[Ovmsdev] ssh: secure mode prompt not set #31
Tue Apr 10 16:30:07 HKT 2018
Thanks, Steve. I will try it in a few minutes.
P.S. I’m about to drive home in my Model S, with the vehicle module actually running for the first time. I’ve got speed, soc, and park/drive support working on Tesla Model S (probably) so will finally have something to see on the web dashboard.
> On 10 Apr 2018, at 2:41 PM, Stephen Casner <casner at acm.org> wrote:
> Mark,
> What this really means is that my previous implementation of the
> secure mode prompt was in the wrong place. I've fixed it, isolating
> the setting of the prompt into OvmsShell. This removes the
> SetPrompt() API from OvmsWriter, which is good, at the cost of making
> SetSecure() virtual.
> -- Steve
> On Tue, 10 Apr 2018, Mark Webb-Johnson wrote:
>> Steve,
>> Can you have a look at this one:
>> https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/31 <https://github.com/openvehicles/Open-Vehicle-Monitoring-System-3/issues/31>
>> When connecting to the box via ssh, using a trusted ssh.keys mechanism, it seems that the session is correctly put into secure mode (enable). But, the prompt is OVMS> (should be OVMS#). The full set of enable commands is shown, so pretty sure the session is in enable mode.
>> I think the issue is purely the prompt being incorrect.
>> I think (hope) it should be simple.
>> Thanks, Mark.
