[Ovmsdev] Initial experience and Nissan Leaf updates (was: Turned off commenting on the OVMS v3 User Guide)
Robin O'Leary
ovmsdev at caederus.org
Fri Apr 20 06:32:28 HKT 2018
On Thu, Apr 19, 2018 at 03:03:20PM -0700, Stephen Casner wrote:
> Thanks for the debug outputs. For the buster case where the
> connection immediately closes, there must be something about the DH
> handshake that the server can't handle, but the client-side debug
> output doesn't indicate what that might be. You can enable some
> logging by the server on the USB/async console with the command:
> log level debug wolfssh
> This causes a lot of blathering that won't be useful, but there may be
> a useful hint near the end of it. Maybe that will tell us something
> for the squeeze case as well.
The log output was very brief:
E (43385740) ssh: Error in reception: -20
I tried a few more times, and got:
E (43507430) ssh: Error in reception: -20
E (43516610) ssh: Error in reception: -20
E (43647420) ssh: Error in reception: -20
> You can install your RSA public key as follows, ...
Will do, thanks.
Desc: Digital signature
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20180419/9ce1433a/attachment.sig>
