[Ovmsdev] Lost both modem and WiFi
Tue Apr 10 11:01:29 HKT 2018
Do you have a auto-start enabled for both modem and wifi?
Perhaps the module is rebooting (panic crash), and restarting?
I suggest when you get back into the module (and find modem and wifi powered down), you check these commands:
boot status
simcom status
wifi status
config list auto
and let us see the output.
> On 10 Apr 2018, at 5:16 AM, Greg D. <gregd2350 at gmail.com> wrote:
> Hi folks,
> This occurred twice over the weekend... I took a trip in my Roadster
> with the OVMSv3 module hooked up. After the drive, I went to check on
> the car via the Android application, and it wouldn't connect. Thought
> perhaps it wasn't getting a good 3G signal where it was, and forgot
> about it overnight. But when I checked again in the morning, sill no
> connection. I looked in the car and saw that the modem was off (nothing
> blinking). Unplugged the module, and plugged it back in. All fine at
> that point. Charged the car for the trip home, and was able to monitor
> the charging just fine.
> Drove home late Sunday night, and when I looked at it again this morning
> (Monday), no modem blinks. Also failed connecting to it on the home
> WiFi, which it is configured to automatically connect to. I hooked up a
> serial port to the USB connector, and found that the module was running
> (OVMS prompts), but both the modem and wifi were reporting their status
> powered off!
> I just updated to today's code, and will try to reproduce the issue. In
> the mean time, any ideas what is going on? I do have scripts to control
> the ext12v power with vehicle_on and vehicle_off (to manage a HUD), but
> the HUD was not attached.
> Greg
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180410/8cf993e4/attachment.htm>
