[Ovmsdev] <enter> not working with vfs edit?
Greg D
gregd2350 at gmail.com
Fri Jan 12 13:53:23 HKT 2018
I'm still on v2.1... Good thing to watch out for, however.
Greg
On January 11, 2018 9:51:32 PM PST, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>Maybe the recent change for IDF v3 where Espressif messed around with
>CRLF.
>2f0c9f0 Translate CR or CRLF to LF on async console for microrl
>$ git diff fc69e3e 2f0c9f0
>diff --git a/vehicle/OVMS.V3/main/console_async.cpp
>b/vehicle/OVMS.V3/main/console_async.cpp
>index e7110fa..dd3df4a 100644
>--- a/vehicle/OVMS.V3/main/console_async.cpp
>+++ b/vehicle/OVMS.V3/main/console_async.cpp
>@@ -155,6 +155,24 @@ void ConsoleAsync::HandleDeviceEvent(void* pEvent)
> if (buffered_size > 0)
>int len = uart_read_bytes(EX_UART_NUM, data, BUF_SIZE, 100 /
>portTICK_RATE_MS);
>+ // Translate CR (Enter) from montitor into \n for microrl
>+ bool found = false;
>+ for (int i = 0; i < len; ++i)
>+ if (found && data[i] == '\n')
>+ for (int j = i+1; j < len; ++j)
>+ data[j-1] = data[j];
>+ --len;
>+ continue;
>+ found = false;
>+ if (data[i] == '\r')
>+ data[i] = '\n';
>+ found = true;
> ProcessChars((char*)data, len);
> break;
>@@ -171,7 +189,7 @@ void ConsoleAsync::HandleDeviceEvent(void* pEvent)
> uart_flush(EX_UART_NUM);
> break;
> default:
>- ESP_LOGI(TAG, "uart event type: %d\n", event.type);
>+ ESP_LOGE(TAG, "uart event type: %d", event.type);
> break;
>That should only affect the ASYNC console, I think. It converts
>CR/LF/CRLF -> LF. Maybe the enum KEY_ACTION in openemacs (vfsedit
>component) needs to change?
>Fix is probably to add a NL=10 to KEY_ACTION and then to treat NL or
>ENTER as the same in the editor_process_keypress. My build environment
>is all switched to v3 at the moment, so hard for me to test (as IDF v3
>does things differently). I’ve made the fix in the for-master branch,
>and it seems to work for me.
>$ git diff --staged
>--- a/vehicle/OVMS.V3/components/vfsedit/src/openemacs.c
>+++ b/vehicle/OVMS.V3/components/vfsedit/src/openemacs.c
>@@ -71,7 +71,7 @@ struct append_buffer
> enum KEY_ACTION
>CTRL_A = 1, CTRL_B = 2, CTRL_C = 3, CTRL_D = 4, CTRL_E = 5, CTRL_F = 6,
>BACKSPACE = 8, TAB = 9,
>- CTRL_K = 11, CTRL_L = 12, ENTER = 13, CTRL_N = 14, CTRL_P = 16,
>CTRL_Q = 17, CTRL_R = 18,
>+ NL = 10, CTRL_K = 11, CTRL_L = 12, ENTER = 13, CTRL_N = 14, CTRL_P =
>16, CTRL_Q = 17, CTRL_R = 18,
>CTRL_S = 19, CTRL_U = 21, CTRL_V = 22, CTRL_X = 24, CTRL_Y = 25, CTRL_Z
>= 26, ESC = 27,
> FORWARD_DELETE = 127,
> // The following are just soft codes, not really reported by the
>@@ -1297,7 +1297,7 @@ bool editor_process_keypress(struct editor_state*
>E, int k)
> // Quoted insert - insert character as-is
> editor_insert_char(E,key);
>- else if (key == ENTER)
>+ else if (key == ENTER || key == NL)
> editor_insert_newline(E);
>I just made the fix also in the master branch, but haven’t tested.
>Regards, Mark.
>> On 12 Jan 2018, at 1:36 PM, Greg D. <gregd2350 at gmail.com> wrote:
>> Is anyone else having trouble with the vfs editor? I can't seem to
>> enter a newline anymore. The status line at the bottom complains of
>an
>> unknown command 10 (presumably control-J). If I try an explicit
>> control-M, it says the same.
>> Did I fat-finger something in my config (I removed SSH, Telnet, and
>> several other items to save RAM recently), or did something else
>> change? This is with two different terminals - make monitor on the
>> development laptop, and putty on my in-car Raspberry Pi.
>> Greg
Sent from my Android device with K-9 Mail. Please excuse my brevity.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180111/66288085/attachment.htm>
