[Ovmsdev] Initial experience and Nissan Leaf updates
Tom Parker tom at carrott.org
Fri Apr 20 19:51:18 HKT 2018
On 20/04/18 03:39, Robin O'Leary wrote:
> Since then, I got a development environment set up with remarkably
> little trouble, and I've been adding some new metrics for the Nissan Leaf:
>      * ms_v_bat_soh from 0x5b3[1]
>      * ms_v_charge_temp from 0x54f[0] (this is actually inside temp)
>      * ms_v_door_fl etc. from 0x60d[0]
>      * ms_v_env_gear from 0x421[0]
>      * ms_v_env_handbrake from 0x5c5[0] (was faked by vehicle_nissanleaf_car_on)
>      * ms_v_env_headlights from 0x60d[0,1]
>      * ms_v_env_on from 0x60d[1] (was faked by vehicle_nissanleaf_car_on)
>      ...but continue to fake ms_v_env_awake by CAN activity of 0x284
>      * ms_v_env_locked from 0x60d[2]
>      * ms_v_inv_temp from 0x510[7]
>      * ms_v_tpms_fl_p etc. from 0x385[2..5]
> These all seem to be working nicely (at least, on my UK MY2015).
> I have a few questions:
> I would like to record the temperature inside the car, but I couldn't
> see an appropriate metric (I've stuck it on ms_v_charge_temp for now).
> Is there a better place for it?
> What is the intent of ms_v_env_on?  It was previously set true when
> certain CAN traffic was present and false after a period of inactivity.
> I now set it to true when the car is in state "ready to drive".
> A similar question goes for ms_v_env_awake.  I've left this doing the
> CAN activity detection, which means it changes for minor things like
> detecting a key-fob.
I originally wrote this using a 2012 car and the OVMS v2 on the EV can
bus, and at the time I didn't know about the VCM status information that
is available on the EV bus, so I picked a frame that's only sent when
the car is pretty awake, 0x284 is I believe a relayed message from the
ABS system. When I learnt about the VCM status information, and also the
gear shift status, I didn't bother to update the simple "is the ABS on"
logic that I originally used as it works well.
The v3 code is an almost verbatim port of v2. I've extended it a little
bit here and there but the structure is the same.
I'd be pleased to replace these klunky bits and pieces with more direct
detection of the car's state.
> What is the process for contributing changes?  I am currently doing
> my local work on the master branch cloned from github.
Looking at your pull request I have a couple of comments.
We're using Mark's "Whitesmiths" coding style which does take some
getting used to. Are coding styles discussed in the developer manual
anywhere? Sorry if they're not. Can you add braces to the single line if
statements and spacing around operators. (I'm not anymore using an IDE
that enforces this style so I sometimes fall back to my normal style).
Your comments on 0x5c0 aren't quite right. This /is/ the battery
temperature, I've verified that by modifying the value using a man in
the middle and watching the battery temperature gauge on the instrument
cluster go up and down. It also lines up with the temperatures that you
can poll out of the BMS. You changed the flag check from d[0] == 0x40 to
(d[0]>>6) == 1, I'm just staring at CAN bus captures and on the car's
I've seen, the 0x40 test works but I'm happy to change if there is even
a trivial reason to change, do you have any insight into which test is
better?
I'm already polling the SOH from the BMS with more precision than is
available on 0x5b3, but that calculation needs to know the "new car" Ah
battery size to convert from the current Ah to the SOH. Can you store
the 0x5b3 SOH in a different metric (or a class variable?) to avoid
clobbering the existing SOH value. It would be great if you used the 5b3
SOH to discover the correct battery size. Something like the following
ought to be true for a 30kWh car and false for a 24kWh(CAC / SOH_5b3 *
100) > 70. That would remove the need to configure the correct Ah to get
the SOH calculation to work.
The SOC in 0x1db is a fundamentally different value than that which is
currently calculated by the OVMS. The 1db value is 100% when fully
charged, while what we have now is a percentage of a new car's battery
and the value at full charge goes down over time as the battery
degrades. My 2012 car shows 73% at full charge, while my 2016 car shows
96%. Can you remove this change from your pull request and we can
discuss whether to make it configurable which SOC calculation to use.
See Tom Saxton's reply which convincingly dissuaded me wanting to
switchto "fully charged is 100%":
http://lists.openvehicles.com/pipermail/ovmsdev/2016-May/002993.html
(this discussion that was before I knew SOC was available so I had some
no longer relevant ideas about how to actually implement it).
Did you mean to remove the odometer code? Can you put it back and see if
it works with an odometer in miles, I've only been able to test with my
km odometers.
Thank you for pulling all this new data out of the car CAN bus, I
haven't spent much time on that bus since the v2 hardware couldn't talk
to it!
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180420/e3bd9310/attachment.htm>
