[Ovmsdev] Transition to new esp-idf
Wed Jan 17 10:28:35 HKT 2018
Stephen Casner wrote:
> On Tue, 16 Jan 2018, Greg D. wrote:
>> I notice that the 3.0 code base is also a lot less chatty than the 2.1.  Almost
>> spooky...
> Are you referring to the fact that the default log level has changed
> from INFO to WARN so all those many INFO logs are not longer shown?
> That is a config setting you can change.
Yes, I understand.  But, even the boot-up dialog is short, and until you
change things, it's like, hello? Did it just hang?
It just caught me by surprise, I guess.
Greg
