[Ovmsdev] OTA status check timeout / SSL problem?
Tom Saxton
tom at idleloop.com
Fri Apr 6 22:57:21 HKT 2018
I don’t have the full context for this discussion, but I’m wondering: is the OTA update mechanism protected against a man-in-the-middle attack?
Tom
From: OvmsDev <ovmsdev-bounces at lists.openvehicles.com> on behalf of Mark Webb-Johnson <mark at webb-johnson.net>
Reply-To: OVMS Developers <ovmsdev at lists.openvehicles.com>
Date: Wednesday, April 4, 2018 at 11:51 PM
Subject: Re: [Ovmsdev] OTA status check timeout / SSL problem?
I think it was a fault on the api.openvehicles.com config - that shouldn’t be redirecting to https.
I fixed it, and it should be ok now.
On 5 Apr 2018, at 12:44 AM, Michael Balzer <dexter at expeedo.de> wrote:
Mark,
the server check for an OTA update now fails every time, times out after 10 seconds.
I think that's because the new server currently does a redirect from http to https also on the api.openvehicles.com host. Not sure why the module doesn't fail
directly on that, maybe it tries to validate the certificate which also does not match.
As the openvehicles server has frequent connectivity issues from here I've added a "nocheck" option to the ota status command and use that for the standard web
status page. The OTA page still checks for the update.
OvmsDev mailing list
OvmsDev at lists.openvehicles.com
_______________________________________________ OvmsDev mailing list OvmsDev at lists.openvehicles.com http://lists.openvehicles.com/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180406/d03543e0/attachment.htm>
