[Ovmsdev] CAN BUS logging to flash storage
Thu Jan 11 20:59:50 HKT 2018
Mark,
I'll add the logging support along with the TX queue.
Am 10.01.2018 um 01:27 schrieb Mark Webb-Johnson:
> Probably best to split this off as a separate eMail thread.
> I think the implementation would be relatively simple.
> * Create a canlog class with a FILE* m_log member variable, and a virtual function Log() that is called with a direction (tx/rx) and frame
> to log.
> o The constructor should be passed the vfs file path to log to. It should fopen the m_log file to that.
> o The destructor should fclose the m_log file.
> * Create a canlog_crtd class, derived from canlog, that supports Log() to log to m_log in CRTD format.
> * Optionally create other canlog_* classes, for other logging formats that we want to support.
> * Add a canlog* m_log member variable in canbus.
> o Initialise m_log to NULL in the constructor.
> o In the destructor, if m_log is not null, delete it’s object and set it to NULL.
> o Have a command ‘can log’ like ‘can trace’ that specifies a vfs file path (remember to check it with OvmsConfig ProtectedPath) and
> logging format. It will then ’new’ a canlog_* style object (depending on logging format).
> * In can::IncomingFrame, log incoming CAN messages with m_log->Log(), in the same way as m_trace is handled.
> * In canbus::Write, log outgoing CAN messages with m_log->Log(), in the same way as m_trace is handled.
> Volunteer?
>> On 10 Jan 2018, at 8:07 AM, Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>> wrote:
>> Now SD CARD support is coming, anybody want to step forward and extend components/can to support CAN bus logging to a file (in crtd format,
>> or perhaps support one or two popular formats)? Implementation would be in class canbus, very similar to m_trace; just need to have a FILE*
>> m_log and appropriate commands / logging of packet write/read in the same place that trace does it.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20180111/284f9443/attachment-0001.html>
