[Ovmsdev] Garbage in /store
Stephen Casner
casner at acm.org
Sat Dec 22 00:53:02 HKT 2018
Michael,
I will save the flash partition as you suggest.
Also, in your message telling about the addition of the config
backup/restore function you said the backup covers the directories
"ovms_config" and "events" from "/store". I note that /store also
contains a .htpasswd file. Should that also be included, or is it
already?
On Fri, 21 Dec 2018, Michael Balzer wrote:
> Yes.
> You might consider saving the flash partition for further bug analysis before erasing it:
> https://docs.google.com/document/d/1q5M9Lb5jzQhJzPMnkMKwy4Es5YK12ACQejX_NWEixr0/edit#heading=h.o79tlr919yab
