[Ovmsdev] Initial experience and Nissan Leaf updates
Fri Apr 20 21:37:40 HKT 2018
> You can add a metric for that, i.e. ms_v_env_cabintemp / "v.e.cabintemp".
Done. Added.
> On 20 Apr 2018, at 4:59 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Robin,
> welcome :)
> Am 19.04.2018 um 17:39 schrieb Robin O'Leary:
>> I would like to record the temperature inside the car, but I couldn't
>> see an appropriate metric (I've stuck it on ms_v_charge_temp for now).
>> Is there a better place for it?
> There is ms_v_env_temp for the ambient temperature, but that's normally meant for the outside temperature I think.
>> What is the intent of ms_v_env_on? It was previously set true when
>> certain CAN traffic was present and false after a period of inactivity.
>> I now set it to true when the car is in state "ready to drive".
>> A similar question goes for ms_v_env_awake. I've left this doing the
>> CAN activity detection, which means it changes for minor things like
>> detecting a key-fob.
> "awake" = Vehicle/bus awake (switched on)
> "on" = "Ignition" state (drivable)
>> What is the process for contributing changes? I am currently doing
>> my local work on the master branch cloned from github.
> Normal process is using Github pull requests. You push your commits to you repository, then create a pull request. We check your changes and merge them into the
> master.
> You should coordinate your work with Tom Parker ("carrott"), the main developer of the Nissan Leaf adaption. To do so you can also add his repository and send
> pull requests to him (and vice versa).
> See Github docs for details, it's simple.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180420/431bc62c/attachment.htm>
