Stephen Casner
casner at acm.org
Thu Aug 2 14:54:26 HKT 2018
Michael,
Will 009 be ready for main soon? I could switch to edge, but my
friend in Santa Barbara needs it too, and edge would not be good for
him.
On Wed, 1 Aug 2018, Michael Balzer wrote:
> Steve, Greg,
> you're both still on the 3.1.008 main release, please check out the edge build.
> Your crashes look very familiar to me, I assume they are wifi related. The "esf_buf" error log Steve had is coming from within the wifi blob, and the latest
> edge build includes many fixes to that. That build reduced those crashes in the Twizy community by about 90%.
> Regarding logging, this is my base config:
> level: debug
> level.gsm-ppp: debug
> level.simcom: debug
> level.time: info
> level.v-twizy: verbose ← change accordingly
> level.webserver: debug
> If I need more detail I simply switch the default level to verbose.
> Am 01.08.2018 um 08:40 schrieb Greg D.:
> > Well, we seem to be on a roll... Got another one.
> > I just realized that I have an SD card in the module, but am not logging anything. What logging should I be setting up to capture additional information?
> > Greg
> > Last boot was 2153 second(s) ago Time at boot: 2018-07-31 23:01:39 PDT This is reset #20 since last power cycle Detected boot reason: Crash (12/12) Crash
> > counters: 2 total, 0 early Last crash: Alloca exception on core 0 Registers: PC : 0x40081b96 PS : 0x00060634 A0 : 0x80081d61 A1 : 0x3ffafa60 A2 : 0x3ffb43e4
> > A3 : 0x00000001 A4 : 0x00000050 A5 : 0x00000001 A6 : 0x000000fe A7 : 0x000000a0 A8 : 0x00000081 A9 : 0x00000001 A10 : 0x0000cdcd A11 : 0x00000000 A12 :
> > 0x3f40819c A13 : 0x3f407ebe A14 : 0x000000fe A15 : 0x00060023 SAR : 0x00000000 EXCCAUSE: 0x00000005 EXCVADDR: 0x00000000 LBEG : 0x40097664 LEND : 0x40097692
> > LCOUNT : 0xffffffff Backtrace: 0x40081b96 0x40081d5e 0x400db815 0x40174f95 0x400e73be 0x400e4699 0x40085149 0x40128bc2 0x40128df7 0x401287b4 0x400ea22d
> > 0x400eac7a 0x400ead09 0x400ead19 0x402207d6 0x400e9ece 0x400e9f79 0x400e45f5 0x400e4604 0x400f5c09 0x400f035d Version: 3.1.008/ota_1/main (build idf
> > v3.1-dev-986-g1a1a544a Jun 26 2018 09:30:21)
> > Running partition: ota_1 Boot partition: ota_1 Firmware: 3.1.008/ota_1/main (build idf v3.1-dev-986-g1a1a544a Jun 26 2018 09:30:21)
> > Greg D. wrote:
> >> Hi Steve,
> >> Ok, so, still a puzzle as to why the crashes. Fortunately, I've only
> >> had the one. I've not had any trouble losing wifi connectivity, either
> >> when the car's been sitting in the garage for a few days, or coming and
> >> going on errands (so, transitioning to cell and back). Prior to this, I
> >> think the last boot was the upgrade to 3.1.008. Oh, perhaps the car's
> >> recent near death experience (*) cycled power? Not sure, but probably
> >> did. Anyway, in general, I've not had trouble with connectivity in a
> >> long time.
> >> The only thing I've noticed is that sometimes I have a rather long delay
> >> between an event (e.g. when the car starts charging) and having it show
> >> up on my cell phone. Usually I get it immediately, but some time it's
> >> delayed several minutes, and once in a while it never shows up (e.g.
> >> charging started but never finished). It might simply be packet loss on
> >> my Internet connection (it's fast, but sometimes leaky), not related to
> >> wi-fi. I get delays at times on the PC going to websites too.
> >> {shrug}
> >> Greg
> >> (*) For some reason, the VMS lost connectivity to the VDS, and the car
> >> locked up. Fortunately it was in the garage, and the windows were
> >> rolled down since the door opening switches stopped working too. Had to
> >> unplug the cables to the VMS under the dash and plug them back in to
> >> force a reboot. {phew!}
> >> Stephen Casner wrote:
> >>> On Sun, 29 Jul 2018, Greg D. wrote:
> >>>> Hi Steve,
> >>>> Interesting...? I just got a very cryptic "event" from my car:?
> >>>> Not charging
> >>>> SOC:-
> >>> I believe it is expected to get that event when OVMS boots while the
> >>> car is idle since "not charging" is an accurate description of the
> >>> state.
> >>> I received a "not charging" notification on Sunday as well,
> >>> coincidentally as we were approaching home in our RAV4-EV. This
> >>> resulted from another "Alloca exception on core 0" crash and reboot of
> >>> OVMS:
> >>> Last boot was 170458 second(s) ago
> >>> Time at boot: 2018-07-29 21:41:32 GMT
> >>> This is reset #7 since last power cycle
> >>> Detected boot reason: Crash (8/14)
> >>> Crash counters: 2 total, 0 early
> >>> This is not the same time as yours (2018-07-29 17:55:36 PDT) so it
> >>> does not appear that the crashes are synchronized by some external
> >>> event.
> >>> Then today I looked at the iPhone app and saw that my OVMS had not
> >>> communicated with the v2 server for 15 hours. So I connected to the
> >>> USB cable again and found that the wifi was again in trouble. This
> >>> time there were many instances of a new error message from wifi that I
> >>> had not seen before, as shown in the log below.
> >>> Again I was able to restore operation of both server v2 and http by
> >>> "wifi mode off" then "wifi mode client".
> >>> -- Steve
> >>> E (170324792) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170325752) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170328632) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
> >>> E (170328632) ovms-server-v2: Status: Error: Connection failed
> >>> E (170329542) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170333742) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170333752) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170333762) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170335592) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> I (170335672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> >>> I (170335672) ovms-server-v2: Status: Connecting...
> >>> E (170335672) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170336312) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170337272) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170338232) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170339192) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170340152) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170341112) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170342072) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170343032) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> OVMS> ena
> >>> Password:
> >>> E (170343992) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170344702) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170345912) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170346232) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170346872) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170347262) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> OVMS#
> >>> E (170347832) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170348792) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
> >>> E (170348792) ovms-server-v2: Status: Error: Connection failed
> >>> E (170348792) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170349752) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170350832) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170353802) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170353812) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170353822) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170353832) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> I (170355672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> >>> I (170355672) ovms-server-v2: Status: Connecting...
> >>> E (170355672) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170356472) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170357432) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170358392) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170359352) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170359842) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170360862) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170362232) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170362922) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170363192) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170364152) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170365112) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170366072) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170368952) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
> >>> E (170368952) ovms-server-v2: Status: Error: Connection failed
> >>> E (170372022) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170373762) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170373772) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170373782) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170374992) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170375672) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> I (170375672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> >>> I (170375672) ovms-server-v2: Status: Connecting...
> >>> E (170376632) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170377592) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170378062) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
> >>> E (170378552) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170379512) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170380472) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170381432) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> E (170382392) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
> >>> OVMS# wifi mode off
> >>> Stopping wifi station...
> >>> I (170383222) esp32wifi: Stopping WIFI station
> >>> I (170383222) wifi: state: run -> init (0)
> >>> I (170383222) wifi: pm stop, total sleep time: 47593209375 us / 59459320714 us
> >>> I (170383222) wifi: n:1 0, o:1 1, ap:1 1, sta:1 0, prof:1
> >>> I (170383232) wifi: flush txq
> >>> I (170383232) wifi: stop sw txq
> >>> I (170383232) wifi: lmac stop hw txq
> >>> E (170389112) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
> >>> E (170389112) ovms-server-v2: Status: Error: Connection failed
> >>> I (170389112) netmanager: Interface priority is pp3 (10.170.41.247/255.255.255.255 gateway 10.64.64.64)
> >>> I (170389112) netmanager: Set DNS#0 8.8.8.8
> >>> I (170389112) netmanager: Set DNS#1 8.8.4.4
> >>> I (170389112) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
> >>> I (170389122) netmanager: Interface priority is pp3 (10.170.41.247/255.255.255.255 gateway 10.64.64.64)
> >>> I (170389122) netmanager: Set DNS#0 8.8.8.8
> >>> I (170389122) netmanager: Set DNS#1 8.8.4.4
> >>> I (170389122) esp32wifi: STA disconnected with reason 8
> >>> W (170389122) netmanager: CleanupConnections: can't get AP station list
> >>> I (170389132) netmanager: Interface priority is pp3 (10.170.41.247/255.255.255.255 gateway 10.64.64.64)
> >>> I (170389132) netmanager: Set DNS#0 8.8.8.8
> >>> I (170389132) netmanager: Set DNS#1 8.8.4.4
> >>> I (170389132) netmanager: WIFI access point is down
> >>> I (170389132) esp32wifi: AP stopped
> >>> I (170389132) netmanager: CleanupConnections: closing conn 3f81dbbc: interface/link down
> >>> I (170389142) netmanager: CleanupConnections: closing conn 3f81dbbc: interface/link down
> >>> I (170389142) time: Network was reconfigured: restarting SNTP client
> >>> I (170389142) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
> >>> I (170389142) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
> >>> I (170389152) netmanager: CleanupConnections: closing conn 3f81dbbc: interface/link down
> >>> I (170398672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> >>> I (170398672) ovms-server-v2: Status: Connecting...
> >>> I (170401312) housekeeping: 2018-07-31 21:01:32 GMT (RAM: 8b=113788-152956 32b=28252)
> >>> I (170402032) ovms-server-v2: Connection successful
> >>> I (170402032) ovms-server-v2: Status: Logging in...
> >>> I (170402032) ovms-server-v2: Sending server login: MP-C 0 xR/s7da9YTwJ+uKH0C2zRl VXtWmVfsQQjJCe4+AwK74w== US33
> >>> I (170402852) ovms-server-v2: Got server response: MP-S 0 1uDt9VTVDl5jzvSqsIwmtN isXmd3Gy2AcrvhQVrX3LAA==
> >>> I (170402852) ovms-server-v2: Server token is 1uDt9VTVDl5jzvSqsIwmtN and digest is isXmd3Gy2AcrvhQVrX3LAA==
> >>> I (170402852) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
> >>> I (170402852) ovms-server-v2: Shared secret key is 1uDt9VTVDl5jzvSqsIwmtNxR/s7da9YTwJ+uKH0C2zRl (44 bytes)
> >>> I (170402852) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
> >>> I (170402872) ovms-server-v2: Incoming Msg: MP-0 Z0
> >>> I (170403672) ovms-server-v2: Send MP-0 S70.0,M,65535,127,stopped,standard,166,146,32,0,0,2100,7,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
> >>> I (170403672) ovms-server-v2: Send MP-0 D65,0,5,23,23,24,587,516256,0,170403,24,0,1,1,11.63,0,12.6,0,23,0
> >>> I (170403672) ovms-server-v2: Send MP-0 L37.346340,-122.037308,206,64,1,1,0,0,0.0,0,0
> >>> I (170403682) ovms-server-v2: Send MP-0 F3.1.008/ota_0/main (build idf v3.1-dev-986-g1a1a544a Jun 26 2018 09:30:21),5YJRE11B181000033,7,1,TR1N,AT&T Hologram
> >>> OVMS# wifi mode client Revelstoke
> >>> Starting WIFI as a client to Revelstoke...
> >>> I (170432062) wifi: mode : sta (30:ae:a4:43:9c:28)
> >>> I (170434462) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
> >>> I (170435152) wifi: state: init -> auth (b0)
> >>> I (170435162) wifi: state: auth -> assoc (0)
> >>> I (170435162) wifi: state: assoc -> run (10)
> >>> I (170435202) wifi: connected with Revelstoke, channel 1
> >>> I (170435202) wifi: pm start, type: 1
> >>> I (170438872) event: sta ip: 192.168.1.82, mask: 255.255.255.0, gw: 192.168.1.254
> >>> I (170438872) netmanager: Interface priority is st4 (192.168.1.82/255.255.255.0 gateway 192.168.1.254)
> >>> I (170438872) netmanager: Set DNS#0 8.8.8.8
> >>> I (170438872) netmanager: Set DNS#1 8.8.4.4
> >>> I (170438872) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority
> >>> I (170438872) esp32wifi: STA got IP with SSID: Revelstoke, MAC: 30:ae:a4:43:9c:28, IP: 192.168.1.82, mask: 255.255.255.0, gw: 192.168.1.254
> >>> I (170438882) time: Network was reconfigured: restarting SNTP client
> >>> I (170438882) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
> >>> I (170438882) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
> >>> I (170439082) ovms-server-v2: Status: Disconnected
> >>> I (170451362) webserver: HTTP GET /
> >>> I (170451572) webserver: HTTP GET /apple-touch-icon.png
> >>> I (170451842) webserver: HTTP GET /status
> >>> I (170458672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
> >>> I (170458672) ovms-server-v2: Status: Connecting...
> >>> I (170458902) ovms-server-v2: Connection successful
> >>> I (170458902) ovms-server-v2: Status: Logging in...
> >>> I (170458902) ovms-server-v2: Sending server login: MP-C 0 zSgUQypXKd9tYDq7XuHf8m Raby/geQppSUPG5l9NRztw== US33
> >>> I (170458922) webserver: HTTP POST /status
> >>> I (170458922) webserver: HandleLogin: 'admin' logged in, sid 6ea0f4c3207e3328
> >>> I (170459342) ovms-server-v2: Got server response: MP-S 0 ooMhIGTk/0ZEvxVpwoHZ4d 4d+RTkaUZ1onzxLyxVwYEQ==
> >>> I (170459342) ovms-server-v2: Server token is ooMhIGTk/0ZEvxVpwoHZ4d and digest is 4d+RTkaUZ1onzxLyxVwYEQ==
> >>> I (170459342) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
> >>> I (170459342) ovms-server-v2: Shared secret key is ooMhIGTk/0ZEvxVpwoHZ4dzSgUQypXKd9tYDq7XuHf8m (44 bytes)
> >>> I (170459342) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
> >>> I (170459352) ovms-server-v2: Incoming Msg: MP-0 Z0
> >>> I (170459352) webserver: HTTP GET /status
> >>> I (170459392) webserver: HTTP GET /menu
> >>> _______________________________________________
> >>> OvmsDev mailing list
> >>> OvmsDev at lists.openvehicles.com
> >>> http://lists.openvehicles.com/mailman/listinfo/ovmsdev
