[Ovmsdev] Prolonging traction battery life feature
    Robert Sharpe
    robert.sharpe at evergreen-consulting.co.uk
    Fri Feb 16 19:13:04 HKT 2018
Hi Tom,
Thanks for your reply.
Just to clarify, all I am trying to do is to reproduce what manufacturers do all the time to prolong battery life when they supply Lithium batteries at 50% soc.  If this charge scenario doesn't improve their life then nothing wasted.  If it does then it could prolong its life by around 50% and save thousands of pounds on battery replacement.
Before I think about about how to use OVMS to implement this, can someone summarise what current Nissan Leaf feature support is provided (which can then be used to update the vehicle support list)
Rob
--- On Fri, 16 Feb 2018 03:19:59 +0000 Tom Saxton <tom at idleloop.com> wrote ----
Hi Robert,
I believe most of what you want is already built into OVMS through the Advanced Charge Control feature, at least for vehicles that have implemented a charge time predictor.
In OVMS v2 this was configured via text message. For example this command:
ACC PARAMS CHARGEBY 07:00 STOPSOC 60
tells OVMS that when plugged in at the current location, it should delay charging until charging to 60% state-of-charge will be achieved around 7:00 am.
As far as I know, there isn’t currently a notion of a minimum SOC that should be achieved ASAP upon plug in. I’m not sure that’s a big deal unless you regularly plug in with SOC below 10%. For example, the Tesla Roadster has a storage mode that holds charge at around 25% for long term storage.
There is a possible downside with using OVMS to limit the state of charge. Some electric vehicles, perhaps most, perform a pack leveling operation at the end of charging. If OVMS is used to stop charging early, that pack leveling will not happen.
     Tom
From: <ovmsdev-bounces at lists.teslaclub.hk> on behalf of Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk>
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date: Thursday, February 15, 2018 at 9:13 AM
Subject: [Ovmsdev] Prolonging traction battery life feature
Hi All,
I have an idea that will help prolong the life of EV batteries and maximise vehicle resale value.
In summary it involves implementing intelligent charging that keeps the battery at 50% (the best soc for long term storage) for as long a possible and minimises depth of charge and discharge.  For example
·         as soon as you get to a charge point (eg home or work), the OVMS will detect if it is below 50% and charge it until 50% is achieved
·         the OVMS will be told the minimum required soc and when this should be achieved
·         it will then wait until the last moment to start charging to achieving the required min soc
·         a later version could receive a notification from your Google calendar with required mileage via IFTT, etc
Unfortunately, I don't have the coding skills to implement it but would be happy to do all the non-coding stuff like requirements, design, documentation, testing, etc.
If this sounds interesting and you would like to find out more please feel free to get back to me for a chat.
Robert Sharpe (Managing Director)
07711 252971
Skype: arsharpe
Your Plugged-in Partner
Evergreen Consulting is the trading name of Sharpe Consultants Ltd
_______________________________________________ OvmsDev mailing list OvmsDev at lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment.htm>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment-0010.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment-0011.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment-0012.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment-0013.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment-0014.gif>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180216/e9d2d7ed/attachment-0002.png>
