[Ovmsdev] Transition to new esp-idf
Tue Jan 16 05:41:36 HKT 2018
More issues:
a) changing log levels only works without specifying a tag
b) getting frequent logs like these:
I (8324105) ovms-server-v2: Server response is incomplete (0 bytes)
E (8324105) ovms-server-v2: Status: Error: Server response is incomplete
…resulting in a server reconnect.
V (8415335) simcom: rx: f9 05 ff 33 24 47 4e 47 4e 53 2c 2c 2c 2c 2c 2c | ...3$GNGNS,,,,,,
V (8415335) simcom: rx: 4e 4e 2c 2c 2c 2c 2c 2c 2a 35 33 0d 0a 84 f9 f9 | NN,,,,,,*53.....
V (8415335) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
V (8415345) gsm-mux: ChanProcessFrame(CHAN=1, ADDR=05, CTRL=ff, LEN=28, IFP=3)
V (8415355) gsm-nmea: IncomingLine: $GNGNS,,,,,,NN,,,,,,*53
V (8415355) simcom: rx: 05 ff 33 24 47 50 52 4d 43 2c 2c 56 2c 2c 2c 2c | ..3$GPRMC,,V,,,,
V (8415355) simcom: rx: 2c 2c 2c 2c 2c 2c 4e 2a 35 33 0d 0a 84 f9 | ,,,,,,N*53....
V (8415355) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
V (8415355) gsm-mux: ChanProcessFrame(CHAN=1, ADDR=05, CTRL=ff, LEN=28, IFP=3)
V (8415355) gsm-nmea: IncomingLine: $GPRMC,,V,,,,,,,,,,N*53
V (8416335) simcom: rx: f9 05 ff 33 24 47 4e 47 4e 53 2c 2c 2c 2c 2c 2c | ...3$GNGNS,,,,,,
V (8416335) simcom: rx: 4e 4e 2c 2c 2c 2c 2c 2c 2a 35 33 0d 0a 84 f9 f9 | NN,,,,,,*53.....
V (8416335) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
V (8416345) gsm-mux: ChanProcessFrame(CHAN=1, ADDR=05, CTRL=ff, LEN=28, IFP=3)
V (8416345) gsm-nmea: IncomingLine: $GNGNS,,,,,,NN,,,,,,*53
V (8416345) simcom: rx: 05 ff 33 24 47 50 52 4d 43 2c 2c 56 2c 2c 2c 2c | ..3$GPRMC,,V,,,,
V (8416345) simcom: rx: 2c 2c 2c 2c 2c 2c 4e 2a 35 33 0d 0a 84 f9 | ,,,,,,N*53....
V (8416345) gsm-mux: ProcessFrame(CHAN=1, ADDR=05, CTRL=ff, FCS=84, LEN=31)
V (8416345) gsm-nmea: IncomingLine: $GPRMC,,V,,,,,,,,,,N*53
*I (8416515) ovms-server-v2: Server response is incomplete (0 bytes)*
V (8416515) gsm-ppp: tx: 7e 21 45 00 00 28 00 6c 00 00 ff 06 e5 3c 0a aa | ~!E..(.l.....<..
V (8416515) gsm-ppp: tx: c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 4d d6 3f f5 | ....K.. at ....M.?.
V (8416515) gsm-ppp: tx: f4 17 50 11 16 2a 38 8b 00 00 b9 4c 7e | ..P..*8....L~
V (8416515) simcom: tx: f9 09 ff 5b 7e 21 45 00 00 28 00 6c 00 00 ff 06 | ...[~!E..(.l....
V (8416515) simcom: tx: e5 3c 0a aa c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 | .<......K.. at ....
V (8416515) simcom: tx: 4d d6 3f f5 f4 17 50 11 16 2a 38 8b 00 00 b9 4c | M.?...P..*8....L
V (8416515) simcom: tx: 7e 45 f9 | ~E.
*E (8416525) ovms-server-v2: Status: Error: Server response is incomplete*
V (8417315) simcom: rx: f9 09 ff 5b 7e 21 45 00 00 28 b7 32 40 00 2d 06 | ...[~!E..(.2 at .-.
V (8417315) simcom: rx: c0 76 bc 8a 4b e5 0a aa c3 0d 1a d3 ee 40 3f f5 | .v..K........@?.
V (8417315) simcom: rx: f4 17 00 00 4d d7 50 11 39 08 15 ac 00 00 f2 89 | ....M.P.9.......
V (8417325) simcom: rx: 7e 45 f9 | ~E.
V (8417325) gsm-mux: ProcessFrame(CHAN=2, ADDR=09, CTRL=ff, FCS=45, LEN=51)
V (8417325) gsm-mux: ChanProcessFrame(CHAN=2, ADDR=09, CTRL=ff, LEN=48, IFP=3)
V (8417325) gsm-ppp: rx: 7e 21 45 00 00 28 b7 32 40 00 2d 06 c0 76 bc 8a | ~!E..(.2 at .-..v..
V (8417325) gsm-ppp: rx: 4b e5 0a aa c3 0d 1a d3 ee 40 3f f5 f4 17 00 00 | K........@?.....
V (8417335) gsm-ppp: rx: 4d d7 50 11 39 08 15 ac 00 00 f2 89 7e | M.P.9.......~
V (8417335) gsm-ppp: tx: 7e 21 45 00 00 28 00 6d 00 00 ff 06 e5 3b 0a aa | ~!E..(.m.....;..
V (8417335) gsm-ppp: tx: c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 4d d7 3f f5 | ....K.. at ....M.?.
V (8417335) gsm-ppp: tx: f4 18 50 10 16 29 38 8b 00 00 a9 af 7e | ..P..)8.....~
V (8417335) simcom: tx: f9 09 ff 5b 7e 21 45 00 00 28 00 6d 00 00 ff 06 | ...[~!E..(.m....
V (8417335) simcom: tx: e5 3b 0a aa c3 0d bc 8a 4b e5 ee 40 1a d3 00 00 | .;......K.. at ....
V (8417335) simcom: tx: 4d d7 3f f5 f4 18 50 10 16 29 38 8b 00 00 a9 af | M.?...P..)8.....
V (8417335) simcom: tx: 7e 45 f9 | ~E.
V (8417345) simcom: rx: f9 05 ff 33 24 47 4e 47 4e 53 2c 2c 2c 2c 2c 2c | ...3$GNGNS,,,,,,
V (8417345) simcom: rx: 4e 4e 2c 2c 2c 2c 2c 2c 2a 35 33 0d 0a 84 f9 f9 | NN,,,,,,*53.....
Am 15.01.2018 um 19:21 schrieb Michael Balzer:
> Transition went fine. "make flash" didn't even erase "/store", I had expected that to happen, good to know.
> And…
> OVMS > sd status
> SD CARD is inserted
> Type: SDHC/SDXC
> Speed: default speed
> CSD: ver=1, sector_size=512, capacity=62333952 read_bl_len=9
> SCR: sd_spec=2, bus_width=5
> → me too (the minion) :)
> BUT… after reconfiguration to the same components as before, I'm now missing about 30-40 KB of free RAM.
> After loading just the Twizy module & the v2 server, I'm now again down to…
> OVMS > module memory
> Free 8-bit 2632/286352, 32-bit 17972/45144, SPIRAM 0/0
> …so it crashes as soon as it needs to actually do anything, like sending a notification.
> This is without any of the new CAN logging stuff yet, that's stashed away for the transition.
> I'll now check the config again for any more options to save RAM…
> Am 15.01.2018 um 06:48 schrieb Stephen Casner:
>> In order for the the "module memory" and "module tasks" commands to
>> work, the configuration needs to be changed from the sdk.default.hw30
>> that Mark just provided. CONFIG_FREERTOS_USE_TRACE_FACILITY needs to
>> be enabled, CONFIG_HEAP_POISONING must be enabled (LIGHT or
>> COMPREHENSIVE), and CONFIG_HEAP_TASK_TRACKING must be enabled. I have
>> attached a diff for the sdkconfig. That diff also includes a section
>> for enabling telnet, which some of you may be using.
>> Please also note that in this revised implementation of "module
>> memory" the block address is now the address that is returned from
>> malloc, not the address of the header that precedes it, and the length
>> of the block is now exclusive of the debugging overhead.
>> -- Steve
>> On Mon, 15 Jan 2018, Mark Webb-Johnson wrote:
>>> All committed and pushed now.
>>> Developers MUST now update their ESP IDF and XTENSA build tools to use this new build. They should also compare sdkconfig and sdkconfig.defaults.hw30 to verify differences. I also suggest you do a ‘make flash’ (rather than ‘make app-flash’) at least once, to update the bootloader to the latest (as bootloaders before v2.1 are no longer supported).
>>> Check
>>> https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain <https://esp-idf.readthedocs.io/en/latest/get-started/index.html#setup-toolchain>
>>> to see the version of XTENSA toolchain required for latest Espressif IDF ‘master’ builds. As of this writing, it is 1.22.0-80-g6c4433a-5.2.0.
>>> I hope this goes smoothly for you.
>>> commit dfcc658557fc480bcccb09b23bc24399bb6e7497 (HEAD -> master, origin/master, origin/HEAD)
>>> Author: Mark Webb-Johnson <mark at webb-johnson.net>
>>> Date: Mon Jan 15 07:56:45 2018 +0800
>>> Provide a sdkconfig.default.hw31 for OVMS v3.1 hardware
>>> commit 003592d553c881f735fb228b08836a13c306cec3
>>> Merge: e58c5b6 b28db5e
>>> Date: Mon Jan 15 07:49:13 2018 +0800
>>> Merge branch 'for-master'. This requires ESP-IDF v3.0 support:
>>> OVMS developers should now:
>>> 1] Pull the latest OpenVehicles IDF, and checkout MASTER branch.
>>> 2] Update XTENSA tools to match version required by Espressif for MASTER branch.
>>> 3] For ovms hardware v3.0, a sdkconfig default file sdkconfig.default.hw30 has
>>> been provided. That can be merged/copied to sdkconfig as appropriate.
>>> 4] For ovms hardware v3.1, a sdkconfig default file sdkconfig.default.hw31 will
>>> been provided in the next update.
>>> 5] It is recommended that developers perform at least one full 'make flash'
>>> with this version, to update the bootloader to latest. Note that the
>>> sdkconfig.default.* files are now set to require bootloader at least v2.1
>>> (or later), and bootloader v2.0 is no longer supported.
>>> Enjoy.
>>>> On 15 Jan 2018, at 7:25 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>>> Merge is ok, but triple checking a couple of things. Should be committed and pushed within the next half hour.
>>>> Regards, Mark
>>>>> On 15 Jan 2018, at 1:09 AM, Stephen Casner <casner at acm.org> wrote:
>>>>> Mark,
>>>>> It looks like you were not able to do the sdkconfig.default and merge
>>>>> as you planned?
>>>>> -- Steve
>>>>>> On Fri, 12 Jan 2018, Stephen Casner wrote:
>>>>>>> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
>>>>>>> @Steve can you update our master clone to latest from Espressif and
>>>>>>> make sure your stuff is still ok?
>>>>>> I have just now done this. I had already done a rebase a few days ago
>>>>>> before committing the improved version of the OS changes so I could
>>>>>> issue a pull request. There were a few commits since then, which I
>>>>>> have now merged. My code still runs correctly.
>>>>>>> I guess steps for developers will be:
>>>>>>> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
>>>>>>> 2) download and install xtensa build chain to match.
>>>>>>> 3) update OVMS master, make clean, check menu config, then build and play.
>>>>>> Sounds right.
>>>>>>> I can get my part done by Sunday 14th night (HKT), so suggest to do
>>>>>>> the Merge of the OVMS firmware master branch then.
>>>>>> I'll be sleeping then, so you can go ahead and do the merge.
>>>>>> -- Steve
>>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180115/ad817c41/attachment-0001.html>
