Steve, Greg,
you're both still on the 3.1.008 main release, please check out the edge build.
Your crashes look very familiar to me, I assume they are wifi related. The "esf_buf" error log Steve had is coming from within the wifi blob, and the latest
edge build includes many fixes to that. That build reduced those crashes in the Twizy community by about 90%.
Regarding logging, this is my base config:
level: debug
level.gsm-ppp: debug
level.simcom: debug
level.time: info
level.v-twizy: verbose ← change accordingly
level.webserver: debug
If I need more detail I simply switch the default level to verbose.
Am 01.08.2018 um 08:40 schrieb Greg D.:
> Well, we seem to be on a roll... Got another one.
> I just realized that I have an SD card in the module, but am not logging anything. What logging should I be setting up to capture additional information?
> Greg
> Last boot was 2153 second(s) ago Time at boot: 2018-07-31 23:01:39 PDT This is reset #20 since last power cycle Detected boot reason: Crash (12/12) Crash
> counters: 2 total, 0 early Last crash: Alloca exception on core 0 Registers: PC : 0x40081b96 PS : 0x00060634 A0 : 0x80081d61 A1 : 0x3ffafa60 A2 : 0x3ffb43e4
> A3 : 0x00000001 A4 : 0x00000050 A5 : 0x00000001 A6 : 0x000000fe A7 : 0x000000a0 A8 : 0x00000081 A9 : 0x00000001 A10 : 0x0000cdcd A11 : 0x00000000 A12 :
> 0x3f40819c A13 : 0x3f407ebe A14 : 0x000000fe A15 : 0x00060023 SAR : 0x00000000 EXCCAUSE: 0x00000005 EXCVADDR: 0x00000000 LBEG : 0x40097664 LEND : 0x40097692
> LCOUNT : 0xffffffff Backtrace: 0x40081b96 0x40081d5e 0x400db815 0x40174f95 0x400e73be 0x400e4699 0x40085149 0x40128bc2 0x40128df7 0x401287b4 0x400ea22d
> 0x400eac7a 0x400ead09 0x400ead19 0x402207d6 0x400e9ece 0x400e9f79 0x400e45f5 0x400e4604 0x400f5c09 0x400f035d Version: 3.1.008/ota_1/main (build idf
> v3.1-dev-986-g1a1a544a Jun 26 2018 09:30:21)
> Running partition: ota_1 Boot partition: ota_1 Firmware: 3.1.008/ota_1/main (build idf v3.1-dev-986-g1a1a544a Jun 26 2018 09:30:21)
> Greg D. wrote:
>> Hi Steve,
>> Ok, so, still a puzzle as to why the crashes. Fortunately, I've only
>> had the one. I've not had any trouble losing wifi connectivity, either
>> when the car's been sitting in the garage for a few days, or coming and
>> going on errands (so, transitioning to cell and back). Prior to this, I
>> think the last boot was the upgrade to 3.1.008. Oh, perhaps the car's
>> recent near death experience (*) cycled power? Not sure, but probably
>> did. Anyway, in general, I've not had trouble with connectivity in a
>> long time.
>> The only thing I've noticed is that sometimes I have a rather long delay
>> between an event (e.g. when the car starts charging) and having it show
>> up on my cell phone. Usually I get it immediately, but some time it's
>> delayed several minutes, and once in a while it never shows up (e.g.
>> charging started but never finished). It might simply be packet loss on
>> my Internet connection (it's fast, but sometimes leaky), not related to
>> wi-fi. I get delays at times on the PC going to websites too.
>> {shrug}
>> Greg
>> (*) For some reason, the VMS lost connectivity to the VDS, and the car
>> locked up. Fortunately it was in the garage, and the windows were
>> rolled down since the door opening switches stopped working too. Had to
>> unplug the cables to the VMS under the dash and plug them back in to
>> force a reboot. {phew!}
>> Stephen Casner wrote:
>>> On Sun, 29 Jul 2018, Greg D. wrote:
>>>> Hi Steve,
>>>> Interesting...? I just got a very cryptic "event" from my car:?
>>>> Not charging
>>>> SOC:-
>>> I believe it is expected to get that event when OVMS boots while the
>>> car is idle since "not charging" is an accurate description of the
>>> state.
>>> I received a "not charging" notification on Sunday as well,
>>> coincidentally as we were approaching home in our RAV4-EV. This
>>> resulted from another "Alloca exception on core 0" crash and reboot of
>>> OVMS:
>>> Last boot was 170458 second(s) ago
>>> Time at boot: 2018-07-29 21:41:32 GMT
>>> This is reset #7 since last power cycle
>>> Detected boot reason: Crash (8/14)
>>> Crash counters: 2 total, 0 early
>>> This is not the same time as yours (2018-07-29 17:55:36 PDT) so it
>>> does not appear that the crashes are synchronized by some external
>>> event.
>>> Then today I looked at the iPhone app and saw that my OVMS had not
>>> communicated with the v2 server for 15 hours. So I connected to the
>>> USB cable again and found that the wifi was again in trouble. This
>>> time there were many instances of a new error message from wifi that I
>>> had not seen before, as shown in the log below.
>>> Again I was able to restore operation of both server v2 and http by
>>> "wifi mode off" then "wifi mode client".
>>> -- Steve
>>> E (170324792) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170325752) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170328632) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
>>> E (170328632) ovms-server-v2: Status: Error: Connection failed
>>> E (170329542) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170333742) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170333752) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170333762) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170335592) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> I (170335672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
>>> I (170335672) ovms-server-v2: Status: Connecting...
>>> E (170335672) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170336312) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170337272) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170338232) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170339192) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170340152) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170341112) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170342072) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170343032) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> OVMS> ena
>>> Password:
>>> E (170343992) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170344702) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170345912) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170346232) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170346872) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170347262) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> OVMS#
>>> E (170347832) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170348792) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
>>> E (170348792) ovms-server-v2: Status: Error: Connection failed
>>> E (170348792) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170349752) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170350832) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170353802) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170353812) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170353822) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170353832) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> I (170355672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
>>> I (170355672) ovms-server-v2: Status: Connecting...
>>> E (170355672) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170356472) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170357432) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170358392) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170359352) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170359842) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170360862) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170362232) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170362922) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170363192) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170364152) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170365112) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170366072) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170368952) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
>>> E (170368952) ovms-server-v2: Status: Error: Connection failed
>>> E (170372022) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170373762) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170373772) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170373782) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170374992) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170375672) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> I (170375672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
>>> I (170375672) ovms-server-v2: Status: Connecting...
>>> E (170376632) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170377592) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170378062) wifi: esf_buf: t=7 l=1600 max:16, alloc:16 no eb
>>> E (170378552) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170379512) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170380472) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170381432) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> E (170382392) wifi: esf_buf: t=7 l=110 max:16, alloc:16 no eb
>>> OVMS# wifi mode off
>>> Stopping wifi station...
>>> I (170383222) esp32wifi: Stopping WIFI station
>>> I (170383222) wifi: state: run -> init (0)
>>> I (170383222) wifi: pm stop, total sleep time: 47593209375 us / 59459320714 us
>>> I (170383222) wifi: n:1 0, o:1 1, ap:1 1, sta:1 0, prof:1
>>> I (170383232) wifi: flush txq
>>> I (170383232) wifi: stop sw txq
>>> I (170383232) wifi: lmac stop hw txq
>>> E (170389112) ovms-server-v2: mg_connect(api.openvehicles.com:6867) failed: cannot parse address|
>>> E (170389112) ovms-server-v2: Status: Error: Connection failed
>>> I (170389112) netmanager: Interface priority is pp3 (10.170.41.247/255.255.255.255 gateway 10.64.64.64)
>>> I (170389112) netmanager: Set DNS#0 8.8.8.8
>>> I (170389112) netmanager: Set DNS#1 8.8.4.4
>>> I (170389112) netmanager: WIFI client down (with MODEM up): reconfigured for MODEM priority
>>> I (170389122) netmanager: Interface priority is pp3 (10.170.41.247/255.255.255.255 gateway 10.64.64.64)
>>> I (170389122) netmanager: Set DNS#0 8.8.8.8
>>> I (170389122) netmanager: Set DNS#1 8.8.4.4
>>> I (170389122) esp32wifi: STA disconnected with reason 8
>>> W (170389122) netmanager: CleanupConnections: can't get AP station list
>>> I (170389132) netmanager: Interface priority is pp3 (10.170.41.247/255.255.255.255 gateway 10.64.64.64)
>>> I (170389132) netmanager: Set DNS#0 8.8.8.8
>>> I (170389132) netmanager: Set DNS#1 8.8.4.4
>>> I (170389132) netmanager: WIFI access point is down
>>> I (170389132) esp32wifi: AP stopped
>>> I (170389132) netmanager: CleanupConnections: closing conn 3f81dbbc: interface/link down
>>> I (170389142) netmanager: CleanupConnections: closing conn 3f81dbbc: interface/link down
>>> I (170389142) time: Network was reconfigured: restarting SNTP client
>>> I (170389142) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
>>> I (170389142) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
>>> I (170389152) netmanager: CleanupConnections: closing conn 3f81dbbc: interface/link down
>>> I (170398672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
>>> I (170398672) ovms-server-v2: Status: Connecting...
>>> I (170401312) housekeeping: 2018-07-31 21:01:32 GMT (RAM: 8b=113788-152956 32b=28252)
>>> I (170402032) ovms-server-v2: Connection successful
>>> I (170402032) ovms-server-v2: Status: Logging in...
>>> I (170402032) ovms-server-v2: Sending server login: MP-C 0 xR/s7da9YTwJ+uKH0C2zRl VXtWmVfsQQjJCe4+AwK74w== US33
>>> I (170402852) ovms-server-v2: Got server response: MP-S 0 1uDt9VTVDl5jzvSqsIwmtN isXmd3Gy2AcrvhQVrX3LAA==
>>> I (170402852) ovms-server-v2: Server token is 1uDt9VTVDl5jzvSqsIwmtN and digest is isXmd3Gy2AcrvhQVrX3LAA==
>>> I (170402852) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
>>> I (170402852) ovms-server-v2: Shared secret key is 1uDt9VTVDl5jzvSqsIwmtNxR/s7da9YTwJ+uKH0C2zRl (44 bytes)
>>> I (170402852) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
>>> I (170402872) ovms-server-v2: Incoming Msg: MP-0 Z0
>>> I (170403672) ovms-server-v2: Send MP-0 S70.0,M,65535,127,stopped,standard,166,146,32,0,0,2100,7,21,0,0,0,0,0.00,0,0,0,0,-1,0,0,0,0,0,0,0,0.00,0.00,0
>>> I (170403672) ovms-server-v2: Send MP-0 D65,0,5,23,23,24,587,516256,0,170403,24,0,1,1,11.63,0,12.6,0,23,0
>>> I (170403672) ovms-server-v2: Send MP-0 L37.346340,-122.037308,206,64,1,1,0,0,0.0,0,0
>>> I (170403682) ovms-server-v2: Send MP-0 F3.1.008/ota_0/main (build idf v3.1-dev-986-g1a1a544a Jun 26 2018 09:30:21),5YJRE11B181000033,7,1,TR1N,AT&T Hologram
>>> OVMS# wifi mode client Revelstoke
>>> Starting WIFI as a client to Revelstoke...
>>> I (170432062) wifi: mode : sta (30:ae:a4:43:9c:28)
>>> I (170434462) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
>>> I (170435152) wifi: state: init -> auth (b0)
>>> I (170435162) wifi: state: auth -> assoc (0)
>>> I (170435162) wifi: state: assoc -> run (10)
>>> I (170435202) wifi: connected with Revelstoke, channel 1
>>> I (170435202) wifi: pm start, type: 1
>>> I (170438872) event: sta ip: 192.168.1.82, mask: 255.255.255.0, gw: 192.168.1.254
>>> I (170438872) netmanager: Interface priority is st4 (192.168.1.82/255.255.255.0 gateway 192.168.1.254)
>>> I (170438872) netmanager: Set DNS#0 8.8.8.8
>>> I (170438872) netmanager: Set DNS#1 8.8.4.4
>>> I (170438872) netmanager: WIFI client up (with MODEM up): reconfigured for WIFI client priority
>>> I (170438872) esp32wifi: STA got IP with SSID: Revelstoke, MAC: 30:ae:a4:43:9c:28, IP: 192.168.1.82, mask: 255.255.255.0, gw: 192.168.1.254
>>> I (170438882) time: Network was reconfigured: restarting SNTP client
>>> I (170438882) ovms-server-v2: Network was reconfigured: disconnect, and reconnect in 10 seconds
>>> I (170438882) ovms-server-v2: Status: Network was reconfigured: disconnect, and reconnect in 10 seconds
>>> I (170439082) ovms-server-v2: Status: Disconnected
>>> I (170451362) webserver: HTTP GET /
>>> I (170451572) webserver: HTTP GET /apple-touch-icon.png
>>> I (170451842) webserver: HTTP GET /status
>>> I (170458672) ovms-server-v2: Connection is api.openvehicles.com:6867 US33
>>> I (170458672) ovms-server-v2: Status: Connecting...
>>> I (170458902) ovms-server-v2: Connection successful
>>> I (170458902) ovms-server-v2: Status: Logging in...
>>> I (170458902) ovms-server-v2: Sending server login: MP-C 0 zSgUQypXKd9tYDq7XuHf8m Raby/geQppSUPG5l9NRztw== US33
>>> I (170458922) webserver: HTTP POST /status
>>> I (170458922) webserver: HandleLogin: 'admin' logged in, sid 6ea0f4c3207e3328
>>> I (170459342) ovms-server-v2: Got server response: MP-S 0 ooMhIGTk/0ZEvxVpwoHZ4d 4d+RTkaUZ1onzxLyxVwYEQ==
>>> I (170459342) ovms-server-v2: Server token is ooMhIGTk/0ZEvxVpwoHZ4d and digest is 4d+RTkaUZ1onzxLyxVwYEQ==
>>> I (170459342) ovms-server-v2: Status: Server authentication ok. Now priming crypto.
>>> I (170459342) ovms-server-v2: Shared secret key is ooMhIGTk/0ZEvxVpwoHZ4dzSgUQypXKd9tYDq7XuHf8m (44 bytes)
>>> I (170459342) ovms-server-v2: Status: OVMS V2 login successful, and crypto channel established
>>> I (170459352) ovms-server-v2: Incoming Msg: MP-0 Z0
>>> I (170459352) webserver: HTTP GET /status
>>> I (170459392) webserver: HTTP GET /menu
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180801/d13cc15e/attachment.htm>
