[Ovmsdev] OT: A tool for exploring data graphically
Stephen Casner
casner at acm.org
Sun Apr 22 10:41:49 HKT 2018
Another software project I've been working on recently (timesharing
computer time with OVMS) is a little data graphing program named
"graf" for use in X11 environments. It's one that I've used for work
and personal data exploration over the past couple of decades, but
recently I added several enhancements. It is quite lightweight, using
only the base Xlib library and protocol, so it can display large
datasets without choking.
You folks may have your own favorite fancy graphing tools; this one
has a somewhat different purpose than most. It is designed for data
exploration more than presentation, using mouse functions to measure
the distance between points or the slope of a line or calculate the
least-squares regression line for a dataset or to zoom in on a section
of the graph for a closer view. It takes a simple text file as input
with an (x,y) pair of numbers on each line so it is easy to feed it
with the output of a script, or it will accept multiple files as input
to show each as a separate line on the graph.
One unusual feature that was part of the recent enhancements is the
ability to interpret Unix-style timestamps (based at 1970-01-01
00:00:00 GMT) as dates and times and to generate dynamic grid labels
with varying temporal resolution depending upon what unit boundary the
grid line represents. The motivation for varying the resolution is
that to show a complete date and time down to microseconds takes too
many characters to fit on each grid line.
Each grid line label on the X axis shows the increment of time at the
scale that allows the labels to fit, while at the left and right edges
an additional label shows the remaining date and time information not
included in the grid line labels. The format of the labels will vary
to show a larger scale value on the even boundaries and as you zoom in
the detail changes. Examples:
09/01 2014 03/01 06/01 09/01
2013 2014
22:30 23:00 23:30 04/26 00:30 01:00
2014-04-25 2014-04-26
45.000 50.000 55.000 23:56 05.000 10.000 15.000 20.000 25.000
2014-04-25 23:55: 2014-04-25 23:56:
Although this varying format is not common, I think it is a pretty
neat idea. In the actual graph window I use three levels of gray for
the grid labels so the major boundaries are emphasized. And in local
time, the DST transitions are handled properly (that was a challenge)
by varying the grid spacing if needed.
If you have an X11-Unix-ish environment and would like to try it out,
the source is here (build it with ./configure then make):
https://github.com/kernelsid/graf
Or, I have MacOS and linux (CentOS) binaries here:
http://casners.us/macos/graf
http://casners.us/linxu/graf
Try "graf -h" to see the usage text and Ctrl-H, ? or F1 in the window
when running to pop up another window describing the mouse and
keyboard functions. A three-button mouse or simulation thereof is
needed to access the functions on the middle button.
I've attached two data files that you could try along with a third
that you could download since it is bigger than I want to put in
email:
1) The first graph has a bunch of data lines for all the telemetry
parameters collected from my Tesla Roadster log while driving on the
track at Laguna Seca in the time trial event at ReFuel 2011.
2) The second dataset contains timestamps with fractional second
resolution. This produces a graph of the difference between the
internal-clock-based timestamps contained in the datastream generated
by the little 8-pin PIC microcontroller that I used to extract the
data from the two meters on our home solar PV system and NTP-derived
timestamps in the computer that collects the datastream. The latter
timestamps only have a resolution of one second, hence the +/-500ms
noise. This is a good dataset for testing the linear regression
function.
3) The third graph shows the output of the solar PV system on our home
for a period of 7 days as measured in Amps as displayed on the meters
connected to the left and right strings of panels in our system. This
dataset demonstrates graf's speed since it contains 1.2 million
datapoints, but that means the file is 49MB so rather than attaching
it to this email I have it available for download from:
http://casners.us/amps.graf
If you want to run graf with these datasets, I suggest invoking it
with "graf -Lmt" plus the dataset filename to select the X axis date
display in local time and to show a small icon at each datapoint. I
usually also include -t because I prefer just tickmarks rather than
full grid lines most of the time.
I also attached a screenshot of the first graph so you can at least
see a static image if you don't want to try to run the program.
# Time-Trial Lap at Laguna Seca, ReFuel 2011
# speed mph
1309127537 35.4
1309127538 32.9
1309127539 33.2
1309127540 41.7
1309127541 53.1
1309127542 62.9
1309127543 70.4
1309127544 77.3
1309127545 83.5
1309127546 88.1
1309127547 92.4
1309127548 95.3
1309127549 98.0
1309127550 100.2
1309127551 101.1
1309127552 103.1
1309127553 105.2
1309127554 100.6
1309127555 93.0
1309127556 84.0
1309127557 73.2
1309127558 59.7
1309127559 50.1
1309127560 44.9
1309127561 42.8
1309127562 40.9
1309127563 43.1
1309127564 46.9
1309127565 52.1
1309127566 60.1
1309127567 65.4
1309127568 69.4
1309127569 71.9
1309127570 64.2
1309127571 57.4
1309127572 55.0
1309127573 52.0
1309127574 53.4
1309127575 58.6
1309127576 67.0
1309127577 74.6
1309127578 80.1
1309127579 78.1
1309127580 72.7
1309127581 70.0
1309127582 67.6
1309127583 64.6
1309127584 71.1
1309127586 77.4
1309127587 82.7
1309127588 87.5
1309127589 91.4
1309127590 95.3
1309127591 98.0
1309127592 93.5
1309127593 77.4
1309127594 64.2
1309127595 61.1
1309127596 59.9
1309127597 59.2
1309127598 59.8
1309127599 65.7
1309127600 72.2
1309127601 77.1
1309127602 81.3
1309127603 85.8
1309127604 89.0
1309127605 88.1
1309127606 76.2
1309127607 67.1
1309127608 64.7
1309127609 64.6
1309127610 71.4
1309127611 76.6
1309127612 80.5
1309127613 82.7
1309127614 85.2
1309127615 86.6
1309127616 89.3
1309127617 91.8
1309127618 93.7
1309127619 89.0
1309127620 75.7
1309127621 57.8
1309127622 41.3
1309127623 23.9
1309127624 19.8
1309127625 29.6
1309127626 37.0
1309127627 45.5
1309127628 54.2
1309127629 56.9
1309127630 59.2
1309127631 57.7
1309127633 54.6
1309127634 52.3
1309127635 53.2
1309127636 58.8
1309127637 61.1
1309127638 64.5
1309127639 71.0
1309127640 77.9
1309127641 82.8
1309127642 77.2
1309127643 66.9
1309127644 60.5
1309127645 60.0
1309127646 61.6
1309127647 68.3
1309127648 75.1
1309127649 81.1
1309127650 83.5
1309127651 68.8
1309127652 51.4
1309127653 37.6
1309127654 30.6
1309127655 29.7
1309127656 33.7
1309127657 44.6
1309127658 55.5
1309127659 63.8
1309127660 70.4
1309127661 76.2
1309127662 81.3
1309127663 85.4
1309127664 89.0
1309127665 92.3
1309127666 94.3
1309127667 95.7
1309127668 96.3
1309127669 98.5
1309127670 101.2
1309127671 103.7
1309127672 103.2
1309127673 89.2
1309127674 74.1
# pedal %
1309127537 -5.0
1309127538 71.5
1309127539 99.6
1309127540 99.6
1309127541 99.6
1309127542 99.6
1309127543 99.6
1309127544 99.6
1309127545 99.6
1309127546 99.6
1309127547 99.6
1309127548 99.6
1309127549 99.6
1309127550 99.6
1309127551 99.6
1309127552 99.6
1309127553 18.4
1309127554 0.0
1309127555 0.0
1309127556 0.0
1309127557 0.0
1309127558 -5.0
1309127559 -5.0
1309127560 0.0
1309127561 9.0
1309127562 27.7
1309127563 58.2
1309127564 98.0
1309127565 80.5
1309127566 76.6
1309127567 55.5
1309127568 53.5
1309127569 37.9
1309127570 0.0
1309127571 -5.0
1309127572 0.0
1309127573 0.8
1309127574 66.4
1309127575 98.0
1309127576 99.6
1309127577 99.6
1309127578 95.7
1309127579 28.9
1309127580 -5.0
1309127581 0.0
1309127582 0.0
1309127583 73.4
1309127584 87.9
1309127586 87.1
1309127587 87.5
1309127588 98.0
1309127589 98.8
1309127590 98.8
1309127591 99.6
1309127592 0.0
1309127593 0.0
1309127594 -5.0
1309127595 32.8
1309127596 22.7
1309127597 55.5
1309127598 84.4
1309127599 99.6
1309127600 99.6
1309127601 99.6
1309127602 99.6
1309127603 99.6
1309127604 99.6
1309127605 12.9
1309127606 0.0
1309127607 -5.0
1309127608 16.4
1309127609 41.8
1309127610 95.3
1309127611 99.6
1309127612 99.6
1309127613 99.6
1309127614 99.6
1309127615 99.6
1309127616 99.6
1309127617 99.6
1309127618 99.6
1309127619 -5.0
1309127620 -5.0
1309127621 -5.0
1309127622 -5.0
1309127623 -5.0
1309127624 0.0
1309127625 51.2
1309127626 42.6
1309127627 72.3
1309127628 81.2
1309127629 30.5
1309127630 0.0
1309127631 0.0
1309127633 0.0
1309127634 0.0
1309127635 37.9
1309127636 46.5
1309127637 21.9
1309127638 60.9
1309127639 62.1
1309127640 67.2
1309127641 41.0
1309127642 0.0
1309127643 -5.0
1309127644 0.0
1309127645 28.9
1309127646 95.7
1309127647 99.6
1309127648 99.6
1309127649 99.6
1309127650 25.8
1309127651 0.0
1309127652 0.0
1309127653 0.0
1309127654 0.0
1309127655 51.2
1309127656 99.6
1309127657 99.6
1309127658 99.6
1309127659 99.6
1309127660 99.6
1309127661 99.6
1309127662 99.6
1309127663 99.6
1309127664 99.6
1309127665 99.6
1309127666 99.6
1309127667 99.6
1309127668 99.6
1309127669 99.6
1309127670 99.6
1309127671 99.6
1309127672 -5.0
1309127673 0.0
1309127674 0.0
# mot amps/8
1309127537 3.0
1309127538 5.0
1309127539 47.4
1309127540 72.3
1309127541 84.5
1309127542 75.2
1309127543 71.4
1309127544 68.9
1309127545 66.7
1309127546 64.9
1309127547 63.7
1309127548 62.5
1309127549 61.0
1309127550 60.3
1309127551 59.6
1309127552 58.4
1309127553 -15.6
1309127554 -10.5
1309127555 -10.9
1309127556 -11.4
1309127557 -12.7
1309127558 5.5
1309127559 3.1
1309127560 3.0
1309127561 -5.8
1309127562 20.7
1309127563 34.4
1309127564 45.1
1309127565 50.7
1309127566 65.1
1309127567 34.5
1309127568 41.4
1309127569 -15.1
1309127570 10.5
1309127571 3.6
1309127572 -5.9
1309127573 26.4
1309127574 30.3
1309127575 59.7
1309127576 72.3
1309127577 69.8
1309127578 57.2
1309127579 -12.5
1309127580 3.3
1309127581 3.7
1309127582 3.2
1309127583 36.7
1309127584 67.9
1309127586 66.2
1309127587 64.6
1309127588 65.0
1309127589 64.0
1309127590 62.2
1309127591 60.6
1309127592 -12.6
1309127593 -12.1
1309127594 3.3
1309127595 17.3
1309127596 9.8
1309127597 28.3
1309127598 41.4
1309127599 70.8
1309127600 70.7
1309127601 68.6
1309127602 67.0
1309127603 65.4
1309127604 64.3
1309127605 -14.3
1309127606 -12.1
1309127607 3.8
1309127608 -3.0
1309127609 60.8
1309127610 70.7
1309127611 68.7
1309127612 67.2
1309127613 66.3
1309127614 66.2
1309127615 65.0
1309127616 64.3
1309127617 63.2
1309127618 62.0
1309127619 11.0
1309127620 3.3
1309127621 3.1
1309127622 2.9
1309127623 2.8
1309127624 29.0
1309127625 68.1
1309127626 28.1
1309127627 53.1
1309127628 32.6
1309127629 23.5
1309127630 -15.5
1309127631 -15.7
1309127633 -16.3
1309127634 -16.9
1309127635 23.6
1309127636 37.8
1309127637 9.6
1309127638 53.2
1309127639 55.6
1309127640 55.8
1309127641 -28.1
1309127642 -8.4
1309127643 3.2
1309127644 3.0
1309127645 16.7
1309127646 44.1
1309127647 70.7
1309127648 68.7
1309127649 66.2
1309127650 -18.3
1309127651 -12.9
1309127652 -16.3
1309127653 -19.7
1309127654 -5.3
1309127655 29.7
1309127656 53.4
1309127657 88.0
1309127658 75.2
1309127659 66.2
1309127660 63.1
1309127661 60.3
1309127662 58.0
1309127663 55.9
1309127664 54.5
1309127665 52.7
1309127666 51.2
1309127667 49.9
1309127668 48.5
1309127669 47.0
1309127670 45.3
1309127671 43.9
1309127672 -15.9
1309127673 -11.1
1309127674 -13.2
# bat -amps/8
1309127537 0.4
1309127538 1.3
1309127539 26.8
1309127540 52.9
1309127541 81.3
1309127542 76.5
1309127543 73.3
1309127544 70.2
1309127545 67.3
1309127546 65.2
1309127547 63.6
1309127548 62.0
1309127549 60.6
1309127550 59.6
1309127551 58.7
1309127552 57.6
1309127553 -5.8
1309127554 -9.4
1309127555 -9.7
1309127556 -9.6
1309127557 -9.9
1309127558 0.6
1309127559 0.5
1309127560 0.4
1309127561 -1.2
1309127562 11.2
1309127563 21.8
1309127564 32.4
1309127565 42.3
1309127566 64.9
1309127567 29.4
1309127568 37.1
1309127569 -3.7
1309127570 1.8
1309127571 0.5
1309127572 -1.3
1309127573 21.1
1309127574 22.2
1309127575 64.3
1309127576 74.4
1309127577 71.2
1309127578 52.6
1309127579 -9.9
1309127580 0.6
1309127581 0.6
1309127582 0.6
1309127583 42.6
1309127584 70.8
1309127586 67.8
1309127587 65.6
1309127588 65.1
1309127589 63.7
1309127590 61.7
1309127591 60.1
1309127592 -9.5
1309127593 -10.0
1309127594 0.6
1309127595 13.4
1309127596 2.5
1309127597 21.6
1309127598 40.6
1309127599 74.5
1309127600 72.4
1309127601 69.7
1309127602 67.8
1309127603 65.9
1309127604 64.3
1309127605 -9.8
1309127606 -9.9
1309127607 0.6
1309127608 0.0
1309127609 70.2
1309127610 72.5
1309127611 70.0
1309127612 68.1
1309127613 66.9
1309127614 66.0
1309127615 65.2
1309127616 64.2
1309127617 62.8
1309127618 61.6
1309127619 1.1
1309127620 0.7
1309127621 0.6
1309127622 0.5
1309127623 0.4
1309127624 12.0
1309127625 39.0
1309127626 14.2
1309127627 43.6
1309127628 3.0
1309127629 14.6
1309127630 -10.1
1309127631 -10.0
1309127633 -9.6
1309127634 -9.7
1309127635 17.8
1309127636 31.5
1309127637 5.2
1309127638 58.8
1309127639 57.9
1309127640 58.1
1309127641 2.2
1309127642 -1.0
1309127643 0.8
1309127644 0.7
1309127645 12.9
1309127646 47.3
1309127647 73.4
1309127648 70.0
1309127649 67.2
1309127650 -11.5
1309127651 -9.9
1309127652 -9.4
1309127653 -8.3
1309127654 -0.2
1309127655 13.5
1309127656 32.7
1309127657 79.4
1309127658 73.4
1309127659 67.8
1309127660 65.3
1309127661 62.4
1309127662 59.8
1309127663 57.6
1309127664 55.8
1309127665 54.1
1309127666 52.4
1309127667 51.2
1309127668 49.9
1309127669 48.3
1309127670 46.7
1309127671 45.2
1309127672 -9.0
1309127673 -9.7
1309127674 -9.9
# torque/3
1309127537 0.0
1309127538 3.3
1309127539 59.0
1309127540 83.5
1309127541 91.0
1309127542 79.4
1309127543 69.1
1309127544 61.3
1309127545 55.0
1309127546 51.1
1309127547 47.8
1309127548 45.4
1309127549 43.4
1309127550 42.2
1309127551 40.9
1309127552 39.2
1309127553 -7.0
1309127554 -10.7
1309127555 -11.7
1309127556 -12.9
1309127557 -14.5
1309127558 0.0
1309127559 0.0
1309127560 0.0
1309127561 -3.6
1309127562 21.9
1309127563 37.7
1309127564 49.3
1309127565 57.1
1309127566 68.8
1309127567 32.3
1309127568 34.7
1309127569 -7.2
1309127570 0.0
1309127571 0.0
1309127572 -4.2
1309127573 31.4
1309127574 31.4
1309127575 71.7
1309127576 71.5
1309127577 61.2
1309127578 39.6
1309127579 -11.7
1309127580 0.0
1309127581 0.0
1309127582 0.0
1309127583 46.6
1309127584 62.0
1309127586 55.4
1309127587 50.4
1309127588 49.4
1309127589 46.8
1309127590 44.2
1309127591 42.2
1309127592 -11.6
1309127593 -13.8
1309127594 0.0
1309127595 17.5
1309127596 3.5
1309127597 27.8
1309127598 48.3
1309127599 72.4
1309127600 64.8
1309127601 59.2
1309127602 54.8
1309127603 51.1
1309127604 48.3
1309127605 -12.2
1309127606 -14.1
1309127607 0.0
1309127608 -0.7
1309127609 67.5
1309127610 64.1
1309127611 59.4
1309127612 55.3
1309127613 53.0
1309127614 51.5
1309127615 49.3
1309127616 47.5
1309127617 45.4
1309127618 43.7
1309127619 0.0
1309127620 0.0
1309127621 0.0
1309127622 0.0
1309127623 0.0
1309127624 41.6
1309127625 82.7
1309127626 27.8
1309127627 66.9
1309127628 1.7
1309127629 18.1
1309127630 -17.1
1309127631 -17.7
1309127633 -18.6
1309127634 -18.8
1309127635 26.0
1309127636 37.0
1309127637 11.4
1309127638 59.0
1309127639 52.0
1309127640 48.3
1309127641 -2.3
1309127642 -2.5
1309127643 0.0
1309127644 0.0
1309127645 17.6
1309127646 52.2
1309127647 64.2
1309127648 56.6
1309127649 50.9
1309127650 -12.3
1309127651 -15.4
1309127652 -19.2
1309127653 -23.6
1309127654 -3.1
1309127655 33.2
1309127656 66.0
1309127657 100.0
1309127658 77.8
1309127659 64.8
1309127660 57.3
1309127661 51.3
1309127662 46.5
1309127663 42.8
1309127664 40.0
1309127665 37.7
1309127666 36.0
1309127667 34.6
1309127668 33.5
1309127669 31.8
1309127670 30.1
1309127671 28.8
1309127672 -9.3
1309127673 -12.2
1309127674 -14.3
# volts/4
1309127537 101.6
1309127538 101.4
1309127539 95.0
1309127540 89.1
1309127541 81.9
1309127542 82.8
1309127543 83.4
1309127544 83.9
1309127545 84.4
1309127546 84.8
1309127547 85.0
1309127548 85.2
1309127549 85.5
1309127550 85.6
1309127551 85.8
1309127552 85.9
1309127553 101.4
1309127554 102.5
1309127555 102.8
1309127556 102.8
1309127557 103.0
1309127558 100.8
1309127559 100.8
1309127560 100.9
1309127561 101.2
1309127562 98.4
1309127563 95.9
1309127564 93.2
1309127565 90.8
1309127566 85.2
1309127567 93.6
1309127568 91.0
1309127569 100.6
1309127570 101.5
1309127571 100.8
1309127572 101.0
1309127573 98.9
1309127574 95.8
1309127575 85.6
1309127576 82.6
1309127577 83.1
1309127578 89.0
1309127579 102.1
1309127580 100.2
1309127581 100.4
1309127582 100.5
1309127583 90.6
1309127584 83.6
1309127586 84.0
1309127587 84.4
1309127588 84.4
1309127589 84.5
1309127590 84.8
1309127591 85.0
1309127592 102.0
1309127593 102.2
1309127594 99.9
1309127595 97.1
1309127596 99.1
1309127597 95.2
1309127598 90.8
1309127599 82.1
1309127600 82.4
1309127601 82.6
1309127602 83.1
1309127603 83.2
1309127604 83.5
1309127605 101.6
1309127606 101.9
1309127607 99.6
1309127608 100.0
1309127609 83.2
1309127610 82.1
1309127611 82.6
1309127612 82.8
1309127613 82.8
1309127614 83.0
1309127615 83.0
1309127616 83.0
1309127617 83.2
1309127618 83.5
1309127619 98.4
1309127620 98.8
1309127621 99.0
1309127622 99.1
1309127623 99.4
1309127624 96.8
1309127625 90.4
1309127626 96.2
1309127627 90.2
1309127628 98.8
1309127629 96.2
1309127630 102.0
1309127631 102.0
1309127633 102.2
1309127634 102.2
1309127635 95.6
1309127636 92.6
1309127637 98.8
1309127638 86.2
1309127639 86.1
1309127640 85.9
1309127641 97.6
1309127642 101.2
1309127643 99.6
1309127644 99.8
1309127645 96.8
1309127646 89.0
1309127647 82.4
1309127648 82.9
1309127649 83.2
1309127650 102.0
1309127651 101.8
1309127652 101.9
1309127653 101.6
1309127654 100.1
1309127655 96.6
1309127656 91.9
1309127657 81.5
1309127658 82.0
1309127659 83.1
1309127660 83.6
1309127661 84.1
1309127662 84.6
1309127663 85.1
1309127664 85.4
1309127665 85.8
1309127666 86.0
1309127667 86.4
1309127668 86.6
1309127669 87.0
1309127670 87.2
1309127671 87.6
1309127672 100.5
1309127673 100.9
1309127674 101.1
# lap %
1309127546 0.0 # 0:00
1309127547 1.1 # 0:01
1309127548 2.2 # 0:02
1309127549 3.4 # 0:03
1309127550 4.6 # 0:04
1309127551 5.9 # 0:05
1309127552 7.1 # 0:06
1309127553 8.4 # 0:07
1309127554 9.7 # 0:08
1309127555 11.0 # 0:09
1309127556 12.1 # 0:10
1309127557 13.2 # 0:11
1309127558 14.1 # 0:12
1309127559 14.8 # 0:13
1309127560 15.4 # 0:14
1309127561 16.0 # 0:15
1309127562 16.5 # 0:16
1309127563 17.0 # 0:17
1309127564 17.6 # 0:18
1309127565 18.2 # 0:19
1309127566 18.8 # 0:20
1309127567 19.5 # 0:21
1309127568 20.4 # 0:22
1309127569 21.2 # 0:23
1309127570 22.1 # 0:24
1309127571 22.9 # 0:25
1309127572 23.6 # 0:26
1309127573 24.3 # 0:27
1309127574 24.9 # 0:28
1309127575 25.6 # 0:29
1309127576 26.3 # 0:30
1309127577 27.2 # 0:31
1309127578 28.1 # 0:32
1309127579 29.1 # 0:33
1309127580 30.1 # 0:34
1309127581 31.0 # 0:35
1309127582 31.8 # 0:36
1309127583 32.7 # 0:37
1309127584 33.5 # 0:38
1309127586 34.4 # 0:40
1309127587 36.3 # 0:41
1309127588 37.3 # 0:42
1309127589 38.4 # 0:43
1309127590 39.5 # 0:44
1309127591 40.7 # 0:45
1309127592 41.9 # 0:46
1309127593 43.1 # 0:47
1309127594 44.0 # 0:48
1309127595 44.8 # 0:49
1309127596 45.6 # 0:50
1309127597 46.3 # 0:51
1309127598 47.1 # 0:52
1309127599 47.8 # 0:53
1309127600 48.6 # 0:54
1309127601 49.5 # 0:55
1309127602 50.5 # 0:56
1309127603 51.5 # 0:57
1309127604 52.6 # 0:58
1309127605 53.7 # 0:59
1309127606 54.8 # 1:00
1309127607 55.7 # 1:01
1309127608 56.5 # 1:02
1309127609 57.3 # 1:03
1309127610 58.1 # 1:04
1309127611 59.0 # 1:05
1309127612 60.0 # 1:06
1309127613 61.0 # 1:07
1309127614 62.0 # 1:08
1309127615 63.1 # 1:09
1309127616 64.1 # 1:10
1309127617 65.2 # 1:11
1309127618 66.4 # 1:12
1309127619 67.5 # 1:13
1309127620 68.7 # 1:14
1309127621 69.6 # 1:15
1309127622 70.3 # 1:16
1309127623 70.8 # 1:17
1309127624 71.1 # 1:18
1309127625 71.4 # 1:19
1309127626 71.7 # 1:20
1309127627 72.2 # 1:21
1309127628 72.8 # 1:22
1309127629 73.4 # 1:23
1309127630 74.1 # 1:24
1309127631 74.9 # 1:25
1309127633 75.6 # 1:27
1309127634 76.9 # 1:28
1309127635 77.6 # 1:29
1309127636 78.3 # 1:30
1309127637 79.0 # 1:31
1309127638 79.7 # 1:32
1309127639 80.5 # 1:33
1309127640 81.4 # 1:34
1309127641 82.4 # 1:35
1309127642 83.4 # 1:36
1309127643 84.4 # 1:37
1309127644 85.2 # 1:38
1309127645 86.0 # 1:39
1309127646 86.7 # 1:40
1309127647 87.5 # 1:41
1309127648 88.3 # 1:42
1309127649 89.2 # 1:43
1309127650 90.3 # 1:44
1309127651 91.3 # 1:45
1309127652 92.1 # 1:46
1309127653 92.8 # 1:47
1309127654 93.2 # 1:48
1309127655 93.6 # 1:49
1309127656 94.0 # 1:50
1309127657 94.4 # 1:51
1309127658 95.0 # 1:52
1309127659 95.7 # 1:53
1309127660 96.4 # 1:54
1309127661 97.3 # 1:55
1309127662 98.3 # 1:56
1309127663 99.3 # 1:57
1309127664 100.3 # 1:58
1309127665 101.4 # 1:59
1309127666 102.6 # 2:00
1309127667 103.8 # 2:01
1309127668 104.9 # 2:02
1309127669 106.1 # 2:03
# Whpm/20
1309127546 0 # Wh/mi=0
1309127547 100 # Wh/mi=2007
1309127548 97 # Wh/mi=1938
1309127549 94 # Wh/mi=1881
1309127550 92 # Wh/mi=1832
1309127551 89 # Wh/mi=1789
1309127552 88 # Wh/mi=1755
1309127553 86 # Wh/mi=1721
1309127554 73 # Wh/mi=1466
1309127555 63 # Wh/mi=1264
1309127556 56 # Wh/mi=1111
1309127557 50 # Wh/mi=993
1309127558 45 # Wh/mi=900
1309127559 43 # Wh/mi=857
1309127560 41 # Wh/mi=824
1309127561 40 # Wh/mi=796
1309127562 38 # Wh/mi=768
1309127563 39 # Wh/mi=771
1309127564 40 # Wh/mi=794
1309127565 42 # Wh/mi=835
1309127566 44 # Wh/mi=887
1309127567 48 # Wh/mi=966
1309127568 49 # Wh/mi=981
1309127569 50 # Wh/mi=1005
1309127570 48 # Wh/mi=957
1309127571 46 # Wh/mi=927
1309127572 45 # Wh/mi=900
1309127573 44 # Wh/mi=873
1309127574 44 # Wh/mi=883
1309127575 45 # Wh/mi=893
1309127576 48 # Wh/mi=952
1309127577 51 # Wh/mi=1012
1309127578 53 # Wh/mi=1063
1309127579 55 # Wh/mi=1090
1309127580 52 # Wh/mi=1042
1309127581 51 # Wh/mi=1012
1309127582 49 # Wh/mi=985
1309127583 48 # Wh/mi=961
1309127584 49 # Wh/mi=984
1309127586 51 # Wh/mi=1027
1309127587 55 # Wh/mi=1097
1309127588 56 # Wh/mi=1126
1309127589 58 # Wh/mi=1151
1309127590 59 # Wh/mi=1172
1309127591 59 # Wh/mi=1189
1309127592 60 # Wh/mi=1203
1309127593 58 # Wh/mi=1161
1309127594 56 # Wh/mi=1127
1309127595 55 # Wh/mi=1107
1309127596 55 # Wh/mi=1100
1309127597 54 # Wh/mi=1085
1309127598 54 # Wh/mi=1085
1309127599 55 # Wh/mi=1099
1309127600 57 # Wh/mi=1130
1309127601 58 # Wh/mi=1158
1309127602 59 # Wh/mi=1181
1309127603 60 # Wh/mi=1202
1309127604 61 # Wh/mi=1219
1309127605 62 # Wh/mi=1233
1309127606 60 # Wh/mi=1201
1309127607 59 # Wh/mi=1174
1309127608 58 # Wh/mi=1157
1309127609 57 # Wh/mi=1141
1309127610 58 # Wh/mi=1165
1309127611 59 # Wh/mi=1187
1309127612 60 # Wh/mi=1207
1309127613 61 # Wh/mi=1224
1309127614 62 # Wh/mi=1239
1309127615 63 # Wh/mi=1253
1309127616 63 # Wh/mi=1265
1309127617 64 # Wh/mi=1276
1309127618 64 # Wh/mi=1286
1309127619 65 # Wh/mi=1294
1309127620 64 # Wh/mi=1274
1309127621 63 # Wh/mi=1257
1309127622 62 # Wh/mi=1244
1309127623 62 # Wh/mi=1236
1309127624 62 # Wh/mi=1231
1309127625 62 # Wh/mi=1233
1309127626 62 # Wh/mi=1246
1309127627 62 # Wh/mi=1246
1309127628 63 # Wh/mi=1257
1309127629 62 # Wh/mi=1247
1309127630 62 # Wh/mi=1243
1309127631 61 # Wh/mi=1225
1309127633 60 # Wh/mi=1209
1309127634 59 # Wh/mi=1177
1309127635 58 # Wh/mi=1162
1309127636 58 # Wh/mi=1161
1309127637 58 # Wh/mi=1165
1309127638 58 # Wh/mi=1157
1309127639 59 # Wh/mi=1170
1309127640 59 # Wh/mi=1182
1309127641 60 # Wh/mi=1192
1309127642 59 # Wh/mi=1178
1309127643 58 # Wh/mi=1164
1309127644 58 # Wh/mi=1153
1309127645 57 # Wh/mi=1144
1309127646 57 # Wh/mi=1139
1309127647 57 # Wh/mi=1149
1309127648 58 # Wh/mi=1165
1309127649 59 # Wh/mi=1178
1309127650 59 # Wh/mi=1190
1309127651 59 # Wh/mi=1171
1309127652 58 # Wh/mi=1156
1309127653 57 # Wh/mi=1144
1309127654 57 # Wh/mi=1135
1309127655 57 # Wh/mi=1130
1309127656 57 # Wh/mi=1131
1309127657 57 # Wh/mi=1139
1309127658 58 # Wh/mi=1159
1309127659 59 # Wh/mi=1176
1309127660 59 # Wh/mi=1189
1309127661 60 # Wh/mi=1201
1309127662 61 # Wh/mi=1211
1309127663 61 # Wh/mi=1219
1309127664 61 # Wh/mi=1225
1309127665 62 # Wh/mi=1230
1309127666 62 # Wh/mi=1235
1309127667 62 # Wh/mi=1238
1309127668 62 # Wh/mi=1241
1309127669 62 # Wh/mi=1243
1309127670 62 # Wh/mi=1244
1309127671 62 # Wh/mi=1245
1309127672 62 # Wh/mi=1245
1309127673 61 # Wh/mi=1227
1309127674 61 # Wh/mi=1211
# PIC Timestams vs. NTP Timestamps
# Left
1519612207.00 0
1519612207.93 -0.0699999
1519612208.80 -0.2
1519612209.69 -0.31
1519612210.56 0.56
1519612211.44 0.44
1519612212.39 0.39
1519612213.53 0.53
1519612214.67 -0.33
1519612215.81 -0.19
1519612216.95 -0.05
1519612218.10 0.0999999
1519612219.06 0.0599999
1519612219.93 -0.0699999
1519612220.81 -0.19
1519612221.69 -0.31
1519612222.57 0.57
1519612223.49 0.49
1519612224.63 -0.37
1519612225.77 -0.23
1519612226.91 -0.0899999
1519612228.05 0.05
1519612229.19 0.19
1519612230.19 0.19
1519612231.07 0.0699999
1519612231.95 -0.05
1519612232.83 -0.17
1519612233.71 -0.29
1519612234.59 0.59
1519612235.73 -0.27
1519612236.87 -0.13
1519612238.01 0.00999999
1519612239.15 0.15
1519612240.30 0.3
1519612241.32 0.32
1519612242.20 0.2
1519612243.08 0.0799999
1519612243.96 -0.04
1519612244.84 -0.16
1519612245.72 -0.28
1519612246.83 -0.17
1519612247.97 -0.03
1519612249.12 0.12
1519612250.26 0.26
1519612251.40 0.4
1519612252.46 0.46
1519612253.34 0.34
1519612254.22 0.22
1519612255.10 0.0999999
1519612255.98 -0.02
1519612256.86 -0.14
1519612257.93 -0.0699999
1519612259.07 0.0699999
1519612260.21 0.21
1519612261.36 0.36
1519612262.50 0.5
1519612263.59 -0.41
1519612264.47 0.47
1519612265.35 0.35
1519612266.23 0.23
1519612267.11 0.11
1519612267.99 -0.00999999
1519612269.03 0.03
1519612270.17 0.17
1519612271.31 0.31
1519612272.46 0.46
1519612273.60 0.6
1519612274.73 -0.27
1519612275.61 0.61
1519612276.49 0.49
1519612277.37 0.37
1519612278.24 0.24
1519612279.13 0.13
1519612280.13 0.13
1519612281.27 0.27
1519612282.41 0.41
1519612283.55 0.55
1519612284.69 -0.31
1519612285.84 -0.16
1519612286.74 -0.26
1519612287.62 0.62
1519612288.50 0.5
1519612289.38 0.38
1519612290.26 0.26
1519612291.23 0.23
1519612292.37 0.37
1519612293.51 0.51
1519612294.65 -0.35
1519612295.79 -0.21
1519612296.93 -0.0699999
1519612297.87 -0.13
1519612298.75 -0.25
1519612299.63 0.63
1519612300.51 0.51
1519612301.39 0.39
1519612302.33 0.33
1519612303.47 0.47
1519612304.61 0.61
1519612305.75 -0.25
1519612306.89 -0.11
1519612308.03 0.03
1519612309.00 0
1519612309.88 -0.12
1519612310.76 -0.24
1519612311.64 0.64
1519612312.52 0.52
1519612313.42 0.42
1519612314.56 0.56
1519612315.70 -0.3
1519612316.84 -0.16
1519612317.98 -0.02
1519612319.12 0.12
1519612320.13 0.13
1519612321.01 0.00999999
1519612321.89 -0.11
1519612322.77 -0.23
1519612323.65 0.65
1519612324.53 0.53
1519612325.66 -0.34
1519612326.80 -0.2
1519612327.94 -0.0599999
1519612329.08 0.0799999
1519612330.22 0.22
1519612331.26 0.26
1519612332.14 0.14
1519612333.02 0.02
1519612333.90 -0.0999999
1519612334.78 -0.22
1519612335.66 -0.34
1519612336.75 -0.25
1519612337.89 -0.11
1519612339.04 0.04
1519612340.18 0.18
1519612341.32 0.32
1519612342.39 0.39
1519612343.27 0.27
1519612344.15 0.15
1519612345.03 0.03
1519612345.91 -0.0899999
1519612346.79 -0.21
1519612347.85 -0.15
1519612348.99 -0.00999999
1519612350.13 0.13
1519612351.27 0.27
1519612352.42 0.42
1519612353.52 0.52
1519612354.40 0.4
1519612355.28 0.28
1519612356.16 0.16
1519612357.04 0.04
1519612357.92 -0.0799999
1519612358.95 -0.05
1519612360.09 0.0899999
1519612361.23 0.23
1519612362.37 0.37
1519612363.51 0.51
1519612364.66 -0.34
1519612365.54 0.54
1519612366.41 0.41
1519612367.30 0.3
1519612368.17 0.17
1519612369.05 0.05
1519612370.05 0.05
1519612371.19 0.19
1519612372.33 0.33
1519612373.47 0.47
1519612374.61 0.61
1519612375.75 -0.25
1519612376.67 -0.33
1519612377.54 0.54
1519612378.42 0.42
1519612379.30 0.3
1519612380.18 0.18
1519612381.14 0.14
1519612382.28 0.28
1519612383.42 0.42
1519612384.56 0.56
1519612385.70 -0.3
1519612386.84 -0.16
1519612387.79 -0.21
1519612388.67 -0.33
1519612389.55 0.55
1519612390.43 0.43
1519612391.31 0.31
1519612392.23 0.23
1519612393.37 0.37
1519612394.52 0.52
1519612395.66 -0.34
1519612396.80 -0.2
1519612397.94 -0.0599999
1519612398.92 -0.0799999
1519612399.80 -0.2
1519612400.68 -0.32
1519612401.56 0.56
1519612402.44 0.44
1519612403.33 0.33
1519612404.47 0.47
1519612405.61 0.61
1519612406.75 -0.25
1519612407.89 -0.11
1519612409.03 0.03
1519612410.05 0.05
1519612410.93 -0.0699999
1519612411.81 -0.19
1519612412.69 -0.31
1519612413.57 0.57
1519612414.45 0.45
1519612415.57 0.57
1519612416.71 -0.29
1519612417.85 -0.15
1519612418.99 -0.00999999
1519612420.13 0.13
1519612421.18 0.18
1519612422.06 0.0599999
1519612422.94 -0.0599999
1519612423.82 -0.18
1519612424.70 -0.3
1519612425.58 0.58
1519612426.67 -0.33
1519612427.81 -0.19
1519612428.95 -0.05
1519612430.09 0.0899999
1519612431.23 0.23
1519612432.32 0.32
1519612433.19 0.19
1519612434.08 0.0799999
1519612434.95 -0.05
1519612435.84 -0.16
1519612436.71 -0.29
1519612437.76 -0.24
1519612438.90 -0.0999999
1519612440.05 0.05
1519612441.18 0.18
1519612442.33 0.33
1519612443.44 0.44
1519612444.32 0.32
1519612445.20 0.2
1519612446.08 0.0799999
1519612446.96 -0.04
1519612447.84 -0.16
1519612448.85 -0.15
1519612450.00 0
1519612451.13 0.13
1519612452.28 0.28
1519612453.42 0.42
1519612454.56 0.56
1519612455.45 0.45
1519612456.33 0.33
1519612457.21 0.21
1519612458.09 0.0899999
1519612458.96 -0.04
1519612459.95 -0.05
1519612461.09 0.0899999
1519612462.23 0.23
1519612463.37 0.37
1519612464.51 0.51
1519612465.65 0.65
1519612466.57 0.57
1519612467.45 0.45
1519612468.33 0.33
1519612469.21 0.21
1519612470.09 0.0899999
1519612471.04 0.04
1519612472.18 0.18
1519612473.32 0.32
1519612474.46 0.46
1519612475.60 -0.4
1519612476.74 -0.26
1519612477.70 -0.3
1519612478.58 0.58
1519612479.46 0.46
1519612480.33 0.33
1519612481.21 0.21
1519612482.13 0.13
1519612483.27 0.27
1519612484.41 0.41
1519612485.55 0.55
1519612486.69 -0.31
1519612487.83 -0.17
1519612488.82 -0.18
1519612489.70 -0.3
1519612490.58 0.58
1519612491.46 0.46
1519612492.34 0.34
1519612493.22 0.22
1519612494.35 0.35
1519612495.50 0.5
1519612496.64 0.64
1519612497.78 -0.22
1519612498.92 -0.0799999
1519612499.95 -0.05
1519612500.82 -0.18
1519612501.70 -0.3
1519612502.58 0.58
1519612503.46 0.46
1519612504.34 0.34
1519612505.45 0.45
1519612506.59 0.59
1519612507.73 -0.27
1519612508.87 -0.13
1519612510.01 0.00999999
1519612511.07 0.0699999
1519612511.95 -0.05
1519612512.83 -0.17
1519612513.70 -0.3
1519612514.58 0.58
1519612515.46 0.46
1519612516.54 0.54
1519612517.67 0.67
1519612518.82 -0.18
1519612519.96 -0.04
1519612521.10 0.0999999
1519612522.19 0.19
1519612523.07 0.0699999
1519612523.95 -0.05
1519612524.83 -0.17
1519612525.71 -0.29
1519612526.59 0.59
1519612527.63 0.63
1519612528.77 -0.23
1519612529.91 -0.0899999
1519612531.05 0.05
1519612532.19 0.19
1519612533.32 0.32
1519612534.20 0.2
1519612535.07 0.0699999
1519612535.96 -0.04
1519612536.83 -0.17
1519612537.71 -0.29
1519612538.72 -0.28
1519612539.86 -0.14
1519612541.00 0
1519612542.14 0.14
1519612543.28 0.28
1519612544.42 0.42
1519612545.32 0.32
1519612546.20 0.2
1519612547.08 0.0799999
1519612547.96 -0.04
1519612548.84 -0.16
1519612549.81 -0.19
1519612550.95 -0.05
1519612552.09 0.0899999
1519612553.23 0.23
1519612554.38 0.38
1519612555.52 0.52
1519612556.45 0.45
1519612557.33 0.33
1519612558.21 0.21
1519612559.09 0.0899999
1519612559.97 -0.03
1519612560.91 -0.0899999
1519612562.05 0.05
1519612563.19 0.19
1519612564.33 0.33
1519612565.47 0.47
1519612566.61 0.61
1519612567.59 0.59
1519612568.46 0.46
1519612569.34 0.34
1519612570.22 0.22
1519612571.10 0.0999999
1519612572.00 0
1519612573.14 0.14
1519612574.28 0.28
1519612575.43 0.43
1519612576.57 0.57
1519612577.71 0.71
1519612578.71 0.71
1519612579.59 0.59
1519612580.47 0.47
1519612581.35 0.35
1519612582.23 0.23
1519612583.11 0.11
1519612584.24 0.24
1519612585.38 0.38
1519612586.52 0.52
1519612587.66 0.66
1519612588.81 -0.19
1519612589.84 -0.16
1519612590.72 0.72
1519612591.60 0.6
1519612592.48 0.48
1519612593.36 0.36
1519612594.24 0.24
1519612595.33 0.33
1519612596.48 0.48
1519612597.62 0.62
1519612598.76 -0.24
1519612599.90 -0.0999999
1519612600.97 -0.03
1519612601.85 -0.15
1519612602.73 0.73
1519612603.61 0.61
1519612604.49 0.49
1519612605.36 0.36
1519612606.43 0.43
1519612607.57 0.57
1519612608.71 0.71
1519612609.85 -0.15
1519612610.99 -0.00999999
1519612612.10 0.0999999
1519612612.98 -0.02
1519612613.85 -0.15
1519612614.73 0.73
1519612615.61 0.61
1519612616.49 0.49
1519612617.52 0.52
1519612618.66 0.66
1519612619.80 -0.2
1519612620.94 -0.0599999
1519612622.08 0.0799999
1519612623.22 0.22
1519612624.10 0.0999999
1519612624.98 -0.02
1519612625.86 -0.14
1519612626.73 0.73
1519612627.61 0.61
1519612628.60 0.6
1519612629.75 -0.25
1519612630.89 -0.11
1519612632.03 0.03
1519612633.17 0.17
1519612634.31 0.31
1519612635.22 0.22
1519612636.10 0.0999999
1519612636.98 -0.02
1519612637.86 -0.14
1519612638.74 0.74
1519612639.70 0.7
1519612640.84 -0.16
1519612641.98 -0.02
1519612643.12 0.12
1519612644.26 0.26
1519612645.40 0.4
1519612646.35 0.35
1519612647.23 0.23
1519612648.10 0.0999999
1519612648.98 -0.02
1519612649.86 -0.14
1519612650.79 -0.21
1519612651.93 -0.0699999
1519612653.07 0.0699999
1519612654.21 0.21
1519612655.35 0.35
1519612656.49 0.49
1519612657.47 0.47
1519612658.35 0.35
1519612659.23 0.23
1519612660.11 0.11
1519612660.99 -0.00999999
1519612661.88 -0.12
1519612663.02 0.02
1519612664.16 0.16
1519612665.30 0.3
1519612666.44 0.44
1519612667.58 0.58
1519612668.60 0.6
1519612669.48 0.48
1519612670.35 0.35
1519612671.23 0.23
1519612672.11 0.11
1519612672.99 -0.00999999
1519612674.11 0.11
1519612675.25 0.25
1519612676.39 0.39
1519612677.53 0.53
1519612678.67 0.67
1519612679.72 0.72
1519612680.60 0.6
1519612681.48 0.48
1519612682.35 0.35
1519612683.23 0.23
1519612684.11 0.11
1519612685.20 0.2
1519612686.34 0.34
1519612687.48 0.48
1519612688.62 0.62
1519612689.76 0.76
1519612690.84 -0.16
1519612691.72 0.72
1519612692.60 0.6
1519612693.48 0.48
1519612694.35 0.35
1519612695.23 0.23
1519612696.28 0.28
1519612697.42 0.42
1519612698.56 0.56
1519612699.70 0.7
1519612700.84 -0.16
1519612701.96 -0.04
1519612702.84 -0.16
1519612703.72 0.72
1519612704.60 0.6
1519612705.48 0.48
1519612706.36 0.36
1519612707.37 0.37
1519612708.51 0.51
1519612709.65 0.65
1519612710.79 -0.21
1519612711.93 -0.0699999
1519612713.07 0.0699999
1519612713.96 -0.04
1519612714.84 -0.16
1519612715.72 0.72
1519612716.60 0.6
1519612717.48 0.48
1519612718.46 0.46
1519612719.60 0.6
1519612720.74 0.74
1519612721.88 -0.12
1519612723.02 0.02
1519612724.16 0.16
1519612725.08 0.0799999
1519612725.96 -0.04
1519612726.84 -0.16
1519612727.72 0.72
1519612728.60 0.6
1519612729.54 0.54
1519612730.69 0.69
1519612731.82 -0.18
1519612732.96 -0.04
1519612734.10 0.0999999
1519612735.25 0.25
1519612736.20 0.2
1519612737.08 0.0799999
1519612737.96 -0.04
1519612738.84 -0.16
1519612739.72 0.72
1519612740.63 0.63
1519612741.77 -0.23
1519612742.91 -0.0899999
1519612744.05 0.05
1519612745.19 0.19
1519612746.33 0.33
1519612747.32 0.32
1519612748.20 0.2
1519612749.08 0.0799999
1519612749.96 -0.04
1519612750.84 -0.16
1519612751.71 0.71
1519612752.85 -0.15
1519612753.99 -0.00999999
1519612755.13 0.13
1519612756.27 0.27
1519612757.41 0.41
1519612758.44 0.44
1519612759.32 0.32
1519612760.20 0.2
1519612761.08 0.0799999
1519612761.96 -0.04
1519612762.84 -0.16
1519612763.94 -0.0599999
1519612765.08 0.0799999
1519612766.22 0.22
1519612767.36 0.36
1519612768.50 0.5
1519612769.56 0.56
1519612770.44 0.44
1519612771.32 0.32
1519612772.20 0.2
1519612773.08 0.0799999
1519612773.95 -0.05
1519612775.02 0.02
1519612776.16 0.16
1519612777.31 0.31
1519612778.44 0.44
1519612779.59 0.59
1519612780.68 0.68
1519612781.56 0.56
1519612782.44 0.44
1519612783.32 0.32
1519612784.19 0.19
1519612785.07 0.0699999
1519612786.11 0.11
1519612787.25 0.25
1519612788.39 0.39
1519612789.53 0.53
1519612790.67 0.67
1519612791.80 -0.2
1519612792.68 0.68
1519612793.56 0.56
1519612794.43 0.43
1519612795.31 0.31
1519612796.19 0.19
1519612797.19 0.19
1519612798.34 0.34
1519612799.47 0.47
1519612800.61 0.61
1519612801.76 0.76
1519612802.89 -0.11
1519612803.79 -0.21
1519612804.67 0.67
1519612805.55 0.55
1519612806.43 0.43
1519612807.31 0.31
1519612808.28 0.28
1519612809.42 0.42
1519612810.56 0.56
1519612811.70 0.7
1519612812.84 -0.16
1519612813.98 -0.02
1519612814.92 -0.0799999
1519612815.80 -0.2
1519612816.68 0.68
1519612817.56 0.56
1519612818.43 0.43
1519612819.37 0.37
1519612820.51 0.51
1519612821.65 0.65
1519612822.79 -0.21
1519612823.93 -0.0699999
1519612825.07 0.0699999
1519612826.04 0.04
1519612826.92 -0.0799999
1519612827.80 -0.2
1519612828.68 0.68
1519612829.56 0.56
1519612830.46 0.46
1519612831.60 0.6
1519612832.74 0.74
1519612833.88 -0.12
1519612835.02 0.02
1519612836.16 0.16
1519612837.16 0.16
1519612838.04 0.04
1519612838.92 -0.0799999
1519612839.80 -0.2
1519612840.68 0.68
1519612841.56 0.56
1519612842.69 0.69
1519612843.83 -0.17
1519612844.97 -0.03
1519612846.11 0.11
1519612847.25 0.25
1519612848.29 0.29
1519612849.17 0.17
1519612850.04 0.04
1519612850.92 -0.0799999
1519612851.80 -0.2
1519612852.68 0.68
1519612853.78 0.78
1519612854.92 -0.0799999
1519612856.06 0.0599999
1519612857.20 0.2
1519612858.34 0.34
1519612859.41 0.41
1519612860.29 0.29
1519612861.17 0.17
1519612862.05 0.05
1519612862.93 -0.0699999
1519612863.80 -0.2
1519612864.86 -0.14
1519612866.00 0
1519612867.14 0.14
1519612868.28 0.28
1519612869.42 0.42
1519612870.53 0.53
1519612871.41 0.41
1519612872.29 0.29
1519612873.16 0.16
1519612874.04 0.04
1519612874.92 -0.0799999
1519612875.95 -0.05
1519612877.09 0.0899999
1519612878.23 0.23
1519612879.37 0.37
1519612880.51 0.51
1519612881.65 0.65
1519612882.53 0.53
1519612883.40 0.4
1519612884.28 0.28
1519612885.16 0.16
1519612886.04 0.04
1519612887.03 0.03
1519612888.17 0.17
1519612889.31 0.31
1519612890.45 0.45
1519612891.59 0.59
1519612892.73 0.73
1519612893.64 0.64
1519612894.52 0.52
1519612895.40 0.4
1519612896.28 0.28
1519612897.16 0.16
1519612898.12 0.12
1519612899.25 0.25
1519612900.39 0.39
1519612901.53 0.53
1519612902.67 0.67
1519612903.81 -0.19
1519612904.76 -0.24
1519612905.64 0.64
1519612906.52 0.52
1519612907.39 0.39
1519612908.27 0.27
1519612909.20 0.2
1519612910.34 0.34
1519612911.48 0.48
1519612912.62 0.62
1519612913.76 0.76
1519612914.90 -0.0999999
1519612915.88 -0.12
1519612916.76 0.76
1519612917.64 0.64
1519612918.51 0.51
1519612919.39 0.39
1519612920.28 0.28
1519612921.42 0.42
1519612922.56 0.56
1519612923.70 0.7
1519612924.84 -0.16
1519612925.98 -0.02
1519612927.00 0
1519612927.88 -0.12
1519612928.75 0.75
1519612929.63 0.63
1519612930.51 0.51
1519612931.39 0.39
1519612932.51 0.51
1519612933.65 0.65
1519612934.79 0.79
1519612935.93 -0.0699999
1519612937.07 0.0699999
1519612938.12 0.12
1519612939.00 0
1519612939.87 -0.13
1519612940.75 0.75
1519612941.63 0.63
1519612942.51 0.51
1519612943.59 0.59
1519612944.73 0.73
1519612945.87 -0.13
1519612947.01 0.00999999
1519612948.15 0.15
1519612949.23 0.23
1519612950.11 0.11
1519612950.99 -0.00999999
1519612951.87 -0.13
1519612952.75 0.75
1519612953.63 0.63
1519612954.68 0.68
1519612955.82 -0.18
1519612956.95 -0.05
1519612958.10 0.0999999
1519612959.23 0.23
1519612960.35 0.35
1519612961.23 0.23
1519612962.11 0.11
1519612962.99 -0.00999999
1519612963.87 -0.13
1519612964.74 0.74
1519612965.76 0.76
1519612966.90 -0.0999999
1519612968.04 0.04
1519612969.18 0.18
1519612970.32 0.32
1519612971.46 0.46
1519612972.35 0.35
1519612973.23 0.23
1519612974.11 0.11
1519612974.99 -0.00999999
1519612975.87 -0.13
1519612976.85 -0.15
1519612977.99 -0.00999999
1519612979.13 0.13
1519612980.27 0.27
1519612981.41 0.41
1519612982.55 0.55
1519612983.48 0.48
1519612984.36 0.36
1519612985.24 0.24
1519612986.11 0.11
1519612986.99 -0.00999999
1519612987.94 -0.0599999
1519612989.08 0.0799999
1519612990.22 0.22
1519612991.36 0.36
1519612992.50 0.5
1519612993.64 0.64
1519612994.60 0.6
1519612995.48 0.48
1519612996.36 0.36
1519612997.24 0.24
1519612998.11 0.11
1519612999.03 0.03
1519613000.17 0.17
1519613001.31 0.31
1519613002.45 0.45
1519613003.59 0.59
1519613004.73 0.73
1519613005.72 0.72
1519613006.60 0.6
1519613007.48 0.48
1519613008.36 0.36
1519613009.24 0.24
1519613010.11 0.11
1519613011.26 0.26
1519613012.39 0.39
1519613013.54 0.54
1519613014.67 0.67
1519613015.82 0.82
1519613016.84 -0.16
1519613017.72 0.72
1519613018.60 0.6
1519613019.48 0.48
1519613020.36 0.36
1519613021.24 0.24
1519613022.35 0.35
1519613023.49 0.49
1519613024.63 0.63
1519613025.77 0.77
1519613026.91 -0.0899999
1519613027.97 -0.03
1519613028.85 -0.15
1519613029.73 0.73
1519613030.61 0.61
1519613031.49 0.49
1519613032.37 0.37
1519613033.44 0.44
1519613034.58 0.58
1519613035.72 0.72
1519613036.86 -0.14
1519613038.00 0
1519613039.10 0.0999999
1519613039.98 -0.02
1519613040.85 -0.15
1519613041.74 0.74
1519613042.61 0.61
1519613043.49 0.49
1519613044.53 0.53
1519613045.67 0.67
1519613046.81 0.81
1519613047.95 -0.05
1519613049.09 0.0899999
1519613050.22 0.22
1519613051.10 0.0999999
1519613051.98 -0.02
1519613052.86 -0.14
1519613053.74 0.74
1519613054.62 0.62
1519613055.62 0.62
1519613056.76 0.76
1519613057.90 -0.0999999
1519613059.05 0.05
1519613060.19 0.19
1519613061.33 0.33
1519613062.23 0.23
1519613063.11 0.11
1519613063.99 -0.00999999
1519613064.87 -0.13
1519613065.75 0.75
1519613066.72 0.72
1519613067.86 -0.14
1519613068.99 -0.00999999
1519613070.14 0.14
1519613071.27 0.27
1519613072.42 0.42
1519613073.35 0.35
1519613074.23 0.23
1519613075.11 0.11
1519613075.99 -0.00999999
1519613076.86 -0.14
1519613077.80 0.8
1519613078.94 -0.0599999
1519613080.08 0.0799999
1519613081.22 0.22
1519613082.36 0.36
1519613083.50 0.5
1519613084.47 0.47
1519613085.35 0.35
1519613086.23 0.23
1519613087.11 0.11
1519613087.99 -0.00999999
1519613088.89 -0.11
1519613090.03 0.03
1519613091.17 0.17
1519613092.31 0.31
1519613093.45 0.45
1519613094.59 0.59
1519613095.59 0.59
1519613096.47 0.47
1519613097.35 0.35
1519613098.23 0.23
1519613099.10 0.0999999
1519613099.98 -0.02
1519613101.11 0.11
1519613102.25 0.25
1519613103.39 0.39
1519613104.53 0.53
1519613105.67 0.67
1519613106.71 0.71
1519613107.59 0.59
1519613108.47 0.47
1519613109.35 0.35
1519613110.23 0.23
1519613111.10 0.0999999
1519613112.20 0.2
1519613113.34 0.34
1519613114.48 0.48
1519613115.62 0.62
1519613116.76 0.76
1519613117.83 0.83
1519613118.71 0.71
1519613119.59 0.59
1519613120.47 0.47
1519613121.35 0.35
1519613122.22 0.22
1519613123.29 0.29
1519613124.43 0.43
1519613125.57 0.57
1519613126.71 0.71
1519613127.85 0.85
1519613128.95 -0.05
1519613129.83 0.83
1519613130.71 0.71
1519613131.59 0.59
1519613132.47 0.47
1519613133.35 0.35
1519613134.37 0.37
1519613135.51 0.51
1519613136.65 0.65
1519613137.79 0.79
1519613138.93 -0.0699999
1519613140.07 0.0699999
1519613140.95 -0.05
1519613141.83 0.83
1519613142.71 0.71
1519613143.59 0.59
1519613144.46 0.46
1519613145.46 0.46
1519613146.59 0.59
1519613147.74 0.74
1519613148.88 0.88
1519613150.01 0.00999999
1519613151.15 0.15
1519613152.07 0.0699999
1519613152.94 -0.0599999
1519613153.82 0.82
1519613154.70 0.7
1519613155.58 0.58
1519613156.54 0.54
1519613157.68 0.68
1519613158.81 0.81
1519613159.96 -0.04
1519613161.09 0.0899999
1519613162.23 0.23
1519613163.18 0.18
1519613164.06 0.0599999
1519613164.94 -0.0599999
1519613165.81 0.81
1519613166.69 0.69
1519613167.62 0.62
1519613168.76 0.76
1519613169.90 -0.0999999
1519613171.04 0.04
1519613172.18 0.18
1519613173.32 0.32
1519613174.30 0.3
1519613175.18 0.18
1519613176.06 0.0599999
1519613176.93 -0.0699999
1519613177.81 0.81
1519613178.70 0.7
1519613179.84 0.84
1519613180.98 -0.02
1519613182.12 0.12
1519613183.26 0.26
1519613184.40 0.4
1519613185.42 0.42
1519613186.29 0.29
1519613187.17 0.17
1519613188.05 0.05
1519613188.93 -0.0699999
1519613189.81 0.81
1519613190.92 -0.0799999
1519613192.06 0.0599999
1519613193.20 0.2
1519613194.34 0.34
1519613195.48 0.48
1519613196.53 0.53
1519613197.41 0.41
1519613198.29 0.29
1519613199.17 0.17
1519613200.04 0.04
1519613200.92 -0.0799999
1519613202.00 0
1519613203.14 0.14
1519613204.28 0.28
1519613205.42 0.42
1519613206.56 0.56
1519613207.64 0.64
1519613208.52 0.52
1519613209.40 0.4
1519613210.28 0.28
1519613211.16 0.16
1519613212.04 0.04
1519613213.09 0.0899999
1519613214.22 0.22
1519613215.37 0.37
1519613216.51 0.51
1519613217.65 0.65
1519613218.76 0.76
1519613219.64 0.64
1519613220.52 0.52
1519613221.40 0.4
1519613222.28 0.28
1519613223.16 0.16
1519613224.17 0.17
1519613225.31 0.31
1519613226.45 0.45
1519613227.59 0.59
1519613228.73 0.73
1519613229.87 0.87
1519613230.76 0.76
1519613231.64 0.64
1519613232.52 0.52
1519613233.40 0.4
1519613234.27 0.27
1519613235.25 0.25
1519613236.39 0.39
1519613237.53 0.53
1519613238.67 0.67
1519613239.81 0.81
1519613240.95 -0.05
1519613241.88 0.88
1519613242.75 0.75
1519613243.63 0.63
1519613244.51 0.51
1519613245.39 0.39
1519613246.34 0.34
1519613247.48 0.48
1519613248.62 0.62
1519613249.76 0.76
1519613250.90 -0.0999999
1519613252.04 0.04
1519613252.99 -0.00999999
1519613253.87 0.87
1519613254.75 0.75
1519613255.63 0.63
1519613256.51 0.51
1519613257.42 0.42
1519613258.56 0.56
1519613259.70 0.7
1519613260.84 0.84
1519613261.98 -0.02
1519613263.12 0.12
1519613264.11 0.11
1519613264.99 -0.00999999
1519613265.87 -0.13
1519613266.75 0.75
1519613267.63 0.63
1519613268.51 0.51
1519613269.64 0.64
1519613270.78 0.78
1519613271.92 -0.0799999
1519613273.06 0.0599999
1519613274.20 0.2
1519613275.23 0.23
1519613276.11 0.11
1519613276.98 -0.02
1519613277.86 0.86
1519613278.74 0.74
1519613279.62 0.62
1519613280.73 0.73
1519613281.86 0.86
1519613283.01 0.00999999
1519613284.14 0.14
1519613285.28 0.28
1519613286.34 0.34
1519613287.22 0.22
1519613288.10 0.0999999
1519613288.98 -0.02
1519613289.86 0.86
1519613290.74 0.74
1519613291.81 0.81
1519613292.95 -0.05
1519613294.09 0.0899999
1519613295.23 0.23
1519613296.37 0.37
1519613297.46 0.46
1519613298.34 0.34
1519613299.22 0.22
1519613300.10 0.0999999
1519613300.98 -0.02
1519613301.85 0.85
1519613302.89 0.89
1519613304.03 0.03
1519613305.17 0.17
1519613306.31 0.31
1519613307.45 0.45
1519613308.58 0.58
1519613309.46 0.46
1519613310.34 0.34
1519613311.22 0.22
1519613312.09 0.0899999
1519613312.97 -0.03
1519613313.98 -0.02
1519613315.12 0.12
1519613316.26 0.26
1519613317.40 0.4
1519613318.54 0.54
1519613319.68 0.68
1519613320.58 0.58
1519613321.46 0.46
1519613322.33 0.33
1519613323.21 0.21
1519613324.09 0.0899999
1519613325.06 0.0599999
1519613326.20 0.2
1519613327.34 0.34
1519613328.48 0.48
1519613329.62 0.62
1519613330.76 0.76
1519613331.70 0.7
1519613332.58 0.58
1519613333.45 0.45
1519613334.33 0.33
1519613335.21 0.21
1519613336.15 0.15
1519613337.29 0.29
1519613338.43 0.43
1519613339.56 0.56
1519613340.71 0.71
1519613341.84 0.84
1519613342.81 0.81
1519613343.69 0.69
1519613344.57 0.57
1519613345.45 0.45
1519613346.33 0.33
1519613347.23 0.23
1519613348.37 0.37
1519613349.51 0.51
1519613350.65 0.65
1519613351.79 0.79
1519613352.93 -0.0699999
1519613353.93 0.93
1519613354.81 0.81
1519613355.69 0.69
1519613356.56 0.56
1519613357.44 0.44
1519613358.32 0.32
1519613359.45 0.45
1519613360.59 0.59
1519613361.73 0.73
1519613362.87 0.87
1519613364.01 0.00999999
1519613365.04 0.04
1519613365.92 0.92
1519613366.80 0.8
1519613367.68 0.68
1519613368.56 0.56
1519613369.44 0.44
1519613370.53 0.53
1519613371.67 0.67
1519613372.81 0.81
1519613373.95 -0.05
1519613375.09 0.0899999
1519613376.16 0.16
1519613377.04 0.04
1519613377.92 0.92
1519613378.80 0.8
1519613379.68 0.68
1519613380.56 0.56
1519613381.62 0.62
1519613382.75 0.75
1519613383.89 0.89
1519613385.03 0.03
1519613386.17 0.17
1519613387.28 0.28
1519613388.16 0.16
1519613389.03 0.03
1519613389.91 0.91
1519613390.79 0.79
1519613391.67 0.67
1519613392.70 0.7
1519613393.84 0.84
1519613394.97 -0.03
1519613396.12 0.12
1519613397.25 0.25
1519613398.39 0.39
1519613399.27 0.27
1519613400.15 0.15
1519613401.03 0.03
1519613401.91 0.91
1519613402.79 0.79
1519613403.78 0.78
1519613404.92 0.92
1519613406.06 0.0599999
1519613407.20 0.2
1519613408.34 0.34
1519613409.48 0.48
1519613410.39 0.39
1519613411.27 0.27
1519613412.14 0.14
1519613413.03 0.03
1519613413.90 0.9
1519613414.86 0.86
1519613416.00 0
1519613417.14 0.14
1519613418.28 0.28
1519613419.42 0.42
1519613420.56 0.56
1519613421.51 0.51
1519613422.38 0.38
1519613423.26 0.26
1519613424.14 0.14
1519613425.02 0.02
1519613425.94 -0.0599999
1519613427.08 0.0799999
1519613428.22 0.22
1519613429.36 0.36
1519613430.51 0.51
1519613431.64 0.64
1519613432.63 0.63
1519613433.50 0.5
1519613434.38 0.38
1519613435.26 0.26
1519613436.14 0.14
1519613437.03 0.03
1519613438.17 0.17
1519613439.31 0.31
1519613440.45 0.45
1519613441.59 0.59
1519613442.73 0.73
1519613443.75 0.75
1519613444.63 0.63
1519613445.51 0.51
1519613446.38 0.38
1519613447.26 0.26
1519613448.14 0.14
1519613449.26 0.26
1519613450.40 0.4
# Right
1519612207.00 0
1519612207.94 -0.0599999
1519612208.88 -0.12
1519612209.82 -0.18
1519612210.97 -0.03
1519612212.19 0.19
1519612213.41 -0.59
1519612214.63 -0.37
1519612215.85 -0.15
1519612217.00 0
1519612217.94 -0.0599999
1519612218.88 -0.12
1519612219.82 -0.18
1519612220.76 -0.24
1519612221.70 -0.3
1519612222.82 -0.18
1519612224.04 0.04
1519612225.25 -0.75
1519612226.47 -0.53
1519612227.69 -0.31
1519612228.89 -0.11
1519612229.83 -0.17
1519612230.76 -0.24
1519612231.70 -0.3
1519612232.64 -0.36
1519612233.58 -0.42
1519612234.66 -0.34
1519612235.88 -0.12
1519612237.10 0.0999999
1519612238.32 -0.68
1519612239.54 -0.46
1519612240.75 -0.25
1519612241.71 -0.29
1519612242.64 -0.36
1519612243.58 -0.42
1519612244.52 -0.48
1519612245.46 -0.54
1519612246.51 -0.49
1519612247.72 -0.28
1519612248.94 -0.0599999
1519612250.16 0.16
1519612251.38 -0.62
1519612252.60 -0.4
1519612253.59 -0.41
1519612254.53 -0.47
1519612255.47 -0.53
1519612256.40 -0.6
1519612257.34 -0.66
1519612258.36 -0.64
1519612259.57 -0.43
1519612260.79 -0.21
1519612262.01 0.00999999
1519612263.23 -0.77
1519612264.45 -0.55
1519612265.47 -0.53
1519612266.41 -0.59
1519612267.35 -0.65
1519612268.29 0.29
1519612269.23 0.23
1519612270.21 -0.79
1519612271.43 -0.57
1519612272.65 -0.35
1519612273.86 -0.14
1519612275.08 0.0799999
1519612276.30 -0.7
1519612277.36 -0.64
1519612278.30 0.3
1519612279.24 0.24
1519612280.18 0.18
1519612281.12 0.12
1519612282.06 0.0599999
1519612283.28 -0.72
1519612284.50 -0.5
1519612285.72 -0.28
1519612286.94 -0.0599999
1519612288.16 0.16
1519612289.25 0.25
1519612290.19 0.19
1519612291.13 0.13
1519612292.07 0.0699999
1519612293.01 0.00999999
1519612293.95 -0.05
1519612295.13 0.13
1519612296.35 -0.65
1519612297.57 -0.43
1519612298.79 -0.21
1519612300.00 0
1519612301.14 0.14
1519612302.07 0.0699999
1519612303.01 0.00999999
1519612303.95 -0.05
1519612304.89 -0.11
1519612305.83 -0.17
1519612306.98 -0.02
1519612308.19 -0.81
1519612309.41 -0.59
1519612310.63 -0.37
1519612311.85 -0.15
1519612313.02 0.02
1519612313.96 -0.04
1519612314.90 -0.0999999
1519612315.84 -0.16
1519612316.78 -0.22
1519612317.71 -0.29
1519612318.82 -0.18
1519612320.04 0.04
1519612321.26 -0.74
1519612322.48 -0.52
1519612323.70 -0.3
1519612324.90 -0.0999999
1519612325.84 -0.16
1519612326.78 -0.22
1519612327.72 -0.28
1519612328.66 -0.34
1519612329.60 -0.4
1519612330.67 -0.33
1519612331.89 -0.11
1519612333.11 0.11
1519612334.33 -0.67
1519612335.55 -0.45
1519612336.76 -0.24
1519612337.73 -0.27
1519612338.67 -0.33
1519612339.61 -0.39
1519612340.55 -0.45
1519612341.49 -0.51
1519612342.52 -0.48
1519612343.74 -0.26
1519612344.96 -0.04
1519612346.18 0.18
1519612347.39 -0.61
1519612348.61 -0.39
1519612349.61 -0.39
1519612350.55 -0.45
1519612351.49 -0.51
1519612352.43 -0.57
1519612353.37 -0.63
1519612354.37 -0.63
1519612355.59 -0.41
1519612356.81 -0.19
1519612358.02 0.02
1519612359.24 -0.76
1519612360.46 -0.54
1519612361.50 -0.5
1519612362.44 -0.56
1519612363.37 -0.63
1519612364.31 -0.69
1519612365.25 0.25
1519612366.21 -0.79
1519612367.43 -0.57
1519612368.65 -0.35
1519612369.87 -0.13
1519612371.08 0.0799999
1519612372.30 -0.7
1519612373.37 -0.63
1519612374.31 0.31
1519612375.25 0.25
1519612376.19 0.19
1519612377.12 0.12
1519612378.06 0.0599999
1519612379.27 -0.73
1519612380.49 -0.51
1519612381.70 -0.3
1519612382.92 -0.0799999
1519612384.14 0.14
1519612385.25 0.25
1519612386.19 0.19
1519612387.13 0.13
1519612388.06 0.0599999
1519612389.00 0
1519612389.94 -0.0599999
1519612391.11 0.11
1519612392.33 -0.67
1519612393.55 -0.45
1519612394.76 -0.24
1519612395.98 -0.02
1519612397.13 0.13
1519612398.07 0.0699999
1519612399.00 0
1519612399.94 -0.0599999
1519612400.88 -0.12
1519612401.82 -0.18
1519612402.95 -0.05
1519612404.17 0.17
1519612405.39 -0.61
1519612406.60 -0.4
1519612407.82 -0.18
1519612409.00 0
1519612409.94 -0.0599999
1519612410.88 -0.12
1519612411.82 -0.18
1519612412.76 -0.24
1519612413.70 -0.3
1519612414.79 -0.21
1519612416.01 0.00999999
1519612417.23 -0.77
1519612418.44 -0.56
1519612419.66 -0.34
1519612420.88 -0.12
1519612421.82 -0.18
1519612422.76 -0.24
1519612423.70 -0.3
1519612424.63 -0.37
1519612425.57 -0.43
1519612426.63 -0.37
1519612427.85 -0.15
1519612429.07 0.0699999
1519612430.29 -0.71
1519612431.50 -0.5
1519612432.72 -0.28
1519612433.70 -0.3
1519612434.63 -0.37
1519612435.57 -0.43
1519612436.51 -0.49
1519612437.45 -0.55
1519612438.47 -0.53
1519612439.69 -0.31
1519612440.91 -0.0899999
1519612442.13 0.13
1519612443.34 -0.66
1519612444.56 -0.44
1519612445.57 -0.43
1519612446.51 -0.49
1519612447.45 -0.55
1519612448.39 -0.61
1519612449.33 -0.67
1519612450.32 -0.68
1519612451.54 -0.46
1519612452.75 -0.25
1519612453.97 -0.03
1519612455.19 0.19
1519612456.40 -0.6
1519612457.45 -0.55
1519612458.39 -0.61
1519612459.33 -0.67
1519612460.27 0.27
1519612461.21 0.21
1519612462.16 0.16
1519612463.37 -0.63
1519612464.59 -0.41
1519612465.81 -0.19
1519612467.03 0.03
1519612468.25 -0.75
1519612469.33 -0.67
1519612470.27 0.27
1519612471.21 0.21
1519612472.15 0.15
1519612473.08 0.0799999
1519612474.02 0.02
1519612475.22 -0.78
1519612476.44 -0.56
1519612477.65 -0.35
1519612478.87 -0.13
1519612480.09 0.0899999
1519612481.21 0.21
1519612482.15 0.15
1519612483.09 0.0899999
1519612484.03 0.03
1519612484.96 -0.04
1519612485.90 -0.0999999
1519612487.06 0.0599999
1519612488.28 -0.72
1519612489.50 -0.5
1519612490.71 -0.29
1519612491.93 -0.0699999
1519612493.09 0.0899999
1519612494.03 0.03
1519612494.96 -0.04
1519612495.90 -0.0999999
1519612496.84 -0.16
1519612497.78 -0.22
1519612498.90 -0.0999999
1519612500.12 0.12
1519612501.33 -0.67
1519612502.55 -0.45
1519612503.77 -0.23
1519612504.96 -0.04
1519612505.90 -0.0999999
1519612506.84 -0.16
1519612507.77 -0.23
1519612508.71 -0.29
1519612509.65 -0.35
1519612510.73 -0.27
1519612511.95 -0.05
1519612513.17 -0.83
1519612514.38 -0.62
1519612515.60 -0.4
1519612516.82 -0.18
1519612517.77 -0.23
1519612518.71 -0.29
1519612519.64 -0.36
1519612520.58 -0.42
1519612521.52 -0.48
1519612522.57 -0.43
1519612523.79 -0.21
1519612525.00 0
1519612526.22 -0.78
1519612527.44 -0.56
1519612528.65 -0.35
1519612529.64 -0.36
1519612530.58 -0.42
1519612531.52 -0.48
1519612532.45 -0.55
1519612533.39 -0.61
1519612534.40 -0.6
1519612535.62 -0.38
1519612536.84 -0.16
1519612538.06 0.0599999
1519612539.28 -0.72
1519612540.49 -0.51
1519612541.52 -0.48
1519612542.46 -0.54
1519612543.39 -0.61
1519612544.33 -0.67
1519612545.27 0.27
1519612546.25 -0.75
1519612547.47 -0.53
1519612548.69 -0.31
1519612549.90 -0.0999999
1519612551.12 0.12
1519612552.34 -0.66
1519612553.40 -0.6
1519612554.34 -0.66
1519612555.28 0.28
1519612556.22 0.22
1519612557.16 0.16
1519612558.10 0.0999999
1519612559.31 -0.69
1519612560.53 -0.47
1519612561.75 -0.25
1519612562.97 -0.03
1519612564.19 -0.81
1519612565.28 0.28
1519612566.22 0.22
1519612567.16 0.16
1519612568.10 0.0999999
1519612569.04 0.04
1519612569.98 -0.02
1519612571.16 0.16
1519612572.38 -0.62
1519612573.59 -0.41
1519612574.81 -0.19
1519612576.03 0.03
1519612577.16 0.16
1519612578.10 0.0999999
1519612579.04 0.04
1519612579.98 -0.02
1519612580.92 -0.0799999
1519612581.86 -0.14
1519612583.01 0.00999999
1519612584.22 -0.78
1519612585.44 -0.56
1519612586.66 -0.34
1519612587.88 -0.12
1519612589.05 0.05
1519612589.99 -0.00999999
1519612590.92 -0.0799999
1519612591.86 -0.14
1519612592.80 -0.2
1519612593.74 -0.26
1519612594.85 -0.15
1519612596.07 0.0699999
1519612597.29 -0.71
1519612598.51 -0.49
1519612599.72 -0.28
1519612600.93 -0.0699999
1519612601.87 -0.13
1519612602.81 -0.19
1519612603.74 -0.26
1519612604.68 -0.32
1519612605.62 -0.38
1519612606.69 -0.31
1519612607.91 -0.0899999
1519612609.13 0.13
1519612610.34 -0.66
1519612611.56 -0.44
1519612612.78 -0.22
1519612613.74 -0.26
1519612614.68 -0.32
1519612615.62 -0.38
1519612616.56 -0.44
1519612617.50 -0.5
1519612618.53 -0.47
1519612619.75 -0.25
1519612620.97 -0.03
1519612622.19 -0.81
1519612623.40 -0.6
1519612624.62 -0.38
1519612625.62 -0.38
1519612626.56 -0.44
1519612627.50 -0.5
1519612628.44 -0.56
1519612629.37 -0.63
1519612630.37 -0.63
1519612631.59 -0.41
1519612632.81 -0.19
1519612634.02 0.02
1519612635.24 -0.76
1519612636.46 -0.54
1519612637.50 -0.5
1519612638.43 -0.57
1519612639.37 -0.63
1519612640.31 0.31
1519612641.25 0.25
1519612642.21 -0.79
1519612643.43 -0.57
1519612644.65 -0.35
1519612645.86 -0.14
1519612647.08 0.0799999
1519612648.30 -0.7
1519612649.37 -0.63
1519612650.31 -0.69
1519612651.25 0.25
1519612652.18 0.18
1519612653.12 0.12
1519612654.06 0.0599999
1519612655.27 -0.73
1519612656.48 -0.52
1519612657.70 -0.3
1519612658.92 -0.0799999
1519612660.14 0.14
1519612661.24 0.24
1519612662.18 0.18
1519612663.12 0.12
1519612664.06 0.0599999
1519612665.00 0
1519612665.94 -0.0599999
1519612667.10 0.0999999
1519612668.32 -0.68
1519612669.54 -0.46
1519612670.76 -0.24
1519612671.97 -0.03
1519612673.12 0.12
1519612674.06 0.0599999
1519612675.00 0
1519612675.93 -0.0699999
1519612676.87 -0.13
1519612677.81 -0.19
1519612678.94 -0.0599999
1519612680.16 0.16
1519612681.38 -0.62
1519612682.59 -0.41
1519612683.81 -0.19
1519612684.99 -0.00999999
1519612685.93 -0.0699999
1519612686.86 -0.14
1519612687.80 -0.2
1519612688.74 -0.26
1519612689.68 -0.32
1519612690.78 -0.22
1519612692.00 0
1519612693.21 -0.79
1519612694.43 -0.57
1519612695.65 -0.35
1519612696.86 -0.14
1519612697.80 -0.2
1519612698.74 -0.26
1519612699.68 -0.32
1519612700.62 -0.38
1519612701.56 -0.44
1519612702.62 -0.38
1519612703.83 -0.17
1519612705.05 0.05
1519612706.27 -0.73
1519612707.49 -0.51
1519612708.70 -0.3
1519612709.68 -0.32
1519612710.61 -0.39
1519612711.55 -0.45
1519612712.49 -0.51
1519612713.43 -0.57
1519612714.45 -0.55
1519612715.67 -0.33
1519612716.88 -0.12
1519612718.10 0.0999999
1519612719.32 -0.68
1519612720.54 -0.46
1519612721.55 -0.45
1519612722.49 -0.51
1519612723.43 -0.57
1519612724.36 -0.64
1519612725.30 0.3
1519612726.29 -0.71
1519612727.50 -0.5
1519612728.72 -0.28
1519612729.94 -0.0599999
1519612731.16 -0.84
1519612732.37 -0.63
1519612733.42 -0.58
1519612734.36 -0.64
1519612735.30 0.3
1519612736.24 0.24
1519612737.17 0.17
1519612738.12 0.12
1519612739.34 -0.66
1519612740.56 -0.44
1519612741.78 -0.22
1519612742.99 -0.00999999
1519612744.21 -0.79
1519612745.29 0.29
1519612746.23 0.23
1519612747.17 0.17
1519612748.11 0.11
1519612749.04 0.04
1519612749.98 -0.02
1519612751.17 0.17
1519612752.39 -0.61
1519612753.61 -0.39
1519612754.82 -0.18
1519612756.04 0.04
1519612757.16 0.16
1519612758.10 0.0999999
1519612759.04 0.04
1519612759.97 -0.03
1519612760.91 -0.0899999
1519612761.85 -0.15
1519612763.01 0.00999999
1519612764.22 -0.78
1519612765.44 -0.56
1519612766.66 -0.34
1519612767.87 -0.13
1519612769.03 0.03
1519612769.97 -0.03
1519612770.91 -0.0899999
1519612771.84 -0.16
1519612772.78 -0.22
1519612773.72 -0.28
1519612774.84 -0.16
1519612776.06 0.0599999
1519612777.28 -0.72
1519612778.49 -0.51
1519612779.71 -0.29
1519612780.91 -0.0899999
1519612781.84 -0.16
1519612782.78 -0.22
1519612783.72 -0.28
1519612784.66 -0.34
1519612785.60 -0.4
1519612786.68 -0.32
1519612787.90 -0.0999999
1519612789.12 0.12
1519612790.34 -0.66
1519612791.55 -0.45
1519612792.77 -0.23
1519612793.72 -0.28
1519612794.66 -0.34
1519612795.60 -0.4
1519612796.54 -0.46
1519612797.47 -0.53
1519612798.52 -0.48
1519612799.74 -0.26
1519612800.96 -0.04
1519612802.17 0.17
1519612803.39 -0.61
1519612804.61 -0.39
1519612805.60 -0.4
1519612806.53 -0.47
1519612807.47 -0.53
1519612808.41 -0.59
1519612809.35 -0.65
1519612810.36 -0.64
1519612811.58 -0.42
1519612812.80 -0.2
1519612814.01 0.00999999
1519612815.23 -0.77
1519612816.45 -0.55
1519612817.47 -0.53
1519612818.41 -0.59
1519612819.35 -0.65
1519612820.29 0.29
1519612821.23 0.23
1519612822.20 -0.8
1519612823.42 -0.58
1519612824.64 -0.36
1519612825.86 -0.14
1519612827.08 0.0799999
1519612828.30 -0.7
1519612829.36 -0.64
1519612830.29 0.29
1519612831.23 0.23
1519612832.17 0.17
1519612833.11 0.11
1519612834.05 0.05
1519612835.27 -0.73
1519612836.49 -0.51
1519612837.70 -0.3
1519612840.14 0.14
1519612841.23 0.23
1519612842.17 0.17
1519612843.11 0.11
1519612844.05 0.05
1519612844.99 -0.00999999
1519612845.93 -0.0699999
1519612847.11 0.11
1519612848.33 -0.67
1519612849.55 -0.45
1519612850.77 -0.23
1519612851.98 -0.02
1519612853.12 0.12
1519612854.06 0.0599999
1519612855.00 0
1519612855.93 -0.0699999
1519612856.87 -0.13
1519612857.81 -0.19
1519612858.96 -0.04
1519612860.18 0.18
1519612861.40 -0.6
1519612862.61 -0.39
1519612863.83 -0.17
1519612865.00 0
1519612865.94 -0.0599999
1519612866.88 -0.12
1519612867.82 -0.18
1519612868.76 -0.24
1519612869.69 -0.31
1519612870.80 -0.2
1519612872.02 0.02
1519612873.24 -0.76
1519612874.46 -0.54
1519612875.68 -0.32
1519612876.88 -0.12
1519612877.82 -0.18
1519612878.76 -0.24
1519612879.70 -0.3
1519612880.64 -0.36
1519612881.58 -0.42
1519612882.65 -0.35
1519612883.87 -0.13
1519612885.09 0.0899999
1519612886.30 -0.7
1519612887.52 -0.48
1519612888.74 -0.26
1519612889.71 -0.29
1519612890.65 -0.35
1519612891.58 -0.42
1519612892.52 -0.48
1519612893.46 -0.54
1519612894.50 -0.5
1519612895.72 -0.28
1519612896.94 -0.0599999
1519612898.16 0.16
1519612899.37 -0.63
1519612900.59 -0.41
1519612901.59 -0.41
1519612902.53 -0.47
1519612903.47 -0.53
1519612904.41 -0.59
1519612905.35 0.35
1519612906.35 -0.65
1519612907.57 -0.43
1519612908.79 -0.21
1519612910.01 0.00999999
1519612911.22 -0.78
1519612912.44 -0.56
1519612913.48 -0.52
1519612914.42 -0.58
1519612915.36 -0.64
1519612916.30 0.3
1519612917.24 0.24
1519612918.20 0.2
1519612919.42 -0.58
1519612920.64 -0.36
1519612921.86 -0.14
1519612923.08 0.0799999
1519612924.29 -0.71
1519612925.37 0.37
1519612926.31 0.31
1519612927.25 0.25
1519612928.18 0.18
1519612929.12 0.12
1519612930.06 0.0599999
1519612931.27 -0.73
1519612932.49 -0.51
1519612933.71 -0.29
1519612934.93 -0.0699999
1519612936.15 0.15
1519612937.26 0.26
1519612938.20 0.2
1519612939.14 0.14
1519612940.08 0.0799999
1519612941.01 0.00999999
1519612941.95 -0.05
1519612943.12 0.12
1519612944.34 -0.66
1519612945.56 -0.44
1519612946.78 -0.22
1519612948.00 0
1519612949.15 0.15
1519612950.08 0.0799999
1519612951.02 0.02
1519612951.96 -0.04
1519612952.90 -0.0999999
1519612953.84 -0.16
1519612954.97 -0.03
1519612956.19 0.19
1519612957.41 -0.59
1519612958.63 -0.37
1519612959.85 -0.15
1519612961.03 0.03
1519612961.97 -0.03
1519612962.91 -0.0899999
1519612963.85 -0.15
1519612964.79 -0.21
1519612965.73 -0.27
1519612966.82 -0.18
1519612968.04 0.04
1519612969.26 0.26
1519612970.48 -0.52
1519612971.70 -0.3
1519612972.92 -0.0799999
1519612973.86 -0.14
1519612974.79 -0.21
1519612975.73 -0.27
1519612976.67 -0.33
1519612977.61 -0.39
1519612978.67 -0.33
1519612979.89 -0.11
1519612981.11 0.11
1519612982.33 -0.67
1519612983.54 -0.46
1519612984.76 -0.24
1519612985.74 -0.26
1519612986.68 -0.32
1519612987.61 -0.39
1519612988.55 -0.45
1519612989.49 -0.51
1519612990.52 -0.48
1519612991.73 -0.27
1519612992.95 -0.05
1519612994.17 0.17
1519612995.39 -0.61
1519612996.61 -0.39
1519612997.62 -0.38
1519612998.56 -0.44
1519612999.50 -0.5
1519613000.44 -0.56
1519613001.38 0.38
1519613002.36 -0.64
1519613003.58 -0.42
1519613004.80 -0.2
1519613006.02 0.02
1519613007.23 0.23
1519613008.45 -0.55
1519613009.50 -0.5
1519613010.44 -0.56
1519613011.38 0.38
1519613012.31 0.31
1519613013.25 0.25
1519613014.20 0.2
1519613015.42 -0.58
1519613016.64 -0.36
1519613017.86 -0.14
1519613019.07 0.0699999
1519613020.29 -0.71
1519613021.38 0.38
1519613022.32 0.32
1519613023.25 0.25
1519613024.19 0.19
1519613025.13 0.13
1519613026.07 0.0699999
1519613027.26 0.26
1519613028.48 -0.52
1519613029.70 -0.3
1519613030.92 -0.0799999
1519613032.13 0.13
1519613033.26 0.26
1519613034.19 0.19
1519613035.13 0.13
1519613036.07 0.0699999
1519613037.01 0.00999999
1519613037.95 -0.05
1519613040.32 -0.68
1519613041.54 -0.46
1519613042.76 -0.24
1519613043.98 -0.02
1519613045.13 0.13
1519613046.07 0.0699999
1519613047.01 0.00999999
1519613047.95 -0.05
1519613048.89 -0.11
1519613049.82 -0.18
1519613050.94 -0.0599999
1519613052.16 0.16
1519613053.38 -0.62
1519613054.60 -0.4
1519613055.81 -0.19
1519613057.01 0.00999999
1519613057.95 -0.05
1519613058.89 -0.11
1519613059.82 -0.18
1519613060.76 -0.24
1519613061.70 -0.3
1519613062.79 -0.21
1519613064.00 0
1519613065.22 0.22
1519613066.44 -0.56
1519613067.66 -0.34
1519613068.87 -0.13
1519613069.82 -0.18
1519613070.76 -0.24
1519613071.70 -0.3
1519613072.64 -0.36
1519613073.58 -0.42
1519613074.62 -0.38
1519613075.84 -0.16
1519613077.06 0.0599999
1519613078.28 0.28
1519613079.49 -0.51
1519613080.71 -0.29
1519613081.70 -0.3
1519613082.64 -0.36
1519613083.57 -0.43
1519613084.51 -0.49
1519613085.45 -0.55
1519613086.46 -0.54
1519613087.68 -0.32
1519613088.90 -0.0999999
1519613090.11 0.11
1519613091.33 -0.67
1519613092.55 -0.45
1519613093.57 -0.43
1519613094.51 -0.49
1519613095.45 -0.55
1519613096.39 0.39
1519613097.33 0.33
1519613098.30 -0.7
1519613099.52 -0.48
1519613100.74 -0.26
1519613101.95 -0.05
1519613103.17 0.17
1519613104.39 -0.61
1519613105.45 -0.55
1519613106.39 0.39
1519613107.32 0.32
1519613108.26 0.26
1519613109.20 0.2
1519613110.14 0.14
1519613111.35 -0.65
1519613112.57 -0.43
1519613113.79 -0.21
1519613115.01 0.00999999
1519613116.23 0.23
1519613117.32 0.32
1519613118.26 0.26
1519613119.20 0.2
1519613120.13 0.13
1519613121.07 0.0699999
1519613122.01 0.00999999
1519613123.19 0.19
1519613124.41 -0.59
1519613125.63 -0.37
1519613126.84 -0.16
1519613128.06 0.0599999
1519613129.19 0.19
1519613130.13 0.13
1519613131.07 0.0699999
1519613132.01 0.00999999
1519613132.95 -0.05
1519613133.88 -0.12
1519613135.03 0.03
1519613136.25 0.25
1519613137.46 -0.54
1519613138.68 -0.32
1519613139.90 -0.0999999
1519613141.07 0.0699999
1519613142.00 0
1519613142.94 -0.0599999
1519613143.88 -0.12
1519613144.82 -0.18
1519613145.75 -0.25
1519613146.86 -0.14
1519613148.08 0.0799999
1519613149.30 -0.7
1519613150.51 -0.49
1519613151.73 -0.27
1519613152.93 -0.0699999
1519613153.87 -0.13
1519613154.81 -0.19
1519613155.75 -0.25
1519613156.68 -0.32
1519613157.62 -0.38
1519613158.69 -0.31
1519613159.91 -0.0899999
1519613161.13 0.13
1519613162.34 -0.66
1519613163.56 -0.44
1519613164.78 -0.22
1519613165.74 -0.26
1519613166.68 -0.32
1519613167.62 -0.38
1519613168.55 -0.45
1519613169.49 -0.51
1519613170.53 -0.47
1519613171.75 -0.25
1519613172.96 -0.04
1519613174.18 0.18
1519613175.40 -0.6
1519613176.62 -0.38
1519613177.61 -0.39
1519613178.55 -0.45
1519613179.49 -0.51
1519613180.43 -0.57
1519613181.37 0.37
1519613182.37 -0.63
1519613183.59 -0.41
1519613184.80 -0.2
1519613186.02 0.02
1519613187.24 0.24
1519613188.46 -0.54
1519613189.49 -0.51
1519613190.43 -0.57
1519613191.37 0.37
1519613192.31 0.31
1519613193.24 0.24
1519613194.21 0.21
1519613195.43 -0.57
1519613196.64 -0.36
1519613197.86 -0.14
1519613199.08 0.0799999
1519613200.30 -0.7
1519613201.37 0.37
1519613202.30 0.3
1519613203.24 0.24
1519613204.18 0.18
1519613205.12 0.12
1519613206.06 0.0599999
1519613207.26 -0.74
1519613208.48 -0.52
1519613209.70 -0.3
1519613210.92 -0.0799999
1519613212.13 0.13
1519613213.24 0.24
1519613214.18 0.18
1519613215.12 0.12
1519613216.05 0.05
1519613216.99 -0.00999999
1519613217.93 -0.0699999
1519613219.10 0.0999999
1519613220.31 -0.69
1519613221.53 -0.47
1519613222.75 -0.25
1519613223.97 -0.03
1519613225.11 0.11
1519613226.05 0.05
1519613226.99 -0.00999999
1519613227.93 -0.0699999
1519613228.86 -0.14
1519613229.80 -0.2
1519613230.93 -0.0699999
1519613232.15 0.15
1519613233.37 -0.63
1519613234.59 -0.41
1519613235.81 -0.19
1519613236.99 -0.00999999
1519613237.93 -0.0699999
1519613238.86 -0.14
1519613239.80 -0.2
1519613240.74 -0.26
1519613241.68 -0.32
1519613242.77 -0.23
1519613243.99 -0.00999999
1519613245.21 0.21
1519613246.43 -0.57
1519613247.64 -0.36
1519613248.86 -0.14
1519613249.80 -0.2
1519613250.74 -0.26
1519613251.67 -0.33
1519613252.61 -0.39
1519613253.55 -0.45
1519613254.60 -0.4
1519613255.82 -0.18
1519613257.04 0.04
1519613258.25 -0.75
1519613259.47 -0.53
1519613260.69 -0.31
1519613261.66 -0.34
1519613262.60 -0.4
1519613263.54 -0.46
1519613264.47 -0.53
1519613265.41 -0.59
1519613266.43 -0.57
1519613267.65 -0.35
1519613268.87 -0.13
1519613270.09 0.0899999
1519613271.31 -0.69
1519613272.52 -0.48
1519613273.53 -0.47
1519613274.47 -0.53
1519613275.41 -0.59
1519613276.35 -0.65
1519613277.29 0.29
1519613278.27 -0.73
1519613279.49 -0.51
1519613280.71 -0.29
1519613281.93 -0.0699999
1519613283.15 0.15
1519613284.36 -0.64
1519613285.41 -0.59
1519613286.35 0.35
1519613287.29 0.29
1519613288.23 0.23
1519613289.16 0.16
1519613290.11 0.11
1519613291.33 -0.67
1519613292.55 -0.45
1519613293.77 -0.23
1519613294.98 -0.02
1519613296.20 0.2
1519613297.28 0.28
1519613298.22 0.22
1519613299.16 0.16
1519613301.04 0.04
1519613301.97 -0.03
1519613303.17 0.17
1519613304.39 -0.61
1519613305.60 -0.4
1519613306.82 -0.18
1519613308.04 0.04
1519613309.16 0.16
1519613310.10 0.0999999
1519613311.04 0.04
1519613311.98 -0.02
1519613312.91 -0.0899999
1519613313.85 -0.15
1519613315.01 0.00999999
1519613316.23 -0.77
1519613317.44 -0.56
1519613318.66 -0.34
1519613319.88 -0.12
1519613321.04 0.04
1519613321.98 -0.02
1519613322.91 -0.0899999
1519613323.85 -0.15
1519613324.79 -0.21
1519613325.73 -0.27
1519613326.85 -0.15
1519613328.07 0.0699999
1519613329.28 -0.72
1519613330.50 -0.5
1519613331.72 -0.28
1519613332.91 -0.0899999
1519613333.85 -0.15
1519613334.79 -0.21
1519613335.73 -0.27
1519613336.67 -0.33
1519613337.61 -0.39
1519613338.69 -0.31
1519613339.91 -0.0899999
1519613341.13 0.13
1519613342.34 -0.66
1519613343.56 -0.44
1519613344.78 -0.22
1519613345.73 -0.27
1519613346.67 -0.33
1519613347.61 -0.39
1519613348.54 -0.46
1519613349.48 -0.52
1519613350.53 -0.47
1519613351.75 -0.25
1519613352.97 -0.03
1519613354.18 0.18
1519613355.40 -0.6
1519613356.62 -0.38
1519613357.61 -0.39
1519613358.54 -0.46
1519613359.48 -0.52
1519613360.42 -0.58
1519613361.36 -0.64
1519613362.37 -0.63
1519613363.59 -0.41
1519613364.81 -0.19
1519613366.03 0.03
1519613367.24 -0.76
1519613368.46 -0.54
1519613369.49 -0.51
1519613370.42 -0.58
1519613371.36 -0.64
1519613372.30 0.3
1519613373.24 0.24
1519613374.22 0.22
1519613375.43 -0.57
1519613376.65 -0.35
1519613377.87 -0.13
1519613379.08 0.0799999
1519613380.30 -0.7
1519613381.36 -0.64
1519613382.30 0.3
1519613383.24 0.24
1519613384.18 0.18
1519613385.11 0.11
1519613386.05 0.05
1519613387.27 -0.73
1519613388.49 -0.51
1519613389.70 -0.3
1519613390.92 -0.0799999
1519613392.14 0.14
1519613393.23 0.23
1519613394.17 0.17
1519613395.11 0.11
1519613395.57 -0.43
1519613396.55 -0.45
1519613397.55 -0.45
1519613398.76 -0.24
1519613400.05 -0.95
1519613401.30 -0.7
1519613402.54 -0.46
1519613403.76 -0.24
1519613404.89 -0.11
1519613405.84 -0.16
1519613406.81 -0.19
1519613407.78 -0.22
1519613408.70 -0.3
1519613409.68 -0.32
1519613410.86 -0.14
1519613412.08 0.0799999
1519613413.34 -0.66
1519613414.57 -0.43
1519613415.80 -0.2
1519613416.98 -0.02
1519613417.94 -0.0599999
1519613418.92 -0.0799999
1519613419.83 -0.17
1519613420.75 -0.25
1519613421.68 -0.32
1519613422.82 -0.18
1519613424.04 0.04
1519613425.25 -0.75
1519613426.50 -0.5
1519613427.75 -0.25
1519613428.98 -0.02
1519613429.88 -0.12
1519613430.80 -0.2
1519613431.74 -0.26
1519613432.67 -0.33
1519613433.60 -0.4
1519613434.71 -0.29
1519613435.94 -0.0599999
1519613437.15 0.15
1519613438.35 -0.65
1519613439.55 -0.45
1519613440.75 -0.25
1519613441.71 -0.29
1519613442.65 -0.35
1519613443.60 -0.4
1519613444.54 -0.46
1519613445.48 -0.52
1519613446.51 -0.49
1519613447.75 -0.25
1519613448.98 -0.02
1519613450.21 0.21
Type: image/png
Desc:
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180421/07dd7103/attachment-0001.png>
