the second never returned, he had to power off the module. After reboot, all
>>>>> successive scans worked.
>>>>> Two users reported they occasionally cannot auth to the OVMS AP with the correct password, and they can then reconnect just by retrying for some minutes or by
>>>>> connecting & disconnecting another client to the AP.
>>>>> I already had a look at the wifi tx power configuration, it's at 100% by default.
>>>>> This all feels like a) we need to change something about the antenna, and b) there are quite some bugs in the wifi blob.
>>>>> Looking at https://github.com/espressif/esp32-wifi-lib/commits/master it seems there have been numerous wifi blob fixes lately. Last time I checked I
>>>>> still was
>>>>> out of memory with the current esp-idf, I'll check again.
>>>>> Regards,
>>>>> Michael
>>>>> Am 06.07.2018 um 01:48 schrieb Stephen Casner:
>>>>>> I find the wifi performance of OVMS v3 to be poor, and I'm wondering
>>>>>> how it might be improved.  I have a mix of thoughts here.
>>>>>> For both my own unit and that of Timothy Rodgers, wifi reception in
>>>>>> our garages was unusable.  You can blame that on too much distance
>>>>>> from the access point, but my iPhone and MacBook both access the wifi
>>>>>> just fine from my garage.  The wifi antenna in the OVMS is probably
>>>>>> smaller and its location within the metal framework around the car's
>>>>>> firewall may impede radio transmission.  Perhaps it would be feasible
>>>>>> to switch to an ESP32-WROVER-I with an external antenna to improve
>>>>>> performance, but that would be a big deal.  If there is a transmit
>>>>>> power adjustment, perhaps that could be increased?
>>>>>> When Timothy parks his car next to his house, which is about 50 feet
>>>>>> closer than the garage, then the wifi reception was good enough for
>>>>>> the update to 3.1.008 to succeed.  But when he tries to connect with
>>>>>> the browser, page updates often time out, so it is close to unusable.
>>>>>> Perhaps we could improve usability by increasing the timeout in our
>>>>>> javascript to allow more time for TCP to retransmit?
>>>>>> For my own unit, I switched from AP+client to just client mode and at
>>>>>> first it seemed that had improved the client performance.  But still
>>>>>> the next day I had no access from the iPhone app.  When I connected to
>>>>>> the console to find out why I saw that server v2 was repeatedly trying
>>>>>> to connect and failing.  I'm presuming that the cause was poor wifi
>>>>>> connectivity since I was also not able to reach the web server on the
>>>>>> client address, although I have not proven that.  But since the client
>>>>>> wifi was associated with the home AP and had an address, the OVMS
>>>>>> network routing preferred the wifi and did not try to use the modem.
>>>>>> For now I have resorted to turning off wifi.  I suggest that the
>>>>>> network routing algorithm be enhanced to back off to use the modem if
>>>>>> some number of attempts to connect to the server over wifi have
>>>>>> failed.  The iPhone will do this for itself (there is a setting to
>>>>>> enable this called Wi-Fi Assist).
>>>>>> The behavior of repeated connection attempts and failures by server v2
>>>>>> seems to induce a more serious failure after a while, perhaps due to
>>>>>> some resource starvation.  At that point there is a failure message
>>>>>> "mg_connect(api.openvehicles.com:6867 <http://api.openvehicles.com:6867/>) failed: cannot parse address"
>>>>>> every time server v2 tries to connect.  I expect that is a bug that
>>>>>> could be fixed.
>>>>>> Lastly, since we may encounter situations where network communication
>>>>>> is not working, we should facilitate access to the console.  When I
>>>>>> was trying to help Timothy change a location radius setting remotely
>>>>>> by phone and the web browser was timing out, I suggested that he find
>>>>>> a micro-USB cable so he could connect to the console.  But then I
>>>>>> realized he would not have any application on his laptop that would
>>>>>> allow him to connect to the console.  Developers use "make monitor" in
>>>>>> the software development cycle, but users won't have that tool.  I
>>>>>> have my own program on the MacBook that I use as an alternative when I
>>>>>> don't want to induce a reset when I connect.  But is there a simple
>>>>>> program for Windows suitable for non-developer users that can connect
>>>>>> to the OVMS console?
>>>>>>                                                        -- Steve
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.openvehicles.com <mailto:OvmsDev at lists.openvehicles.com>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180709/2b8b6d31/attachment.htm>
