[Ovmsdev] Transition to new esp-idf
Mon Jan 15 08:04:32 HKT 2018
All committed and pushed now.
Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
Check
https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
I hope this goes smoothly for you.
commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
Author: Mark Webb-Johnson <mark at webb-johnson.net>
Date:   Mon Jan 15 07:56:45 2018 +0800
    Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
commit 003592d553c881f735fb228b08836a13c306cec3
Merge: e58c5b6 b28db5e
Date:   Mon Jan 15 07:49:13 2018 +0800
    Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
    OVMS developers should now:
    1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
    2] Update XTENSA tools to match version required by Espressif for MASTER branch.
    3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
       been provided. That can be merged/copied to sdkconfig as appropriate.
    4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
       been provided in the next update.
    5] It is recommended that developers perform at least one full 'make flash'
       with this version, to update the bootloader to latest. Note that the
       sdkconfig.default.* files are now set to require bootloader at least v2.1
       (or later), and bootloader v2.0 is no longer supported.
    Enjoy.
> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
> Regards, Mark
>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> wrote:
>> Mark,
>> It looks like you were not able to do the sdkconfig.default and merge
>> as you planned?
>>                                                       -- Steve
>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>> @Steve can you update our master clone to latest from Espressif and
>>>> make sure your stuff is still ok?
>>> I have just now done this.  I had already done a rebase a few days ago
>>> before committing the improved version of the OS changes so I could
>>> issue a pull request.  There were a few commits since then, which I
>>> have now merged.  My code still runs correctly.
>>>> I guess steps for developers will be:
>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>> 2) download and install xtensa build chain to match.
>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>> Sounds right.
>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>> the Merge of the OVMS firmware master branch then.
>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>                                                       -- Steve
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180115/6d77d6a5/attachment.htm>
