[Ovmsdev] Transition to new esp-idf
Mon Jan 15 07:25:34 HKT 2018
Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> It looks like you were not able to do the sdkconfig.default and merge
> as you planned?
> -- Steve
>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>> @Steve can you update our master clone to latest from Espressif and
>>> make sure your stuff is still ok?
>> I have just now done this. I had already done a rebase a few days ago
>> before committing the improved version of the OS changes so I could
>> issue a pull request. There were a few commits since then, which I
>> have now merged. My code still runs correctly.
>>> I guess steps for developers will be:
>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>> 2) download and install xtensa build chain to match.
>>> 3) update OVMS master, make clean, check menu config, then build and play.
>> Sounds right.
>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>> the Merge of the OVMS firmware master branch then.
>> I'll be sleeping then, so you can go ahead and do the merge.
>> -- Steve
