[Ovmsdev] Missing File?
Tom Parker tom at carrott.org
Fri Jan 19 18:58:48 HKT 2018
I just updated to the latest IDF and I'm getting this error:
CXX build/main/ovms_module.o
/vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/main/./ovms_module.cpp:40:28:
fatal error: esp_heap_debug.h: No such file or directory
compilation terminated.
/home/ubuntu/esp/esp-idf/make/component_wrapper.mk:273: recipe for
target 'ovms_module.o' failed
make[1]: *** [ovms_module.o] Error 1
If I delete line 40 of ovms_module.cpp to avoid trying to import this
file then everything compiles.
Well it compiles if I turn off the mdns server in menuconfig. If I leave
that as the sdkconfig.default.hw30 values then I get this error:
CXX build/ovms_mdns/src/ovms_mdns.o
In file included from
/vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_mdns/src/ovms_mdns.cpp:36:0:
/vagrant/Open-Vehicle-Monitoring-System-3/vehicle/OVMS.V3/components/ovms_mdns/src/ovms_mdns.h:48:5:
error: 'mdns_server_t' does not name a type
      mdns_server_t *m_mdns;
