[Ovmsdev] /store gone
    Greg D.
    gregd2350 at gmail.com
    Sat Feb 17 11:20:57 HKT 2018
Not the recovery, the troubleshooting.  Didn't want to write to it if
there were any tea leaves that we needed to analyze, though come to
think of it, the (empty) ovms_config directory was written there
already, so...
Tried creating an obd2ecu map item, and now ovms_config has a file in
it, and the file contains the map.  So, writing and reading work, and
they survive a reboot.
So, wipe it?  Any last tea leaves to sift through?
What is the safest way to put flash back to a good state (without having
access to a programmer!)?
Greg
Stephen Casner wrote:
> I get the same error message if I try "vfs cat /store/scripts" (which
> is a directory), so I don't think that message indicates anything
> worse for you.  If the recovery approach is to wipe flash, what harm
> could there be in trying to write something in the config?
> On Fri, 16 Feb 2018, Greg D. wrote:
>> That would have helped.  Also, shouldn't a 'stat' of it return something
>> useful?  That error about not being able to open it leaves me wondering
>> about what is safe to do at this point.
>> Greg
>>> On Sat, 17 Feb 2018, Mark Webb-Johnson wrote:
>>>> Ovms_config is a directory. Don't think you can cat it.
>>> Oh, right.  Perhaps vfs ls should add a trailing '/'?
>>>                                                         -- Steve
