[Ovmsdev] Transition to new esp-idf
Tue Jan 16 08:11:33 HKT 2018
I’m seeing this:
OVMS > module memory
Free 8-bit 79812/282268, 32-bit 17816/44988, SPIRAM 0/0
OVMS > sd unmount
Unmounted SD CARD
Free 8-bit 107768/282268, 32-bit 17816/44988, SPIRAM 0/0
--Task-- Total DRAM D/IRAM IRAM SPIRAM +/- DRAM D/IRAM IRAM SPIRAM
Tmr Svc 0 20 0 0 -4 -27780 +0 +0
I guess it is FAT fs stuff, but we use that for /store as well so not sure why so much. I will look into it.
With wifi client, ovms server v2, tesla roadster vehicle module, I get this:
Free 8-bit 54224/282268, 32-bit 17816/44988, SPIRAM 0/0
With the OBDII HUD, that drops to 45KB.
Do you have bluetooth enabled (in menuconfig)?
> On 16 Jan 2018, at 3:35 AM, Michael Balzer <dexter at expeedo.de> wrote:
> I've found the missing RAM. It's allocated for the SD card:
> Free 8-bit 117364/286352, 32-bit 17972/45144, SPIRAM 0/0
> I (34235) sdcard: SD CARD has been inserted. Auto-mounting...
> Free 8-bit 89348/286352, 32-bit 17972/45144, SPIRAM 0/0
> Tmr Svc 4 27804 0 0 +4 +27804 +0 +0
> I (68065) sdcard: SD CARD has been removed.
> Free 8-bit 117332/286352, 32-bit 17972/45144, SPIRAM 0/0
> Tmr Svc 0 12 0 0 -4 -27792 +0 +0
> …again…
> I (114985) sdcard: SD CARD has been inserted. Auto-mounting...
> Tmr Svc 4 27804 0 0 +4 +27792 +0 +0
> E (141205) sdmmc_cmd: sdmmc_read_sectors_dma: sdmmc_send_cmd returned 0x107
> E (141205) diskio_sdmmc: sdmmc_read_blocks failed (263)
> I (141515) sdcard: SD CARD has been removed.
> Btw, I think the RAM usage of the telnet server is also higher than before:
> OVMS > wifi mode client
> Starting WIFI as a client for any defined SSID
> I (380175) wifi: wifi firmware version: 403db1d
> I (380175) wifi: config NVS flash: enabled
> I (380175) wifi: config nano formating: disabled
> I (380185) wifi: Init dynamic tx buffer num: 16
> I (380185) wifi: Init data frame dynamic rx buffer num: 16
> I (380185) wifi: Init management frame dynamic rx buffer num: 16
> I (380185) wifi: wifi driver task: 3ffe3db4, prio:23, stack:4096
> I (380185) wifi: Init static rx buffer num: 4
> I (380185) wifi: Init dynamic rx buffer num: 16
> I (380195) wifi: wifi power manager task: 0x3ffe846c prio: 21 stack: 2560
> I (380195) wifi: mode : sta (30:ae:a4:37:25:88)
> W (390205) wifi: incorrect scan type: 1073534024
> I (392615) esp32wifi: Found SSID devolo-f4068d73a03e - trying to connect
> I (393945) wifi: n:11 2, o:1 0, ap:255 255, sta:11 2, prof:1
> I (394595) wifi: state: init -> auth (b0)
> I (394605) wifi: state: auth -> assoc (0)
> I (394605) wifi: state: assoc -> run (10)
> I (394625) wifi: connected with devolo-f4068d73a03e, channel 11
> I (394665) esp32wifi: WiFi UP with SSID: devolo-f4068d73a03e, MAC: 30:ae:a4:37:25:88, IP: 192.168.2.101, mask: 255.255.255.0, gw: 192.168.2.1
> I (394665) telnet: Launching Telnet Server
> I (397615) wifi: pm start, type:0
> Free 8-bit 89700/286352, 32-bit 17972/45144, SPIRAM 0/0
> tiT 128 716 0 0 +0 +484 +0 +0
> AsyncConsole 0 16552 26404 0 +0 +16356 +0 +0
> NetManTask 8 488 0 0 +8 +488 +0 +0
> wifi 0 1600 0 0 +0 +1600 +0 +0
> eventTask 0 7564 0 0 +0 +7564 +0 +0
> …but I'm not sure about that, haven't tested that in a while.
> So, SD cards now work, and I'll not be able to use them due to the RAM usage… :(
> Am 15.01.2018 um 19:21 schrieb Michael Balzer:
>> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
>> And…
>> OVMS > sd status
>> SD CARD is inserted
>> Type: SDHC/SDXC
>> Speed: default speed
>> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
>> SCR: sd_spec=2, bus_width=5
>> → me too (the minion) :)
>> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
>> After loading just the Twizy module & the v2 server, I'm now again down to…
>> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
>> …so it crashes as soon as it needs to actually do anything, like sending a notification.
>> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
>> I'll now check the config again for any more options to save RAM…
>> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>>> In order for the the "module memory" and "module tasks" commands to
>>> work, the configuration needs to be changed from the sdk.default.hw30
>>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled. I have
>>> attached a diff for the sdkconfig. That diff also includes a section
>>> for enabling telnet, which some of you may be using.
>>> Please also note that in this revised implementation of "module
>>> memory" the block address is now the address that is returned from
>>> malloc, not the address of the header that precedes it, and the length
>>> of the block is now exclusive of the debugging overhead.
>>> -- Steve
>>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>>> All committed and pushed now.
>>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>>> Check
>>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain> <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>>> I hope this goes smoothly for you.
>>>> Regards, Mark.
>>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>>> Author: Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net>
>>>> Date: Mon Jan 15 07:56:45 2018 +0800
>>>> Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>>> Merge: e58c5b6 b28db5e
>>>> Date: Mon Jan 15 07:49:13 2018 +0800
>>>> Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>>> OVMS developers should now:
>>>> 1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>>> 2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>>> 3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>>> been provided. That can be merged/copied to sdkconfig as appropriate.
>>>> 4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>>> been provided in the next update.
>>>> 5] It is recommended that developers perform at least one full 'make flash'
>>>> with this version, to update the bootloader to latest. Note that the
>>>> sdkconfig.default.* files are now set to require bootloader at least v2.1
>>>> (or later), and bootloader v2.0 is no longer supported.
>>>> Enjoy.
>>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> <mailto:mark at webb-johnson.net> wrote:
>>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>>> Regards, Mark
>>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> <mailto:casner at acm.org> wrote:
>>>>>> Mark,
>>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>>> as you planned?
>>>>>> -- Steve
>>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>>> make sure your stuff is still ok?
>>>>>>> I have just now done this. I had already done a rebase a few days ago
>>>>>>> before committing the improved version of the OS changes so I could
>>>>>>> issue a pull request. There were a few commits since then, which I
>>>>>>> have now merged. My code still runs correctly.
>>>>>>>> I guess steps for developers will be:
>>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>>> Sounds right.
>>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>>> -- Steve
>>>>>> OvmsDev mailing list
>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180116/f5772218/attachment-0001.html>
