[Ovmsdev] OTA via modem broken
Fri Apr 20 00:23:35 HKT 2018
Mark,
the OTA / job queue overflow issue has no connection to the DNS, I have now verified it to be modem/ppp related.
It is currently 100% reproducable with "ota status" in the shell, which fails to finish when running via modem. The http response comes in at the ppp level but
doesn't get through to the socket.
I assume OTA over modem is currently completely broken, I haven't tried but if the download fails on the version file, chances are it will fail on the firmware
file as well.
Also, when running via Wifi, it skips the first body line (misinterpretation as header line?).
Here's a log of both ways with debug info:
[ota status]
******************* WIFI **********************
D (56183) net: Connect: DNS lookup for host 'api.openvehicles.com'
D (56223) net: Connect: Server api.openvehicles.com is at 202.52.43.188
D (56493) http: Request: method 'GET' server 'api.openvehicles.com' path '/firmware/ota/v3.1/main/ovms3.ver'
D (56503) http: Reading headers...
D (56783) http: Now buffered 1024 bytes
D (56783) http: Request: Got response HTTP/1.1 200 OK
D (56783) http: Request: Got response Server: Apache
D (56793) http: Request: Got response Last-Modified: Tue, 17 Apr 2018 00:38:25 GMT
D (56793) http: Request: Got response Accept-Ranges: bytes
D (56793) http: Request: Got response Cache-Control: max-age=1209600
D (56793) http: Request: Got response Connection: close
D (56793) http: Request: Got response 3.1.004
I (56793) ota: GetStatus: BodyRead=512
I (56793) ota: GetStatus: BodyRead=53
I (56803) ota: GetStatus: BodyRead=244
→ first body line "3.1.004" misinterpreted as header line?
Output:
Running partition: factory
Boot partition:    factory
Firmware:          3.1.004-15-g5d2488f-dirty/factory/main (build idf v3.1-dev-454-gdaef4b5c Apr 19 2018 14:26:14)
Server Available:  - Tesla Model S: Add support for v.bat.soc, v.pos.speed and park/drive status metrics
- Tesla Roadster: Fixes for charge/drive mode on v1.x and v2.x cars
- SD CARD: Provide configurable sdcard parameters:
    sdcard [maxfreq.khz] = 16000         Maximum frequency (in kHz) of SD CARD bus
    sdcard [automount] = yes             Automatically mount SD CARD on insertion
- Boot: store & send crash debug info (*-OVM-DebugCrash records)
- OTA: Support for configurable release tag and server URL
    ota [tag] = main
    ota [server] = api.openvehicles.com/firmware/ota
- Wifi: Increase scan responsiveness (60 seconds -> 10, on first scan)
- Factory reset by SD file "factoryreset.txt" or pushing SW2 for 10 seconds
    Note: SW2 method needs removing any SD card inserted.
- Wifi: fallback to AP mode net "OVMS" password "OVMSinit" after factory reset
- Miscellaneous bug fixes and enhancements
******************* MODEM **********************
D (458063) net: Connect: DNS lookup for host 'api.openvehicles.com'
D (458063) net: Connect: Server api.openvehicles.com is at 202.52.43.188
V (458063) gsm-ppp: tx: 7e 21 45 00 00 2c 00 d4 00 00 ff 06 4d a0 0a 78 | ~!E..,......M..x
V (458063) gsm-ppp: tx: 6c ef ca 34 2b bc d4 86 00 50 00 00 27 42 00 00 | l..4+....P..'B..
V (458063) gsm-ppp: tx: 00 00 60 02 16 70 18 5e 00 00 02 04 05 9c 8e aa | ..`..p.^........
V (458063) gsm-ppp: tx: 7e                                              | ~
V (459033) gsm-ppp: rx: 7e 21 45 00 00 2c 00 00 40 00 2f 06 de 74 ca 34 | ~!E..,.. at ./..t.4
V (459043) gsm-ppp: rx: 2b bc 0a 78 6c ef 00 50 d4 86 58 30 ec da 00 00 | +..xl..P..X0....
V (459043) gsm-ppp: rx: 27 43 60 12 72 10 77 89 00 00 02 04 05 b4 5f 90 | 'C`.r.w......._.
V (459053) gsm-ppp: rx: 7e                                              | ~
V (459053) gsm-ppp: tx: 7e 21 45 00 00 28 00 d5 00 00 ff 06 4d a3 0a 78 | ~!E..(......M..x
V (459053) gsm-ppp: tx: 6c ef ca 34 2b bc d4 86 00 50 00 00 27 43 58 30 | l..4+....P..'CX0
V (459053) gsm-ppp: tx: ec db 50 10 16 70 ea e6 00 00 eb bb 7e          | ..P..p......~
D (459063) http: Request: method 'GET' server 'api.openvehicles.com' path '/firmware/ota/v3.1/main/ovms3.ver'
V (459063) gsm-ppp: tx: 7e 21 45 00 00 8a 00 d6 00 00 ff 06 4d 40 0a 78 | ~!E.........M at .x
V (459063) gsm-ppp: tx: 6c ef ca 34 2b bc d4 86 00 50 00 00 27 43 58 30 | l..4+....P..'CX0
V (459063) gsm-ppp: tx: ec db 50 18 16 70 08 0c 00 00 47 45 54 20 2f 66 | ..P..p....GET /f
V (459063) gsm-ppp: tx: 69 72 6d 77 61 72 65 2f 6f 74 61 2f 76 33 2e 31 | irmware/ota/v3.1
V (459063) gsm-ppp: tx: 2f 6d 61 69 6e 2f 6f 76 6d 73 33 2e 76 65 72 20 | /main/ovms3.ver
V (459063) gsm-ppp: tx: 48 54 54 50 2f 31 2e 30 0d 0a 48 6f 73 74 3a 20 | HTTP/1.0..Host:
V (459063) gsm-ppp: tx: 61 70 69 2e 6f 70 65 6e 76 65 68 69 63 6c 65 73 | api.openvehicles
V (459063) gsm-ppp: tx: 2e 63 6f 6d 0d 0a 55 73 65 72 2d 41 67 65 6e 74 | .com..User-Agent
V (459063) gsm-ppp: tx: 3a 20 6f 76 6d 73 2f 33 0d 0a 0d 0a c6 c1 7e    | : ovms/3......~
D (459073) http: Reading headers...
V (461743) gsm-ppp: tx: 7e 21 45 00 00 8a 00 d7 00 00 ff 06 4d 3f 0a 78 | ~!E.........M?.x
V (461743) gsm-ppp: tx: 6c ef ca 34 2b bc d4 86 00 50 00 00 27 43 58 30 | l..4+....P..'CX0
V (461743) gsm-ppp: tx: ec db 50 18 16 70 08 0c 00 00 47 45 54 20 2f 66 | ..P..p....GET /f
V (461743) gsm-ppp: tx: 69 72 6d 77 61 72 65 2f 6f 74 61 2f 76 33 2e 31 | irmware/ota/v3.1
V (461743) gsm-ppp: tx: 2f 6d 61 69 6e 2f 6f 76 6d 73 33 2e 76 65 72 20 | /main/ovms3.ver
V (461743) gsm-ppp: tx: 48 54 54 50 2f 31 2e 30 0d 0a 48 6f 73 74 3a 20 | HTTP/1.0..Host:
V (461743) gsm-ppp: tx: 61 70 69 2e 6f 70 65 6e 76 65 68 69 63 6c 65 73 | api.openvehicles
V (461743) gsm-ppp: tx: 2e 63 6f 6d 0d 0a 55 73 65 72 2d 41 67 65 6e 74 | .com..User-Agent
V (461743) gsm-ppp: tx: 3a 20 6f 76 6d 73 2f 33 0d 0a 0d 0a 79 21 7e    | : ovms/3....y!~
V (462093) gsm-ppp: rx: 7e 21 45 00 00 28 55 ba 40 00 2f 06 88 be ca 34 | ~!E..(U. at ./....4
V (462093) gsm-ppp: rx: 2b bc 0a 78 6c ef 00 50 d4 86 58 30 ec db 00 00 | +..xl..P..X0....
V (462103) gsm-ppp: rx: 27 a5 50 10 72 10 8e e4 00 00 02 b3 7e          | '.P.r.......~
V (462213) gsm-ppp: rx: 7e 21 45 00 05 1c 55 bb 40 00 2f 06 83 c9 ca 34 | ~!E...U. at ./....4
V (462213) gsm-ppp: rx: 2b bc 0a 78 6c ef 00 50 d4 86 58 30 ec db 00 00 | +..xl..P..X0....
V (462223) gsm-ppp: rx: 27 a5 50 18 72 10 de ad 00 00 48 54 54 50 2f 31 | '.P.r.....HTTP/1
V (462223) gsm-ppp: rx: 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 65 3a | .1 200 OK..Date:
V (462233) gsm-ppp: rx: 20 54 68 75 2c 20 31 39 20 41 70 72 20 32 30 31 |  Thu, 19 Apr 201
V (462233) gsm-ppp: rx: 38 20 31 35 3a 34 36 3a 31 31 20 47 4d 54 0d 0a | 8 15:46:11 GMT..
V (462243) gsm-ppp: rx: 53 65 72 76 65 72 3a 20 41 70 61 63 68 65 0d 0a | Server: Apache..
V (462243) gsm-ppp: rx: 58 2d 43 6f 6e 74 65 6e 74 2d 54 79 70 65 2d 4f | X-Content-Type-O
V (462253) gsm-ppp: rx: 70 74 69 6f 6e 73 3a 20 6e 6f 73 6e 69 66 66 0d | ptions: nosniff.
V (462253) gsm-ppp: rx: 0a 4c 61 73 74 2d 4d 6f 64 69 66 69 65 64 3a 20 | .Last-Modified:
V (462263) gsm-ppp: rx: 54 75 65 2c 20 31 37 20 41 70 72 20 32 30 31 38 | Tue, 17 Apr 2018
V (462263) gsm-ppp: rx: 20 30 30 3a 33 38 3a 32 35 20 47 4d 54 0d 0a 45 |  00:38:25 GMT..E
V (462273) gsm-ppp: rx: 54 61 67 3a 20 22 33 62 63 2d 35 36 61 30 30 38 | Tag: "3bc-56a008
V (462273) gsm-ppp: rx: 65 36 37 61 37 34 63 22 0d 0a 41 63 63 65 70 74 | e67a74c"..Accept
V (462283) gsm-ppp: rx: 2d 52 61 6e 67 65 73 3a 20 62 79 74 65 73 0d 0a | -Ranges: bytes..
V (462283) gsm-ppp: rx: 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 | Content-Length:
V (462293) gsm-ppp: rx: 39 35 36 0d 0a 43 61 63 68 65 2d 43 6f 6e 74 72 | 956..Cache-Contr
V (462293) gsm-ppp: rx: 6f 6c 3a 20 6d 61 78 2d 61 67 65 3d 31 32 30 39 | ol: max-age=1209
V (462303) gsm-ppp: rx: 36 30 30 0d 0a 45 78 70 69 72 65 73 3a 20 54 68 | 600..Expires: Th
V (462303) gsm-ppp: rx: 75 2c 20 30 33 20 4d 61 79 20 32 30 31 38 20 31 | u, 03 May 2018 1
V (462313) gsm-ppp: rx: 35 3a 34 36 3a 31 31 20 47 4d 54 0d 0a 43 6f 6e | 5:46:11 GMT..Con
V (462313) gsm-ppp: rx: 6e 65 63 74 69 6f 6e 3a 20 63 6c 6f 73 65 0d 0a | nection: close..
V (462323) gsm-ppp: rx: 0d 0a 33 2e 31 2e 30 30 34 0a 4f 54 41 20 72 65 | ..3.1.004.OTA re
V (462323) gsm-ppp: rx: 6c 65 61 73 65 20 70 72 6f 76 69 64 69 6e 67 20 | lease providing
V (462333) gsm-ppp: rx: 6d 69 6e 6f 72 20 69 6d 70 72 6f 76 65 6d 65 6e | minor improvemen
V (462333) gsm-ppp: rx: 74 73 20 61 6e 64 20 66 69 78 65 73 2e 0a 0a 2d | ts and fixes...-
V (462343) gsm-ppp: rx: 20 54 65 73 6c 61 20 4d 6f 64 65 6c 20 53 3a 20 |  Tesla Model S:
V (462343) gsm-ppp: rx: 41 64 64 20 73 75 70 70 6f 72 74 20 66 6f 72 20 | Add support for
V (462353) gsm-ppp: rx: 76 2e 62 61 74 2e 73 6f 63 2c 20 76 2e 70 6f 73 | v.bat.soc, v.pos
V (462353) gsm-ppp: rx: 2e 73 70 65 65 64 20 61 6e 64 20 70 61 72 6b 2f | .speed and park/
V (462363) gsm-ppp: rx: 64 72 69 76 65 20 73 74 61 74 75 73 20 6d 65 74 | drive status met
V (462363) gsm-ppp: rx: 72 69 63 73 0a 2d 20 54 65 73 6c 61 20 52 6f 61 | rics.- Tesla Roa
V (462373) gsm-ppp: rx: 64 73 74 65 72 3a 20 46 69 78 65 73 20 66 6f 72 | dster: Fixes for
V (462373) gsm-ppp: rx: 20 63 68 61 72 67 65 2f 64 72 69 76 65 20 6d 6f |  charge/drive mo
V (462383) gsm-ppp: rx: 64 65 20 6f 6e 20 76 31 2e 78 20 61 6e 64 20 76 | de on v1.x and v
V (462383) gsm-ppp: rx: 32 2e 78 20 63 61 72 73 0a 2d 20 53 44 20 43 41 | 2.x cars.- SD CA
V (462393) gsm-ppp: rx: 52 44 3a 20 50 72 6f 76 69 64 65 20 63 6f 6e 66 | RD: Provide conf
V (462393) gsm-ppp: rx: 69 67 75 72 61 62 6c 65 20 73 64 63 61 72 64 20 | igurable sdcard
V (462403) gsm-ppp: rx: 70 61 72 61 6d 65 74 65 72 73 3a 0a 20 20 20 20 | parameters:.
V (462403) gsm-ppp: rx: 73 64 63 61 72 64 20 5b 6d 61 78 66 72 65 71 2e | sdcard [maxfreq.
V (462413) gsm-ppp: rx: 6b 68 7a 5d 20 3d 20 31 36 30 30 30 20 20 20 20 | khz] = 16000
V (462413) gsm-ppp: rx: 20 20 20 20 20 4d 61 78 69 6d 75 6d 20 66 72 65 |      Maximum fre
V (462413) gsm-ppp: rx: 71 75 65 6e 63 79 20 28 69 6e 20 6b 48 7a 29 20 | quency (in kHz)
V (462413) gsm-ppp: rx: 6f 66 20 53 44 20 43 41 52 44 20 62 75 73 0a 20 | of SD CARD bus.
V (462423) gsm-ppp: rx: 20 20 20 73 64 63 61 72 64 20 5b 61 75 74 6f 6d |    sdcard [autom
V (462423) gsm-ppp: rx: 6f 75 6e 74 5d 20 3d 20 79 65 73 20 20 20 20 20 | ount] = yes
V (462433) gsm-ppp: rx: 20 20 20 20 20 20 20 20 41 75 74 6f 6d 61 74 69 |         Automati
V (462433) gsm-ppp: rx: 63 61 6c 6c 79 20 6d 6f 75 6e 74 20 53 44 20 43 | cally mount SD C
V (462443) gsm-ppp: rx: 41 52 44 20 6f 6e 20 69 6e 73 65 72 74 69 6f 6e | ARD on insertion
V (462443) gsm-ppp: rx: 0a 2d 20 42 6f 6f 74 3a 20 73 74 6f 72 65 20 26 | .- Boot: store &
V (462453) gsm-ppp: rx: 20 73 65 6e 64 20 63 72 61 73 68 20 64 65 62 75 |  send crash debu
V (462453) gsm-ppp: rx: 67 20 69 6e 66 6f 20 28 2a 2d 4f 56 4d 2d 44 65 | g info (*-OVM-De
V (462463) gsm-ppp: rx: 62 75 67 43 72 61 73 68 20 72 65 63 6f 72 64 73 | bugCrash records
V (462463) gsm-ppp: rx: 29 0a 2d 20 4f 54 41 3a 20 53 75 70 70 6f 72 74 | ).- OTA: Support
V (462473) gsm-ppp: rx: 20 66 6f 72 20 63 6f 6e 66 69 67 75 72 61 62 6c |  for configurabl
V (462473) gsm-ppp: rx: 65 20 72 65 6c 65 61 73 65 20 74 61 67 20 61 6e | e release tag an
V (462483) gsm-ppp: rx: 64 20 73 65 72 76 65 72 20 55 52 4c 0a 20 20 20 | d server URL.
V (462483) gsm-ppp: rx: 20 6f 74 61 20 5b 74 61 67 5d 20 3d 20 6d 61 69 |  ota [tag] = mai
V (462493) gsm-ppp: rx: 6e 0a 20 20 20 20 6f 74 61 20 5b 73 65 72 76 65 | n.    ota [serve
V (462493) gsm-ppp: rx: 72 5d 20 3d 20 61 70 69 2e 6f 70 65 6e 76 65 68 | r] = api.openveh
V (462503) gsm-ppp: rx: 69 63 6c 65 73 2e 63 6f 6d 2f 66 69 72 6d 77 61 | icles.com/firmwa
V (462503) gsm-ppp: rx: 72 65 2f 6f 74 61 0a 2d 20 57 69 66 69 3a 20 49 | re/ota.- Wifi: I
V (462513) gsm-ppp: rx: 6e 63 72 65 61 73 65 20 73 63 61 6e 20 72 65 73 | ncrease scan res
V (462513) gsm-ppp: rx: 70 6f 6e 73 69 76 65 6e 65 73 73 20 28 36 30 20 | ponsiveness (60
V (462523) gsm-ppp: rx: 7e 21 45 00 00 28 55 bc 40 00 2f 06 88 bc ca 34 | ~!E..(U. at ./....4
V (462523) gsm-ppp: rx: 2b bc 0a 78 6c ef 00 50 d4 86 58 30 f1 cf 00 00 | +..xl..P..X0....
V (462533) gsm-ppp: rx: 27 a5 50 11 72 10 89 ef 00 00 36 7d 5e 7e       | '.P.r.....6}^~
V (462533) gsm-ppp: tx: 7e 21 45 00 00 28 00 d8 00 00 ff 06 4d a0 0a 78 | ~!E..(......M..x
V (462533) gsm-ppp: tx: 6c ef ca 34 2b bc d4 86 00 50 00 00 27 a5 58 30 | l..4+....P..'.X0
V (462533) gsm-ppp: tx: ec db 50 10 16 70 ea 84 00 00 f4 55 7e          | ..P..p.....U~
E (469073) buffer: PollSocket: select result 0 = Timeout
D (469073) http: Now buffered 0 bytes
V (472973) gsm-ppp: rx: 7e 21 45 00 05 1c 55 bd 40 00 2f 06 83 c7 ca 34 | ~!E...U. at ./....4
V (472973) gsm-ppp: rx: 2b bc 0a 78 6c ef 00 50 d4 86 58 30 ec db 00 00 | +..xl..P..X0....
V (472983) gsm-ppp: rx: 27 a5 50 18 72 10 de ad 00 00 48 54 54 50 2f 31 | '.P.r.....HTTP/1
V (472993) gsm-ppp: rx: 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 65 3a | .1 200 OK..Date:
V (473003) gsm-ppp: rx: 20 54 68 75 2c 20 31 39 20 41 70 72 20 32 30 31 |  Thu, 19 Apr 201
V (473003) gsm-ppp: rx: 38 20 31 35 3a 34 36 3a 31 31 20 47 4d 54 0d 0a | 8 15:46:11 GMT..
V (473013) gsm-ppp: rx: 53 65 72 76 65 72 3a 20 41 70 61 63 68 65 0d 0a | Server: Apache..
V (473013) gsm-ppp: rx: 58 2d 43 6f 6e 74 65 6e 74 2d 54 79 70 65 2d 4f | X-Content-Type-O
V (473023) gsm-ppp: rx: 70 74 69 6f 6e 73 3a 20 6e 6f 73 6e 69 66 66 0d | ptions: nosniff.
V (473023) gsm-ppp: rx: 0a 4c 61 73 74 2d 4d 6f 64 69 66 69 65 64 3a 20 | .Last-Modified:
V (473033) gsm-ppp: rx: 54 75 65 2c 20 31 37 20 41 70 72 20 32 30 31 38 | Tue, 17 Apr 2018
V (473033) gsm-ppp: rx: 20 30 30 3a 33 38 3a 32 35 20 47 4d 54 0d 0a 45 |  00:38:25 GMT..E
V (473043) gsm-ppp: rx: 54 61 67 3a 20 22 33 62 63 2d 35 36 61 30 30 38 | Tag: "3bc-56a008
V (473043) gsm-ppp: rx: 65 36 37 61 37 34 63 22 0d 0a 41 63 63 65 70 74 | e67a74c"..Accept
V (473053) gsm-ppp: rx: 2d 52 61 6e 67 65 73 3a 20 62 79 74 65 73 0d 0a | -Ranges: bytes..
V (473053) gsm-ppp: rx: 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 | Content-Length:
V (473063) gsm-ppp: rx: 39 35 36 0d 0a 43 61 63 68 65 2d 43 6f 6e 74 72 | 956..Cache-Contr
V (473063) gsm-ppp: rx: 6f 6c 3a 20 6d 61 78 2d 61 67 65 3d 31 32 30 39 | ol: max-age=1209
V (473073) gsm-ppp: rx: 36 30 30 0d 0a 45 78 70 69 72 65 73 3a 20 54 68 | 600..Expires: Th
V (473073) gsm-ppp: rx: 75 2c 20 30 33 20 4d 61 79 20 32 30 31 38 20 31 | u, 03 May 2018 1
V (473083) gsm-ppp: rx: 35 3a 34 36 3a 31 31 20 47 4d 54 0d 0a 43 6f 6e | 5:46:11 GMT..Con
V (473083) gsm-ppp: rx: 6e 65 63 74 69 6f 6e 3a 20 63 6c 6f 73 65 0d 0a | nection: close..
V (473093) gsm-ppp: rx: 0d 0a 33 2e 31 2e 30 30 34 0a 4f 54 41 20 72 65 | ..3.1.004.OTA re
V (473093) gsm-ppp: rx: 6c 65 61 73 65 20 70 72 6f 76 69 64 69 6e 67 20 | lease providing
V (473103) gsm-ppp: rx: 6d 69 6e 6f 72 20 69 6d 70 72 6f 76 65 6d 65 6e | minor improvemen
V (473103) gsm-ppp: rx: 74 73 20 61 6e 64 20 66 69 78 65 73 2e 0a 0a 2d | ts and fixes...-
V (473113) gsm-ppp: rx: 20 54 65 73 6c 61 20 4d 6f 64 65 6c 20 53 3a 20 |  Tesla Model S:
V (473113) gsm-ppp: rx: 41 64 64 20 73 75 70 70 6f 72 74 20 66 6f 72 20 | Add support for
V (473123) gsm-ppp: rx: 76 2e 62 61 74 2e 73 6f 63 2c 20 76 2e 70 6f 73 | v.bat.soc, v.pos
V (473123) gsm-ppp: rx: 2e 73 70 65 65 64 20 61 6e 64 20 70 61 72 6b 2f | .speed and park/
V (473133) gsm-ppp: rx: 64 72 69 76 65 20 73 74 61 74 75 73 20 6d 65 74 | drive status met
V (473133) gsm-ppp: rx: 72 69 63 73 0a 2d 20 54 65 73 6c 61 20 52 6f 61 | rics.- Tesla Roa
V (473143) gsm-ppp: rx: 64 73 74 65 72 3a 20 46 69 78 65 73 20 66 6f 72 | dster: Fixes for
V (473143) gsm-ppp: rx: 20 63 68 61 72 67 65 2f 64 72 69 76 65 20 6d 6f |  charge/drive mo
V (473153) gsm-ppp: rx: 64 65 20 6f 6e 20 76 31 2e 78 20 61 6e 64 20 76 | de on v1.x and v
V (473153) gsm-ppp: rx: 32 2e 78 20 63 61 72 73 0a 2d 20 53 44 20 43 41 | 2.x cars.- SD CA
V (473163) gsm-ppp: rx: 52 44 3a 20 50 72 6f 76 69 64 65 20 63 6f 6e 66 | RD: Provide conf
V (473163) gsm-ppp: rx: 69 67 75 72 61 62 6c 65 20 73 64 63 61 72 64 20 | igurable sdcard
V (473163) gsm-ppp: rx: 70 61 72 61 6d 65 74 65 72 73 3a 0a 20 20 20 20 | parameters:.
V (473163) gsm-ppp: rx: 73 64 63 61 72 64 20 5b 6d 61 78 66 72 65 71 2e | sdcard [maxfreq.
V (473173) gsm-ppp: rx: 6b 68 7a 5d 20 3d 20 31 36 30 30 30 20 20 20 20 | khz] = 16000
V (473173) gsm-ppp: rx: 20 20 20 20 20 4d 61 78 69 6d 75 6d 20 66 72 65 |      Maximum fre
V (473183) gsm-ppp: rx: 71 75 65 6e 63 79 20 28 69 6e 20 6b 48 7a 29 20 | quency (in kHz)
V (473183) gsm-ppp: rx: 6f 66 20 53 44 20 43 41 52 44 20 62 75 73 0a 20 | of SD CARD bus.
V (473193) gsm-ppp: rx: 20 20 20 73 64 63 61 72 64 20 5b 61 75 74 6f 6d |    sdcard [autom
V (473193) gsm-ppp: rx: 6f 75 6e 74 5d 20 3d 20 79 65 73 20 20 20 20 20 | ount] = yes
V (473203) gsm-ppp: rx: 20 20 20 20 20 20 20 20 41 75 74 6f 6d 61 74 69 |         Automati
V (473203) gsm-ppp: rx: 63 61 6c 6c 79 20 6d 6f 75 6e 74 20 53 44 20 43 | cally mount SD C
V (473213) gsm-ppp: rx: 41 52 44 20 6f 6e 20 69 6e 73 65 72 74 69 6f 6e | ARD on insertion
V (473213) gsm-ppp: rx: 0a 2d 20 42 6f 6f 74 3a 20 73 74 6f 72 65 20 26 | .- Boot: store &
V (473223) gsm-ppp: rx: 20 73 65 6e 64 20 63 72 61 73 68 20 64 65 62 75 |  send crash debu
V (473223) gsm-ppp: rx: 67 20 69 6e 66 6f 20 28 2a 2d 4f 56 4d 2d 44 65 | g info (*-OVM-De
V (473233) gsm-ppp: rx: 62 75 67 43 72 61 73 68 20 72 65 63 6f 72 64 73 | bugCrash records
V (473233) gsm-ppp: rx: 29 0a 2d 20 4f 54 41 3a 20 53 75 70 70 6f 72 74 | ).- OTA: Support
V (473243) gsm-ppp: rx: 20 66 6f 72 20 63 6f 6e 66 69 67 75 72 61 62 6c |  for configurabl
V (473243) gsm-ppp: rx: 65 20 72 65 6c 65 61 73 65 20 74 61 67 20 61 6e | e release tag an
V (473253) gsm-ppp: rx: 64 20 73 65 72 76 65 72 20 55 52 4c 0a 20 20 20 | d server URL.
V (473253) gsm-ppp: rx: 20 6f 74 61 20 5b 74 61 67 5d 20 3d 20 6d 61 69 |  ota [tag] = mai
V (473263) gsm-ppp: rx: 6e 0a 20 20 20 20 6f 74 61 20 5b 73 65 72 76 65 | n.    ota [serve
V (473263) gsm-ppp: rx: 72 5d 20 3d 20 61 70 69 2e 6f 70 65 6e 76 65 68 | r] = api.openveh
V (473273) gsm-ppp: rx: 69 63 6c 65 73 2e 63 6f 6d 2f 66 69 72 6d 77 61 | icles.com/firmwa
V (473273) gsm-ppp: rx: 72 65 2f 6f 74 61 0a 2d 20 57 69 66 69 3a 20 49 | re/ota.- Wifi: I
V (473283) gsm-ppp: rx: 6e 63 72 65 61 73 65 20 73 63 61 6e 20 72 65 73 | ncrease scan res
V (473283) gsm-ppp: rx: 70 6f 6e 73 69 76 65 6e 65 73 73 20 28 36 30 20 | ponsiveness (60
E (479073) buffer: PollSocket: select result 0 = Timeout
D (479073) http: Now buffered 0 bytes
V (482743) gsm-ppp: rx: 7e 21 45 00 00 28 ad 53 40 00 2e 06 cf 1c 0e 98 | ~!E..(.S at .......
V (482743) gsm-ppp: rx: 4a 61 0a 78 6c ef 06 ae a2 10 2d 68 6c f6 97 a6 | Ja.xl.....-hl...
V (482753) gsm-ppp: rx: 77 8b 50 11 00 10 8d 14 00 00 c4 a3 7e          | w.P.........~
V (482753) gsm-ppp: tx: 7e 21 45 00 00 28 00 d9 00 00 ff 06 ea 96 0a 78 | ~!E..(.........x
V (482753) gsm-ppp: tx: 6c ef 0e 98 4a 61 a2 10 06 ae 97 a6 77 8b 2d 68 | l...Ja......w.-h
V (482753) gsm-ppp: tx: 6c f7 50 14 16 70 76 b0 00 00 9f ee 7e          | l.P..pv.....~
V (482773) gsm-ppp: rx: 7e 21 45 00 00 28 ad 54 40 00 2e 06 cf 1b 0e 98 | ~!E..(.T at .......
V (482773) gsm-ppp: rx: 4a 61 0a 78 6c ef 06 ae a2 10 2d 68 6c f6 97 a6 | Ja.xl.....-hl...
V (482773) gsm-ppp: rx: 77 8b 50 11 00 10 8d 14 00 00 de 7f 7e          | w.P.........~
V (482773) gsm-ppp: tx: 7e 21 45 00 00 28 00 da 00 00 ff 06 ea 95 0a 78 | ~!E..(.........x
V (482773) gsm-ppp: tx: 6c ef 0e 98 4a 61 a2 10 06 ae 97 a6 77 8b 2d 68 | l...Ja......w.-h
V (482773) gsm-ppp: tx: 6c f7 50 14 16 70 76 b0 00 00 96 fa 7e          | l.P..pv.....~
V (483163) gsm-ppp: rx: 7e 21 45 00 00 28 ad 53 40 00 2e 06 cf 1c 0e 98 | ~!E..(.S at .......
V (483163) gsm-ppp: rx: 4a 61 0a 78 6c ef 06 ae a2 10 2d 68 6c f6 97 a6 | Ja.xl.....-hl...
V (483173) gsm-ppp: rx: 77 8b 50 11 00 10 8d 14 00 00 c4 a3 7e          | w.P.........~
V (483173) gsm-ppp: tx: 7e 21 45 00 00 28 00 db 00 00 ff 06 ea 94 0a 78 | ~!E..(.........x
V (483173) gsm-ppp: tx: 6c ef 0e 98 4a 61 a2 10 06 ae 97 a6 77 8b 2d 68 | l...Ja......w.-h
V (483173) gsm-ppp: tx: 6c f7 50 14 16 70 76 b0 00 00 9e 0e 7e          | l.P..pv.....~
V (483183) gsm-ppp: rx: 7e 21 45 00 00 28 ad 54 40 00 2e 06 cf 1b 0e 98 | ~!E..(.T at .......
V (483183) gsm-ppp: rx: 4a 61 0a 78 6c ef 06 ae a2 10 2d 68 6c f6 97 a6 | Ja.xl.....-hl...
V (483193) gsm-ppp: rx: 77 8b 50 11 00 10 8d 14 00 00 de 7f 7e          | w.P.........~
V (483193) gsm-ppp: tx: 7e 21 45 00 00 28 00 dc 00 00 ff 06 ea 93 0a 78 | ~!E..(.........x
V (483193) gsm-ppp: tx: 6c ef 0e 98 4a 61 a2 10 06 ae 97 a6 77 8b 2d 68 | l...Ja......w.-h
V (483193) gsm-ppp: tx: 6c f7 50 14 16 70 76 b0 00 00 84 d2 7e          | l.P..pv.....~
E (489073) buffer: PollSocket: select result 0 = Timeout
D (489073) http: Now buffered 0 bytes
V (491443) gsm-ppp: rx: 7e 21 45 00 05 1c 55 be 40 00 2f 06 83 c6 ca 34 | ~!E...U. at ./....4
V (491443) gsm-ppp: rx: 2b bc 0a 78 6c ef 00 50 d4 86 58 30 ec db 00 00 | +..xl..P..X0....
V (491453) gsm-ppp: rx: 27 a5 50 18 72 10 de ad 00 00 48 54 54 50 2f 31 | '.P.r.....HTTP/1
V (491453) gsm-ppp: rx: 2e 31 20 32 30 30 20 4f 4b 0d 0a 44 61 74 65 3a | .1 200 OK..Date:
V (491463) gsm-ppp: rx: 20 54 68 75 2c 20 31 39 20 41 70 72 20 32 30 31 |  Thu, 19 Apr 201
V (491463) gsm-ppp: rx: 38 20 31 35 3a 34 36 3a 31 31 20 47 4d 54 0d 0a | 8 15:46:11 GMT..
V (491473) gsm-ppp: rx: 53 65 72 76 65 72 3a 20 41 70 61 63 68 65 0d 0a | Server: Apache..
V (491473) gsm-ppp: rx: 58 2d 43 6f 6e 74 65 6e 74 2d 54 79 70 65 2d 4f | X-Content-Type-O
V (491483) gsm-ppp: rx: 70 74 69 6f 6e 73 3a 20 6e 6f 73 6e 69 66 66 0d | ptions: nosniff.
V (491483) gsm-ppp: rx: 0a 4c 61 73 74 2d 4d 6f 64 69 66 69 65 64 3a 20 | .Last-Modified:
V (491493) gsm-ppp: rx: 54 75 65 2c 20 31 37 20 41 70 72 20 32 30 31 38 | Tue, 17 Apr 2018
V (491493) gsm-ppp: rx: 20 30 30 3a 33 38 3a 32 35 20 47 4d 54 0d 0a 45 |  00:38:25 GMT..E
V (491503) gsm-ppp: rx: 54 61 67 3a 20 22 33 62 63 2d 35 36 61 30 30 38 | Tag: "3bc-56a008
V (491503) gsm-ppp: rx: 65 36 37 61 37 34 63 22 0d 0a 41 63 63 65 70 74 | e67a74c"..Accept
V (491513) gsm-ppp: rx: 2d 52 61 6e 67 65 73 3a 20 62 79 74 65 73 0d 0a | -Ranges: bytes..
V (491513) gsm-ppp: rx: 43 6f 6e 74 65 6e 74 2d 4c 65 6e 67 74 68 3a 20 | Content-Length:
V (491523) gsm-ppp: rx: 39 35 36 0d 0a 43 61 63 68 65 2d 43 6f 6e 74 72 | 956..Cache-Contr
V (491523) gsm-ppp: rx: 6f 6c 3a 20 6d 61 78 2d 61 67 65 3d 31 32 30 39 | ol: max-age=1209
V (491533) gsm-ppp: rx: 36 30 30 0d 0a 45 78 70 69 72 65 73 3a 20 54 68 | 600..Expires: Th
V (491533) gsm-ppp: rx: 75 2c 20 30 33 20 4d 61 79 20 32 30 31 38 20 31 | u, 03 May 2018 1
V (491543) gsm-ppp: rx: 35 3a 34 36 3a 31 31 20 47 4d 54 0d 0a 43 6f 6e | 5:46:11 GMT..Con
V (491543) gsm-ppp: rx: 6e 65 63 74 69 6f 6e 3a 20 63 6c 6f 73 65 0d 0a | nection: close..
V (491553) gsm-ppp: rx: 0d 0a 33 2e 31 2e 30 30 34 0a 4f 54 41 20 72 65 | ..3.1.004.OTA re
V (491553) gsm-ppp: rx: 6c 65 61 73 65 20 70 72 6f 76 69 64 69 6e 67 20 | lease providing
V (491563) gsm-ppp: rx: 6d 69 6e 6f 72 20 69 6d 70 72 6f 76 65 6d 65 6e | minor improvemen
V (491563) gsm-ppp: rx: 74 73 20 61 6e 64 20 66 69 78 65 73 2e 0a 0a 2d | ts and fixes...-
V (491573) gsm-ppp: rx: 20 54 65 73 6c 61 20 4d 6f 64 65 6c 20 53 3a 20 |  Tesla Model S:
V (491573) gsm-ppp: rx: 41 64 64 20 73 75 70 70 6f 72 74 20 66 6f 72 20 | Add support for
V (491573) gsm-ppp: rx: 76 2e 62 61 74 2e 73 6f 63 2c 20 76 2e 70 6f 73 | v.bat.soc, v.pos
V (491573) gsm-ppp: rx: 2e 73 70 65 65 64 20 61 6e 64 20 70 61 72 6b 2f | .speed and park/
V (491583) gsm-ppp: rx: 64 72 69 76 65 20 73 74 61 74 75 73 20 6d 65 74 | drive status met
V (491583) gsm-ppp: rx: 72 69 63 73 0a 2d 20 54 65 73 6c 61 20 52 6f 61 | rics.- Tesla Roa
V (491593) gsm-ppp: rx: 64 73 74 65 72 3a 20 46 69 78 65 73 20 66 6f 72 | dster: Fixes for
V (491593) gsm-ppp: rx: 20 63 68 61 72 67 65 2f 64 72 69 76 65 20 6d 6f |  charge/drive mo
V (491603) gsm-ppp: rx: 64 65 20 6f 6e 20 76 31 2e 78 20 61 6e 64 20 76 | de on v1.x and v
V (491603) gsm-ppp: rx: 32 2e 78 20 63 61 72 73 0a 2d 20 53 44 20 43 41 | 2.x cars.- SD CA
V (491603) gsm-ppp: rx: 52 44 3a 20 50 72 6f 76 69 64 65 20 63 6f 6e 66 | RD: Provide conf
V (491603) gsm-ppp: rx: 69 67 75 72 61 62 6c 65 20 73 64 63 61 72 64 20 | igurable sdcard
V (491613) gsm-ppp: rx: 70 61 72 61 6d 65 74 65 72 73 3a 0a 20 20 20 20 | parameters:.
V (491613) gsm-ppp: rx: 73 64 63 61 72 64 20 5b 6d 61 78 66 72 65 71 2e | sdcard [maxfreq.
V (491623) gsm-ppp: rx: 6b 68 7a 5d 20 3d 20 31 36 30 30 30 20 20 20 20 | khz] = 16000
V (491623) gsm-ppp: rx: 20 20 20 20 20 4d 61 78 69 6d 75 6d 20 66 72 65 |      Maximum fre
V (491633) gsm-ppp: rx: 71 75 65 6e 63 79 20 28 69 6e 20 6b 48 7a 29 20 | quency (in kHz)
V (491633) gsm-ppp: rx: 6f 66 20 53 44 20 43 41 52 44 20 62 75 73 0a 20 | of SD CARD bus.
V (491643) gsm-ppp: rx: 20 20 20 73 64 63 61 72 64 20 5b 61 75 74 6f 6d |    sdcard [autom
V (491643) gsm-ppp: rx: 6f 75 6e 74 5d 20 3d 20 79 65 73 20 20 20 20 20 | ount] = yes
V (491653) gsm-ppp: rx: 20 20 20 20 20 20 20 20 41 75 74 6f 6d 61 74 69 |         Automati
V (491653) gsm-ppp: rx: 63 61 6c 6c 79 20 6d 6f 75 6e 74 20 53 44 20 43 | cally mount SD C
V (491663) gsm-ppp: rx: 41 52 44 20 6f 6e 20 69 6e 73 65 72 74 69 6f 6e | ARD on insertion
V (491663) gsm-ppp: rx: 0a 2d 20 42 6f 6f 74 3a 20 73 74 6f 72 65 20 26 | .- Boot: store &
V (491673) gsm-ppp: rx: 20 73 65 6e 64 20 63 72 61 73 68 20 64 65 62 75 |  send crash debu
V (491673) gsm-ppp: rx: 67 20 69 6e 66 6f 20 28 2a 2d 4f 56 4d 2d 44 65 | g info (*-OVM-De
V (491683) gsm-ppp: rx: 62 75 67 43 72 61 73 68 20 72 65 63 6f 72 64 73 | bugCrash records
V (491683) gsm-ppp: rx: 29 0a 2d 20 4f 54 41 3a 20 53 75 70 70 6f 72 74 | ).- OTA: Support
V (491693) gsm-ppp: rx: 20 66 6f 72 20 63 6f 6e 66 69 67 75 72 61 62 6c |  for configurabl
V (491693) gsm-ppp: rx: 65 20 72 65 6c 65 61 73 65 20 74 61 67 20 61 6e | e release tag an
V (491703) gsm-ppp: rx: 64 20 73 65 72 76 65 72 20 55 52 4c 0a 20 20 20 | d server URL.
V (491703) gsm-ppp: rx: 20 6f 74 61 20 5b 74 61 67 5d 20 3d 20 6d 61 69 |  ota [tag] = mai
V (491713) gsm-ppp: rx: 6e 0a 20 20 20 20 6f 74 61 20 5b 73 65 72 76 65 | n.    ota [serve
V (491713) gsm-ppp: rx: 72 5d 20 3d 20 61 70 69 2e 6f 70 65 6e 76 65 68 | r] = api.openveh
V (491723) gsm-ppp: rx: 69 63 6c 65 73 2e 63 6f 6d 2f 66 69 72 6d 77 61 | icles.com/firmwa
V (491723) gsm-ppp: rx: 72 65 2f 6f 74 61 0a 2d 20 57 69 66 69 3a 20 49 | re/ota.- Wifi: I
V (491733) gsm-ppp: rx: 6e 63 72 65 61 73 65 20 73 63 61 6e 20 72 65 73 | ncrease scan res
V (491733) gsm-ppp: rx: 70 6f 6e 73 69 76 65 6e 65 73 73 20 28 36 30 20 | ponsiveness (60
E (499073) buffer: PollSocket: select result 0 = Timeout
D (499073) http: Now buffered 0 bytes
E (509073) buffer: PollSocket: select result 0 = Timeout
D (509073) http: Now buffered 0 bytes
E (519073) buffer: PollSocket: select result 0 = Timeout
D (519073) http: Now buffered 0 bytes
… and so on, command doesn't finish
Am 19.04.2018 um 01:50 schrieb Mark Webb-Johnson:
> Do you have a DNS server set on the module?
> I think we should probably use 8.8.8.8 and 8.8.4.4 by default.
>     https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/43
>> On 19 Apr 2018, at 12:46 AM, Greg D. <gregd2350 at gmail.com <mailto:gregd2350 at gmail.com>> wrote:
>> Michael Balzer wrote:
>>> Am 16.04.2018 um 22:16 schrieb Michael Balzer:
>>>> I have seen the queue overflow problem once on the current build, so it isn't solved. But it wasn't related to any action, it happened while
>>>> the module was idle.
>>>> To clarify, it's no problem if it resolves after some seconds, that may be due to a temporary mongoose lock / overload. If we can trigger that
>>>> reliably by some action, that would help to track this down.
>>> Short update: I could trigger it again now multiple times on the OTA page. It seems to be happening due to the update check running over the
>>> modem line, it does not happen with modem disabled. I need to check in Wifi client mode.
>> Hi Michael,
>> Interesting...  I was going to write back and say that the 3.003 to 3.004 update went very smoothly, with no queue overflows being reported, and that all was
>> well.  I don't recall if the modem was connected at the time, however.
>> A side note for anyone having trouble connecting to AP mode with their cell phone...  I've always had a lot of trouble with timeouts and such, and finally
>> tracked it down to a similar issue as above.  If the phone has both an LTE and AP connection, the http request to 192.168.4.1 often goes out over the LTE
>> path, and is therefore doomed.  Disabling LTE "fixes" that, but of course, also disables your phone.(or at least the data part).  I haven't found a good way
>> to beat some (routing) sense into the phone otherwise.
>> This was with my new Google Pixel2, so it's not a matter of an old buggy device.  (Ok, so it's a new buggy device...)
>> Also, the first time you connect to the AP, the phone /blocks/ all communications with it until you answer the annoying notification (usually hidden in the
>> background) that says "Hey, we can't get to the Internet with that AP.  Are you sure you want to stay connected to it?", or words to that effect.  Me thinks
>> they have taken this always connected Internet meme a bit too far.
>> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180419/bec0f7b7/attachment.htm>
