[Ovmsdev] Transition to new esp-idf
Wed Jan 17 00:59:34 HKT 2018
Bluetooth is disabled. Has been for a while, I don't see a chance to enable it with the 3.0 module.
I've also disabled Javascript support (duktape), Wolf, the web server and MDNS and the OBD2ECU. Telnet is enabled as I sometimes use that parallel to the async
console.
That config gives me…
OVMS > module memory
Free 8-bit 117364/286352, 32-bit 17972/45144, SPIRAM 0/0
…after reboot (without SD card), and with Wifi, modem, Twizy & server v2 running & connected…
Free 8-bit 23436/286352, 32-bit 17972/45144, SPIRAM 0/0
…when idle, will drop further with transmissions pending etc.
Opening a telnet session then results in:
Free 8-bit 18372/286352, 32-bit 17972/45144, SPIRAM 0/0
…and still stable.
Am 16.01.2018 um 01:11 schrieb Mark Webb-Johnson:
> I’m seeing this:
> Free 8-bit 79812/282268, 32-bit 17816/44988, SPIRAM 0/0
> OVMS > sd unmount
> Unmounted SD CARD
> Free 8-bit 107768/282268, 32-bit 17816/44988, SPIRAM 0/0
> --Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM
> Tmr Svc 0 20 0 0 -4 -27780 +0 +0
> I guess it is FAT fs stuff, but we use that for /store as well so not sure why so much. I will look into it.
> With wifi client, ovms server v2, tesla roadster vehicle module, I get this:
> Free 8-bit 54224/282268, 32-bit 17816/44988, SPIRAM 0/0
> With the OBDII HUD, that drops to 45KB.
> Do you have bluetooth enabled (in menuconfig)?
>> On 16 Jan 2018, at 3:35 AM, Michael Balzer <dexter at expeedo.de> wrote:
>> I've found the missing RAM. It's allocated for the SD card:
>> I (34235) sdcard: SD CARD has been inserted. Auto-mounting...
>> Free 8-bit 89348/286352, 32-bit 17972/45144, SPIRAM 0/0
>> Tmr Svc 4 27804 0 0 +4 +27804 +0 +0
>> I (68065) sdcard: SD CARD has been removed.
>> Free 8-bit 117332/286352, 32-bit 17972/45144, SPIRAM 0/0
>> Tmr Svc 0 12 0 0 -4 -27792 +0 +0
>> …again…
>> I (114985) sdcard: SD CARD has been inserted. Auto-mounting...
>> Tmr Svc 4 27804 0 0 +4 +27792 +0 +0
>> E (141205) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
>> E (141205) diskio_sdmmc: sdmmc_read_blocks failed (263)
>> I (141515) sdcard: SD CARD has been removed.
>> Btw, I think the RAM usage of the telnet server is also higher than before:
>> OVMS > wifi mode client
>> Starting WIFI as a client for any defined SSID
>> I (380175) wifi: wifi firmware version: 403db1d
>> I (380175) wifi: config NVS flash: enabled
>> I (380175) wifi: config nano formating: disabled
>> I (380185) wifi: Init dynamic tx buffer num: 16
>> I (380185) wifi: Init data frame dynamic rx buffer num: 16
>> I (380185) wifi: Init management frame dynamic rx buffer num: 16
>> I (380185) wifi: wifi driver task: 3ffe3db4, prio:23, stack:4096
>> I (380185) wifi: Init static rx buffer num: 4
>> I (380185) wifi: Init dynamic rx buffer num: 16
>> I (380195) wifi: wifi power manager task: 0x3ffe846c prio: 21 stack: 2560
>> I (380195) wifi: mode : sta (30:ae:a4:37:25:88)
>> W (390205) wifi: incorrect scan type: 1073534024
>> I (392615) esp32wifi: Found SSID devolo-f4068d73a03e - trying to connect
>> I (393945) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
>> I (394595) wifi: state: init -> auth (b0)
>> I (394605) wifi: state: auth -> assoc (0)
>> I (394605) wifi: state: assoc -> run (10)
>> I (394625) wifi: connected with devolo-f4068d73a03e, channel 11
>> I (394665) esp32wifi: WiFi UP with SSID: devolo-f4068d73a03e, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.101, mask: 255.255.255.0, gw: 192.168.2.1
>> I (394665) telnet: Launching Telnet Server
>> I (397615) wifi: pm start, type:0
>> Free 8-bit 89700/286352, 32-bit 17972/45144, SPIRAM 0/0
>> tiT 128 716 0 0 +0 +484 +0 +0
>> AsyncConsole 0 16552 26404 0 +0 +16356 +0 +0
>> NetManTask 8 488 0 0 +8 +488 +0 +0
>> wifi 0 1600 0 0 +0 +1600 +0 +0
>> eventTask 0 7564 0 0 +0 +7564 +0 +0
>> …but I'm not sure about that, haven't tested that in a while.
>> So, SD cards now work, and I'll not be able to use them due to the RAM usage… :(
>> Am 15.01.2018 um 19:21 schrieb Michael Balzer:
>>> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
>>> And…
>>> OVMS > sd status
>>> SD CARD is inserted
>>> Type: SDHC/SDXC
>>> Speed: default speed
>>> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
>>> SCR: sd_spec=2, bus_width=5
>>> → me too (the minion) :)
>>> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
>>> After loading just the Twizy module & the v2 server, I'm now again down to…
>>> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
>>> …so it crashes as soon as it needs to actually do anything, like sending a notification.
>>> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
>>> I'll now check the config again for any more options to save RAM…
>>> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>>>> In order for the the "module memory" and "module tasks" commands to
>>>> work, the configuration needs to be changed from the sdk.default.hw30
>>>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>>>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>>>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled. I have
>>>> attached a diff for the sdkconfig. That diff also includes a section
>>>> for enabling telnet, which some of you may be using.
>>>> Please also note that in this revised implementation of "module
>>>> memory" the block address is now the address that is returned from
>>>> malloc, not the address of the header that precedes it, and the length
>>>> of the block is now exclusive of the debugging overhead.
>>>> -- Steve
>>>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>>>> All committed and pushed now.
>>>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>>>> Check
>>>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>>>> I hope this goes smoothly for you.
>>>>> Regards, Mark.
>>>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net>
>>>>> Date: Mon Jan 15 07:56:45 2018 +0800
>>>>> Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>>>> Merge: e58c5b6 b28db5e
>>>>> Date: Mon Jan 15 07:49:13 2018 +0800
>>>>> Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>>>> OVMS developers should now:
>>>>> 1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>>>> 2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>>>> 3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>>>> been provided. That can be merged/copied to sdkconfig as appropriate.
>>>>> 4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>>>> been provided in the next update.
>>>>> 5] It is recommended that developers perform at least one full 'make flash'
>>>>> with this version, to update the bootloader to latest. Note that the
>>>>> sdkconfig.default.* files are now set to require bootloader at least v2.1
>>>>> (or later), and bootloader v2.0 is no longer supported.
>>>>> Enjoy.
>>>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net> wrote:
>>>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>>>> Regards, Mark
>>>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> <mailto:casner at acm.org> wrote:
>>>>>>> Mark,
>>>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>>>> as you planned?
>>>>>>> -- Steve
>>>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>>>> make sure your stuff is still ok?
>>>>>>>> I have just now done this. I had already done a rebase a few days ago
>>>>>>>> before committing the improved version of the OS changes so I could
>>>>>>>> issue a pull request. There were a few commits since then, which I
>>>>>>>> have now merged. My code still runs correctly.
>>>>>>>>> I guess steps for developers will be:
>>>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>>>> Sounds right.
>>>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>>>> -- Steve
>>>>>>> OvmsDev mailing list
>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180116/47c5e11d/attachment-0001.html>
