[Ovmsdev] Boot Loop
Tom Parker tom at carrott.org
Sun Jan 21 17:25:00 HKT 2018
The following script reliably puts the ovms into a boot loop:
vfs mkdir /store/events
vfs mkdir /store/events/system.start
vfs rm /store/events/system.start/startmeup
vfs append "log level debug" /store/events/system.start/startmeup
vfs append "server v2 start" /store/events/system.start/startmeup
Press the reset button and it loops with the log below.
It can be fixed by "make erase_flash flash" but this obviously erases
your config.
If you swap the order of the two commands in the script, or if the
script only contains on or other of the commands then it doesn't boot loop.
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x1f (SPI_FAST_FLASH_BOOT)
configsip: 156795334, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4456
load:0x40078000,len:0
ho 12 tail 0 room 4
load:0x40078000,len:12988
entry 0x40078d14
I (168) ovms_main: Set default logging level for * to WARN
OVMS > ***ERROR*** A stack overflow in task Housekeeping has been detected.
abort() was called at PC 0x4008a824 on core 1
0x4008a824: vApplicationStackOverflowHook at
/home/ubuntu/esp/esp-idf/components/esp32/./panic.c:572
Backtrace: 0x4008a70c:0x3ffcea70 0x4008a80b:0x3ffcea90
0x4008a824:0x3ffceab0 0x4008791c:0x3ffcead0 0x4008921c:0x3ffceaf0
0x400891d2:0x632e6769
0x4008a70c: invoke_abort at
0x4008a80b: abort at /home/ubuntu/esp/esp-idf/components/esp32/./panic.c:572
0x4008791c: vTaskSwitchContext at
/home/ubuntu/esp/esp-idf/components/freertos/./tasks.c:4837
0x4008921c: _frxt_dispatch at
/home/ubuntu/esp/esp-idf/components/freertos/./portasm.S:406
0x400891d2: _frxt_int_exit at
/home/ubuntu/esp/esp-idf/components/freertos/./portasm.S:206
Rebooting...
