[Ovmsdev] Crash / reboot loop with log level Info
Mon Feb 26 08:33:22 HKT 2018
Hi Steve,
I don't see any evidence that there is a recursive loop here, just the
buffers stacking up, causing the overflow.  Odd, though, this used to
work.  Not sure what else changed at that time besides the logging
level; if I recall, it was part of a larger update.
But given that we have a RAM fix coming, is it worth messing with this?
Greg
Stephen Casner wrote:
> Greg,
> Unless there is a bug causing infinite recursion or something, you may
> have sufficient free RAM to allow increasing the size of the stack for
> the task that is getting the stack overflow and achieve successful
> operation.
