[Ovmsdev] Transition to new esp-idf
Sat Jan 13 14:47:12 HKT 2018
On Sat, 13 Jan 2018, Mark Webb-Johnson wrote:
> @Steve can you update our master clone to latest from Espressif and
> make sure your stuff is still ok?
I have just now done this.  I had already done a rebase a few days ago
before committing the improved version of the OS changes so I could
issue a pull request.  There were a few commits since then, which I
have now merged.  My code still runs correctly.
> I guess steps for developers will be:
> 1) pull the openvehicles IDF and switch to master branch. Sub module update.
> 2) download and install xtensa build chain to match.
> 3) update OVMS master, make clean, check menu config, then build and play.
Sounds right.
> I can get my part done by Sunday 14th night (HKT), so suggest to do
> the Merge of the OVMS firmware master branch then.
I'll be sleeping then, so you can go ahead and do the merge.
