[Ovmsdev] Tesla Cables
Thu Aug 9 12:44:47 HKT 2018
I got the first ten cables from the manufacturer, and they look good. I tried it in a Model S, and all three buses reachable. The Chassis bus in particular looks really useful - things like GPS on there.
I haven’t tried it in a Tesla Roadster yet, but don’t anticipate any issues. I also haven’t tried K-line yet.
If any Model S / Tesla Roadster developers want one, let me know (via private message) and I’ll post one to you.
I’m going to give the go-ahead for the first production run of 100 cables.
> On 24 Jul 2018, at 1:23 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I have a suggested pinout for future Tesla Cables:
> X437 DB9 Signal
> 1 7 CAN0-H
> 2 8 CAN2-H
> 3 1 K-Line
> 4 5 CAN1-H
> 6 2 CAN0-L
> 7 6 CAN2-L
> 9 3 GND
> 10 9 +12V
> 11 4 CAN1-L
> This new cable could work for both Roadster and Model S. The previous pinout did not populate DB9 pins 1, 4, 5, 6, or 8 (so only GND, +12V, CAN0-H, and CAN0-L were connected).
> For Tesla Roadster, that gives us access to all three CAN buses (and opens up a lot of opportunities):
> CAN0 - Instrumentation (VDS, TPMS, etc)
> CAN1 - SwitchPack / PEM
> CAN2 - HVAC and Battery
> K-Line (OBDII K-Line)
> For Tesla Model S and X (2014 and before), that gives us access to three of the four CAN buses (of which the PowerTrain and Chassis seem the most useful, and BodyFaultTolerant has remote climate control module on it):
> CAN0 - PowerTrain CAN bus
> CAN1 - Chassis CAN bus
> CAN2 - BodyFaultTolerant CAN bus
> For new Model S and X (with X437A connector), the DB9 side pinouts should be the same. I am currently trying to source a good supplier for the new style vehicle side connectors.
> I’ve also wired in the K-Line into the unused pin #1 of our DB9 connector (even though that is not currently connected to anything). I am working with China side to see how we can connect that up (either via direct support chip in a future module, or via expansion board). Existing modules would require a mod to work with that (but not too hard to do).
> As usual, suggestions / comments, and double-checking of the pinouts would be most appreciated.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180809/431d10db/attachment.html>
