[Ovmsdev] Garbage in /store
Sat Dec 22 01:21:33 HKT 2018
The .htpasswd file is generated automatically by the webserver from the password config.
Am 21.12.18 um 17:53 schrieb Stephen Casner:
> Michael,
> I will save the flash partition as you suggest.
> Also, in your message telling about the addition of the config
> backup/restore function you said the backup covers the directories
> "ovms_config" and "events" from "/store". I note that /store also
> contains a .htpasswd file. Should that also be included, or is it
> already?
> -- Steve
> On Fri, 21 Dec 2018, Michael Balzer wrote:
>> Yes.
>> You might consider saving the flash partition for further bug analysis before erasing it:
>> https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/edit#heading=h.o79tlr919yab
