[Ovmsdev] Crash / reboot loop with log level Info
Tue Feb 27 01:59:15 HKT 2018
I second that, the normal stack usage for the Housekeeper is already quite close to 4K:
Number of Tasks = 19       Stack:  Now   Max Total    Heap 32-bit SPIRAM
Task 3FFD3718 14 Housekeeping      356  3396  4096   91940      0      0
So I also think 6K should be the default.
Am 26.02.2018 um 08:54 schrieb Stephen Casner:
> Greg,
> Presuming that you are not doing some activity in the Housekeeping
> task that should really be done in some other task, and presuming that
> the activity you are doing is not something unreasonable, then indeed
> you have found a valid need for a larger stack and the change should
> be committed.  The value 6144 is a reasonable step up.
> On Sun, 25 Feb 2018, Greg D. wrote:
>> Ha, yes.  Sorry.  I bumped it up to 6144 (seems like a popular value),
>> and that fixed it.
>> So, two questions:
>> 1.  What should a proper value be?  I used 6144 only because I'd seen it
>> used elsewhere.
>> 2.  Shall I push this for permanence?
>> Thanks,
>> Greg
>> Stephen Casner wrote:
>>> Greg,
>>> It sounds to me like you are conflating stack overflow with running
>>> out of heap space.  You are not having a problem (yet) of running out
>>> of heap space, you have a stack size that is configured too small for
>>> your program's requirements.  From what I saw in your earlier message,
>>> you need to change the creation of the Housekeeping task to specify a
>>> larger stack.
>>>                                                         -- Steve
>>>> Hi Steve,
>>>> I don't see any evidence that there is a recursive loop here, just the
>>>> buffers stacking up, causing the overflow.  Odd, though, this used to
>>>> work.  Not sure what else changed at that time besides the logging
>>>> level; if I recall, it was part of a larger update.
>>>> But given that we have a RAM fix coming, is it worth messing with this?
>>>> Greg
>>>>> Greg,
>>>>> Unless there is a bug causing infinite recursion or something, you may
>>>>> have sufficient free RAM to allow increasing the size of the stack for
>>>>> the task that is getting the stack overflow and achieve successful
>>>>> operation.
>>>>>                                                         -- Steve
>>>>> OvmsDev mailing list
