[Ovmsdev] Transition to new esp-idf
Mon Jan 22 12:53:27 HKT 2018
Umm, Mark, we're not running a separate task.  If we were, this would
not be a problem.  With one task, sleeping would do no good because
that would be causing Mongoose to sleep.  The only way we can save the
state of the "user" code that is doing the output would be to recurse
into Mongoose so it can actually send, but that is likely to lead to a
stack overflow due to repeated recursion.  After pondering many ideas,
that's why I made the change to mg_send.
It is still not difficult to use one of several options make a
solution that allows SSH to send immediately while MQTT does not, but
it's just that some mods to mongoose.c will be required.
On Mon, 22 Jan 2018, Mark Webb-Johnson wrote:
> > Perhaps check add a loop to check if ctx->send_mbuf.len and ctx->send_mbuf.size to see how much space is free. If not enough, then sleep the task (10ms or 100ms?) and try again? Or use MG_EV_SEND to set a semaphore, and pickup on that in the SendCallback? Rely on the fact that mongoose is running in a separate task and will empty the buffer when it can.
> To be hopefully clear(er):
> For event driven systems sending a big file, the usual approach is to send a block, wait for SENT callback, then send the next block. Repeat until no more file left. That approach minimises the buffer usage.
> We are trying to shoe-horn SSH into this event driven system, but the wolfssh system is expecting a normal blocking API.
> But, we are running in a separate task, so with a semaphore / poll we can convert the events into a blocking API.
> Two approaches I can see:
> Simple is to just check if ctx->send_mbuf has enough space. If not, sleep for a while, and check again. Rely on the mongoose task emptying the buffer.
> More complex is to use the mongoose MG_EV_SEND callback (which signifies that some data has been sent), and a semaphore to signal data has been sent. The OvmsSSH::EventHandler and SendCallback could then use that to co-ordinate and avoid sleeping. This is the preferred approach.
> Perhaps this is general enough to be put into a library? An object that could be used to encapsulate the semaphore (initialised to indicate data has been sent), method to indicate data has been sent, and method to wait for that indication. I have a similar problem (although the reverse - receive rather than transmit) in ovms_ota now, and perhaps a generic solution could solve both our problems?
> > On 22 Jan 2018, at 12:34 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> > It doesn’t seem as if there is a good solution. I can see two approaches:
> > Use a MG_F_USER_? flag to mean ‘immediate write’ and extend mg_send to honour that.
> > Add a separate mg_flush() call (used after mg_send) to flush the fd.
> > That static function is going to be a pain to workaround. Perhaps a #include for our C code in mongoose.c?
> > All of this is going to be fighting the event-driven mechanism of Mongoose. Is there another way of doing this?
> > For console_ssh, I think this is where it is:
> > int SendCallback(WOLFSSH* ssh, void* data, uint32_t size, void* ctx)
> >   mg_send((mg_connection*)ctx, (char*)data, size);
> >   return size;
> > Regards, Mark.
> >> On 22 Jan 2018, at 3:17 AM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
> >> Mark,
> >> Well, in turn, I'm sorry for making an API change that was driving you
> >> crazy.  It would have been smarter to add it as a new function even
> >> though that would be duplicating more code.
> >> As the code currently stands, telnet and SSH will work so long as no
> >> operation does more contiguous output than the amount of available
> >> free memory can hold, otherwise an out-of-memory crash will occur.  I
> >> don't know if we consider that an acceptable risk.  Maybe with v3.1
> >> hardware it will be.
> >> Your suggestion to put a new funtion into a separate module is a fine
> >> idea, but that function needs to access some functions in mongoose.c
> >> that are scoped static.  That means we can't entirely avoid modifying
> >> mongoose.
> >>                                                        -- Steve
> >> On Fri, 19 Jan 2018, Mark Webb-Johnson wrote:
> >>> Oops. Sorry. That change broke MQTT. I couldn’t understand what was going on (as mg_send was sending immediately). MQTT works like this:
> >>> void mg_mqtt_publish(struct mg_connection *nc, const char *topic,
> >>>                     uint16_t message_id, int flags, const void *data,
> >>>                     size_t len) {
> >>>  size_t old_len = nc->send_mbuf.len;
> >>>  uint16_t topic_len = htons((uint16_t) strlen(topic));
> >>>  uint16_t message_id_net = htons(message_id);
> >>>  mg_send(nc, &topic_len, 2);
> >>>  mg_send(nc, topic, strlen(topic));
> >>>  if (MG_MQTT_GET_QOS(flags) > 0) {
> >>>    mg_send(nc, &message_id_net, 2);
> >>>  mg_send(nc, data, len);
> >>>  mg_mqtt_prepend_header(nc, MG_MQTT_CMD_PUBLISH, flags,
> >>>                         nc->send_mbuf.len - old_len);
> >>> It uses mg_send a bunch of times, then goes back and modifies the send_mbuf by inserting a header, then finishes so that the actual transmission can occur. Seems a really dumb way to do it, but such is life.
> >>> It was driving me crazy last night, so in the end I just updated mongoose this morning and hey! everything worked. Now I know why :-(
> >>> I see that mg_send_dns_query() does the same (it calls mg_dns_insert_header, which then calls mbuf_insert). Making mg_send transmit immediately would break that as well.
> >>> How about introducing a new mg_send_now() that calls mg_send() then sends the data immediately? Perhaps it could be a separate .h/.c file mongoose_extensions to avoid the change getting overwritten?
> >>> Regards, Mark.
> >>>> On 19 Jan 2018, at 2:36 PM, Stephen Casner <casner at acm.org <mailto:casner at acm.org>> wrote:
> >>>> Mark,
> >>>> The update of Mongoose to v6.10 removed the change I had made so that
> >>>> the mg_send() call would transmit on the network immediately if the
> >>>> socket was ready.  I needed to make that change because we would
> >>>> otherwise run out of RAM with SSH because mg_send() would just buffer
> >>>> everything until the next poll.
> >>>>                                                       -- Steve
> >>>>> I re-worked the ovms_server_* framework, and v2 implementation, to use MONGOOSE.
> >>>>> It seems to be _basically_ working. It can connect/disconnect/etc. Some slight memory saving, but standardising the networking throughout on mongoose should simplify things.
> >>>>> I am seeing problems with transmitting the FEATURES and PARAMETERS sometimes - particularly in low memory situations. I’m still trying to find out why.
> >>>>> Regards, Mark.
> >>>>>> On 17 Jan 2018, at 8:33 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
> >>>>>> This is the issue Michael pointed out. The 'server response is incomplete’ problem with select(). Apologies for this; I am not sure why I didn’t notice it before.
> >>>>>> Gory details are here:
> >>>>>> https://github.com/espressif/esp-idf/issues/1510 <https://github.com/espressif/esp-idf/issues/1510> <https://github.com/espressif/esp-idf/issues/1510 <https://github.com/espressif/esp-idf/issues/1510>>
> >>>>>> I think Espressif implemented requirement this in a bizarre way, likely to break compatibility, but such is life. They did point it out as a ‘breaking change’ (at the bottom of the release notes for 3.0b1):
> >>>>>> https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1 <https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1> <https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1 <https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1>>
> >>>>>> LWIP socket file descriptors now take higher numeric values (via the LWIP LWIP_SOCKET_OFFSET macro). BSD sockets code should mostly work as expected (and, new in V3.0, some standard POSIX functions can now be used with sockets). However any code which assumes a socket file descriptor is always a low numbered integer may need modifying to account for LWIP_SOCKET_OFFSET.
> >>>>>> It sure broke us.
> >>>>>> I’ve made a one-line workaround fix (to ovms_buffer.cpp), and ovms server v2 connections are working again for me. That is committed and pushed already.
> >>>>>> It is kind of messy to have all these different networking implementations in our code base; I intend to move ovms_server_* to mongoose networking over the next few days. That will mean we won’t need a separate task/stack for server connections, and should save us 7KB internal RAM for each connection. Also ovms_ota. But that will have to wait, as I need to get the hardware complete first (some issues with 1.8v vs 3.3v logic on VDD_SDIO of the wrover module and some of our GPIOs), and that is top priority.
> >>>>>> Regards, Mark.
> >>>>>>> On 17 Jan 2018, at 7:05 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com> <mailto:gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>>> wrote:
> >>>>>>> But, I'm not getting much love out of the v2 server.  The connection doesn't appear to be working - "server response is incomplete".  Same error whether on wifi or modem.
> >>>> _______________________________________________
> >>>> OvmsDev mailing list
> >>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
> >>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
