[Ovmsdev] DB29 expansion GPIO
Sat Jan 20 16:12:36 HKT 2018
The EGPIOs (plus the rest) go to the expansion socket (modem, etc). Also available there are the GEP lines (which are externally exposed).
The idea was that expansion boards take the EGPIO lines (plus whatever else they need), do their stuff, and expose their output on the GEP pins of the DB26.
In general, I would recommend staying away from EXP_1 and EXP_2 as those are directly on the ESP32 and are thus very valuable (the last two unused pins).
I guess if you wanted to directly expose EGPIO lines as GEP, then all that is needed would be internal jumper wires on the internal expansion connector.
> On 20 Jan 2018, at 3:55 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> I'm currently planning the SimpleConsole connection to v3.x.
> Given the schemes, it seems the DB29 connector does not offer direct connections to the GPIO lines -- is that correct?
> GEP_1…7 are not the GPIO lines but currently unused expansion pins on the piggy board connectors?
> So without additional expansion boards only EXP_1 & _2 are available as general purpose IO pins on the connector?
> Thanks,
