[Ovmsdev] Missing File?
Fri Jan 19 19:37:03 HKT 2018
Can you check ‘git branch’. Make sure you are on ‘master’ branch (not 2.1).
Also make sure you’ve done the Submodule update command.
> On 19 Jan 2018, at 6:58 PM, Tom Parker <tom at carrott.org> wrote:
> I just updated to the latest IDF and I'm getting this error:
> CXX build/main/ovms_module.o
> /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:40:28: fatal error: esp_heap_debug.h: No such file or directory
> compilation terminated.
> /home/ubuntu/esp/esp-idf/make/component_wrapper.mk:273: recipe for target 'ovms_module.o' failed
> make[1]: *** [ovms_module.o] Error 1
> If I delete line 40 of ovms_module.cpp to avoid trying to import this file then everything compiles.
> Well it compiles if I turn off the mdns server in menuconfig. If I leave that as the sdkconfig.default.hw30 values then I get this error:
> CXX build/ovms_mdns/src/ovms_mdns.o
> In file included from /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_mdns/src/ovms_mdns.cpp:36:0:
> /vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_mdns/src/ovms_mdns.h:48:5: error: 'mdns_server_t' does not name a type
>      mdns_server_t *m_mdns;
