[Ovmsdev] Transition to new esp-idf
Mon Jan 22 12:34:31 HKT 2018
It doesn’t seem as if there is a good solution. I can see two approaches:
Use a MG_F_USER_? flag to mean ‘immediate write’ and extend mg_send to honour that.
Add a separate mg_flush() call (used after mg_send) to flush the fd.
That static function is going to be a pain to workaround. Perhaps a #include for our C code in mongoose.c?
All of this is going to be fighting the event-driven mechanism of Mongoose. Is there another way of doing this?
For console_ssh, I think this is where it is:
int SendCallback(WOLFSSH* ssh, void* data, uint32_t size, void* ctx)
mg_send((mg_connection*)ctx, (char*)data, size);
return size;
Perhaps check add a loop to check if ctx->send_mbuf.len and ctx->send_mbuf.size to see how much space is free. If not enough, then sleep the task (10ms or 100ms?) and try again? Or use MG_EV_SEND to set a semaphore, and pickup on that in the SendCallback? Rely on the fact that mongoose is running in a separate task and will empty the buffer when it can.
> On 22 Jan 2018, at 3:17 AM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> Well, in turn, I'm sorry for making an API change that was driving you
> crazy. It would have been smarter to add it as a new function even
> though that would be duplicating more code.
> As the code currently stands, telnet and SSH will work so long as no
> operation does more contiguous output than the amount of available
> free memory can hold, otherwise an out-of-memory crash will occur. I
> don't know if we consider that an acceptable risk. Maybe with v3.1
> hardware it will be.
> Your suggestion to put a new funtion into a separate module is a fine
> idea, but that function needs to access some functions in mongoose.c
> that are scoped static. That means we can't entirely avoid modifying
> mongoose.
> -- Steve
> On Fri, 19 Jan 2018, Mark Webb-Johnson wrote:
>> Oops. Sorry. That change broke MQTT. I couldn’t understand what was going on (as mg_send was sending immediately). MQTT works like this:
>> void mg_mqtt_publish(struct mg_connection *nc, const char *topic,
>> uint16_t message_id, int flags, const void *data,
>> size_t len) {
>> size_t old_len = nc->send_mbuf.len;
>> uint16_t topic_len = htons((uint16_t) strlen(topic));
>> uint16_t message_id_net = htons(message_id);
>> mg_send(nc, &topic_len, 2);
>> mg_send(nc, topic, strlen(topic));
>> if (MG_MQTT_GET_QOS(flags) > 0) {
>> mg_send(nc, &message_id_net, 2);
>> mg_send(nc, data, len);
>> mg_mqtt_prepend_header(nc, MG_MQTT_CMD_PUBLISH, flags,
>> nc->send_mbuf.len - old_len);
>> It uses mg_send a bunch of times, then goes back and modifies the send_mbuf by inserting a header, then finishes so that the actual transmission can occur. Seems a really dumb way to do it, but such is life.
>> It was driving me crazy last night, so in the end I just updated mongoose this morning and hey! everything worked. Now I know why :-(
>> I see that mg_send_dns_query() does the same (it calls mg_dns_insert_header, which then calls mbuf_insert). Making mg_send transmit immediately would break that as well.
>> How about introducing a new mg_send_now() that calls mg_send() then sends the data immediately? Perhaps it could be a separate .h/.c file mongoose_extensions to avoid the change getting overwritten?
>>> On 19 Jan 2018, at 2:36 PM, Stephen Casner <casner at acm.org> wrote:
>>> Mark,
>>> The update of Mongoose to v6.10 removed the change I had made so that
>>> the mg_send() call would transmit on the network immediately if the
>>> socket was ready. I needed to make that change because we would
>>> otherwise run out of RAM with SSH because mg_send() would just buffer
>>> everything until the next poll.
>>> -- Steve
>>>> I re-worked the ovms_server_* framework, and v2 implementation, to use MONGOOSE.
>>>> It seems to be _basically_ working. It can connect/disconnect/etc. Some slight memory saving, but standardising the networking throughout on mongoose should simplify things.
>>>> I am seeing problems with transmitting the FEATURES and PARAMETERS sometimes - particularly in low memory situations. I’m still trying to find out why.
>>>> Regards, Mark.
>>>>> On 17 Jan 2018, at 8:33 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>>> This is the issue Michael pointed out. The 'server response is incomplete’ problem with select(). Apologies for this; I am not sure why I didn’t notice it before.
>>>>> Gory details are here:
>>>>> https://github.com/espressif/esp-idf/issues/1510 <https://github.com/espressif/esp-idf/issues/1510>
>>>>> I think Espressif implemented requirement this in a bizarre way, likely to break compatibility, but such is life. They did point it out as a ‘breaking change’ (at the bottom of the release notes for 3.0b1):
>>>>> https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1 <https://github.com/espressif/esp-idf/releases/tag/v3.0-rc1>
>>>>> LWIP socket file descriptors now take higher numeric values (via the LWIP LWIP_SOCKET_OFFSET macro). BSD sockets code should mostly work as expected (and, new in V3.0, some standard POSIX functions can now be used with sockets). However any code which assumes a socket file descriptor is always a low numbered integer may need modifying to account for LWIP_SOCKET_OFFSET.
>>>>> It sure broke us.
>>>>> I’ve made a one-line workaround fix (to ovms_buffer.cpp), and ovms server v2 connections are working again for me. That is committed and pushed already.
>>>>> It is kind of messy to have all these different networking implementations in our code base; I intend to move ovms_server_* to mongoose networking over the next few days. That will mean we won’t need a separate task/stack for server connections, and should save us 7KB internal RAM for each connection. Also ovms_ota. But that will have to wait, as I need to get the hardware complete first (some issues with 1.8v vs 3.3v logic on VDD_SDIO of the wrover module and some of our GPIOs), and that is top priority.
>>>>> Regards, Mark.
>>>>>> On 17 Jan 2018, at 7:05 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>>>>>> But, I'm not getting much love out of the v2 server. The connection doesn't appear to be working - "server response is incomplete". Same error whether on wifi or modem.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180122/f4dc2346/attachment.htm>
