    Tom Parker
    tom at carrott.org
    Mon Jan 29 09:07:17 HKT 2018
On 29/01/18 13:29, Mark Webb-Johnson wrote:
> Perhaps we should issue network.mgr.stop earlier? However, even if we
> close the connections from our end, I’m not sure if the packet would
> make it through to the other end before the wifi disconnects.
I don't think we need to address the situation where the server does not
get informed of the disconnection -- the disconnection could happen
before we know it has happened preventing us from signaling the server.
This could happen simply by driving away from the wifi network.
What we need to address is informing the client inside the vehicle
module that it is no longer connected. In the case where we know the
network has gone down, we can have the OVMS process listen for the event
and take appropriate actions. In the case where the network is up but
the socket is broken somewhere in the network and we get a RST response
or we never get an ACK, we should signal the client. It's been a long
time since I dealt with raw sockets and tried to handle all the edge
cases so I'll have to defer to others with more knowledge of the apis to
suggest how it should work. The v2 client is good in that it transmits
periodically (which should eliminate the need for TCP level keepalive
packets on all but the most aggressive networks) so the socket library
has an opportunity detect the broken socket and tell the client code
that the socket isn't working.
I wrote an OVMS v2 python client which suffers from the same problem,
every now and again it needs to be restarted because it thinks it is
connected but it isn't. Unlike the vehicle module, this client never
writes to the socket after login but I'm a little surprised the OS
doesn't eventually say "this socket is broken" or something, I really
should work out how to fix it (maybe by restarting if there has been no
data for some number of minutes).
