[Ovmsdev] Automatic vehicle notifications
Wed Apr 25 14:45:04 HKT 2018
We can also add the "sufficient SOC/range reached" notifications, the low SOC alert and the low 12V alert to the framework.
Porting the low 12V detection is on my list for today/tomorrow. For the sufficient SOC/range notifications, I currently still (mis-)use the topoff state, which
is irritating to users.
Notification config should include a channel selection for each, so users can choose which of them to get by SMS. May be combinable, i.e. instead of a bool, use
a set of ("ip", "sms")?
Am 25.04.2018 um 03:13 schrieb Mark Webb-Johnson:
> It is time to implement vehicle notifications (charge started, charge completed, charge interrupted, etc) in the vehicle modules I am supporting. It seems
> that this can be done in the vehicle.{h,cpp} framework in a standard manner, and work across all vehicle types. However, I guess that will break any
> notifications already being produced by other vehicle types.
> My suggestion is:
> 1. A config parameter ‘notifications’, with individual instances to turn on/off the notifications. Default is all enabled.
> 2. OvmsVehicle::MetricModified picks up metric changes and issues the standard notifications (checking ‘notifications’ parameter appropriately).
> * charge_mode=>charging: Notify charge started
> * charge_mode=>topoff: Notify charge started
> * charge_mode=>heating: Notify battery heating started
> * charge_mode=>done: Notify charge completed
> * charge_mode=>stopped: Notify charge interrupted
> * valet_mode=>on: Notify valet mode enabled
> * valet_mode=>off: Notify valet mode disabled
> * alarm=>on: Notify alarm is sounding
> * alarm=>off: Notify alarm is off
> 3. All the above should be suppressed for the initial setting of each parameter. I will have to look into metrics to see how best that should be done; one
> neat way is to keep a modification count (rather than the current m_defined boolean).
> Does that make sense? Any objections/suggestions?
> Regards, Mark
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180425/a512bd9a/attachment.html>
