[Ovmsdev] Transition to new esp-idf
Mon Jan 15 01:09:35 HKT 2018
Mark,
It looks like you were not able to do the sdkconfig.default and merge
as you planned?
On Fri, 12 Jan 2018, Stephen Casner wrote:
> On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
> > @Steve can you update our master clone to latest from Espressif and
> > make sure your stuff is still ok?
> I have just now done this.  I had already done a rebase a few days ago
> before committing the improved version of the OS changes so I could
> issue a pull request.  There were a few commits since then, which I
> have now merged.  My code still runs correctly.
> > I guess steps for developers will be:
> > 1) pull the openvehicles IDF and switch to master branch. Sub module update.
> > 2) download and install xtensa build chain to match.
> > 3) update OVMS master, make clean, check menu config, then build and play.
> Sounds right.
> > I can get my part done by Sunday 14th night (HKT), so suggest to do
> > the Merge of the OVMS firmware master branch then.
> I'll be sleeping then, so you can go ahead and do the merge.
