On Tue, 16 Jan 2018, Greg D. wrote:
> I notice that the 3.0 code base is also a lot less chatty than the 2.1. Almost
> spooky...
Are you referring to the fact that the default log level has changed
from INFO to WARN so all those many INFO logs are not longer shown?
That is a config setting you can change.
