[Ovmsdev] ssh: secure mode prompt not set #31
Tom Saxton
tom at idleloop.com
Tue Apr 10 23:38:09 HKT 2018
Do you get a calculated amp-hour capacity (CAC) value on the Model S?
Tom
-----Original Message-----
From: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> on behalf of Mark Webb-Johnson <mark at webb-johnson.net>
Reply-To: OVMS Developers <ovmsdev at lists.openvehicles.com>
Date: Tuesday, April 10, 2018 at 1:30 AM
To: Stephen & Karen Casner <casner at acm.org>
Cc: OVMS Developers <ovmsdev at lists.openvehicles.com>
Subject: Re: [Ovmsdev] ssh: secure mode prompt not set #31
Thanks, Steve. I will try it in a few minutes.
P.S. I’m about to drive home in my Model S, with the vehicle module actually running for the first time. I’ve got speed, soc, and park/drive support working on Tesla Model S (probably) so will finally have something to see on the web dashboard.
> On 10 Apr 2018, at 2:41 PM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> What this really means is that my previous implementation of the
> secure mode prompt was in the wrong place. I've fixed it, isolating
> the setting of the prompt into OvmsShell. This removes the
> SetPrompt() API from OvmsWriter, which is good, at the cost of making
> SetSecure() virtual.
> -- Steve
> On Tue, 10 Apr 2018, Mark Webb-Johnson wrote:
>> Steve,
>> Can you have a look at this one:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/31 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/31>
>> When connecting to the box via ssh, using a trusted ssh.keys mechanism, it seems that the session is correctly put into secure mode (enable). But, the prompt is OVMS> (should be OVMS#). The full set of enable commands is shown, so pretty sure the session is in enable mode.
>> I think the issue is purely the prompt being incorrect.
>> I think (hope) it should be simple.
>> Thanks, Mark.
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
