[Ovmsdev] OTA status check timeout / SSL problem?
Thu Apr 5 14:51:21 HKT 2018
I think it was a fault on the api.openvehicles.com <http://api.openvehicles.com/> config - that shouldn’t be redirecting to https.
I fixed it, and it should be ok now.
> On 5 Apr 2018, at 12:44 AM, Michael Balzer <dexter at expeedo.de> wrote:
> Mark,
> the server check for an OTA update now fails every time, times out after 10 seconds.
> I think that's because the new server currently does a redirect from http to https also on the api.openvehicles.com host. Not sure why the module doesn't fail
> directly on that, maybe it tries to validate the certificate which also does not match.
> As the openvehicles server has frequent connectivity issues from here I've added a "nocheck" option to the ota status command and use that for the standard web
> status page. The OTA page still checks for the update.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180405/53fd7d56/attachment.htm>
