[Ovmsdev] Prolonging traction battery life feature
Fri Feb 16 11:19:59 HKT 2018
Hi Robert,
I believe most of what you want is already built into OVMS through the Advanced Charge Control feature, at least for vehicles that have implemented a charge time predictor.
In OVMS v2 this was configured via text message. For example this command:
ACC PARAMS CHARGEBY 07:00 STOPSOC 60
tells OVMS that when plugged in at the current location, it should delay charging until charging to 60% state-of-charge will be achieved around 7:00 am.
As far as I know, there isn’t currently a notion of a minimum SOC that should be achieved ASAP upon plug in. I’m not sure that’s a big deal unless you regularly plug in with SOC below 10%. For example, the Tesla Roadster has a storage mode that holds charge at around 25% for long term storage.
There is a possible downside with using OVMS to limit the state of charge. Some electric vehicles, perhaps most, perform a pack leveling operation at the end of charging. If OVMS is used to stop charging early, that pack leveling will not happen.
     Tom
From: <ovmsdev-bounces at lists.teslaclub.hk> on behalf of Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk>
Reply-To: OVMS Developers <ovmsdev at lists.teslaclub.hk>
Date: Thursday, February 15, 2018 at 9:13 AM
Subject: [Ovmsdev] Prolonging traction battery life feature
Hi All,
I have an idea that will help prolong the life of EV batteries and maximise vehicle resale value.
In summary it involves implementing intelligent charging that keeps the battery at 50% (the best soc for long term storage) for as long a possible and minimises depth of charge and discharge.  For example
·         as soon as you get to a charge point (eg home or work), the OVMS will detect if it is below 50% and charge it until 50% is achieved
·         the OVMS will be told the minimum required soc and when this should be achieved
·         it will then wait until the last moment to start charging to achieving the required min soc
·         a later version could receive a notification from your Google calendar with required mileage via IFTT, etc
Unfortunately, I don't have the coding skills to implement it but would be happy to do all the non-coding stuff like requirements, design, documentation, testing, etc.
If this sounds interesting and you would like to find out more please feel free to get back to me for a chat.
Robert Sharpe (Managing Director)
07711 252971
Skype: arsharpe
Your Plugged-in Partner
Evergreen Consulting is the trading name of Sharpe Consultants Ltd
_______________________________________________ OvmsDev mailing list OvmsDev at lists.teslaclub.hk http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment.htm>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment-0010.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment-0011.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment-0012.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment-0013.gif>
Type: image/gif
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment-0014.gif>
Type: image/png
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180215/ce2eee54/attachment-0002.png>
