[Ovmsdev] Some warning/error messages
Sat Apr 14 22:17:47 HKT 2018
I see this too. I’m guessing it is a bug in the ESP IDF version we pulled at last merge.
I enabled the option for MD5 checksums on the partition table, for production builds, and it seems to be working (looking at the generated partitions.bin). It also validates correctly.
I think this is just a facility to disable the generation of MD5 checksums, and the MD5_OPT variable is not set empty when using MD5 checksums. Should not impact operation.
Once the next OTA firmware release goes out, I intend to try another upstream merge for the IDF. Just a bit scary as historically they have broken stuff.
> On 14 Apr 2018, at 6:38 AM, Stephen Casner <casner at acm.org> wrote:
> Item 1: When running "make flash" I see the following warning:
> Running make flash...
> /Users/casner/src/github/esp-idf/components/partition_table/Makefile.projbuild:16: warning: undefined variable `MD5_OPT'
> Flashing binaries to serial port /dev/cu.SLAB_USBtoUART (app at offset 0x10000)...
> A grep for MD5_OPT in the esp-idf source tree only finds the two
> instances in Makefile.projbuild, so it looks like is not defined
> anywhere if CONFIG_PARTITION_TABLE_MD5=y.
> Do others see this warning? If not, I must need to update something.
> Item 2: I don't have an SD card installed, but I see the following
> errors at boot time (with current Master sources):
> I (2492) sdcard: SD CARD has been inserted
> E (2532) sdmmc_req: handle_idle_state_events unhandled: 00000004 00000000
> E (2532) sdmmc_cmd: sdmmc_card_init: send_op_cond (1) returned 0x107
> -- Steve
