[Ovmsdev] CAN-3 broken again?
Fri Jan 12 02:28:37 HKT 2018
Steve,
LFs will be injected into the log if a notification or command result is sent:
I (544365) ovms-server-v2: Send MP-0 PITopping off|CHG: 0 (~0) Wh|Full: 124 min.|Range: 50 - 48Km|SOC: 70.0% (70.0..70.0%)|ODO: 47026.7Km|CAP: 89.7% 96.9Ah|SOH:
100%|
D (550265) ovms-server-v2: TransmitNotifyData: msg=RT-BAT-P,1,86400,1,1,6998,6998,6998,574,574,574,29,29,29,5,1,190,20|
These were the reason for my change. Will probably also occur if a user command received contains CR/LF.
At the moment, the simcom module also injects CR/LF on tx logs:
D (28345) simcom: tx scmd ch=0 len=4   : AT||
D (44345) simcom: tx scmd ch=0 len=103 : AT+CPIN?;+CREG=1;+CTZU=1;+CTZR=1;+CLIP=1;+CMGF=1;+CNMI=1,2,0,0,0;+CSDH=1;+CMEE=2;+CSQ;+AUTOCSQ=1,1;E0||
Don't know if that covers all cases.
Basically this also applies everywhere a string of external / user supplied source gets logged (little Bobby Tables). I can for example imagine a broken Wifi
network sending an SSID containing CR/LF.
Am 11.01.2018 um 19:07 schrieb Stephen Casner:
> On Thu, 11 Jan 2018, Michael Balzer wrote:
>>   * Line 294: this should be a warning level log, also the "\n" at
>>     the end isn't necessary for a log.
> This should be stated more strongly: Not only is it not necessary, it should just
> not be there.  It is also not optional, it won't be ignored.  It used
> to cause a blank line in the output, but now it causes a '|' character
> to be appended after after a change that Michael made a while back.
> Michael, when I first saw that change you made to translate all \n or \r
> except the last to be '|', thereby unfolding a multi-line log into one
> line, I did not really like that idea but I didn't comment at the
> time.  It seems to me that if the format of a multi-line log message
> causes a problem then it would be best to go back to the original log
> message and change it.  Perhaps you were bothered by some log message
> in code that is not under our control?  Can you show some examples?
> I bring this up now because that bit of code needs to move as I
> implement the facility to log on all consoles, and I would like to
> consider removing it.
