[Ovmsdev] V3 progress
Mon Oct 23 14:19:16 HKT 2017
> Is the poll functionality/framework in place, by the way?
Nope. And, I think that will have to be mine to do (as pretty fundamental) - unless someone else wants to step forward :-)
What do people think of the v2 polling mechanism? Shall I just straight port it (moving to the object model, of course), or are there things we need to change/improve to make it more usable?
> On 23 Oct 2017, at 2:05 PM, Geir Øyvind Vælidalo <geir at validalo.net> wrote:
> Great!
> I missed the NL-part🙂
> Geir
> Sendt fra min iPhone
> 23. okt. 2017 kl. 03:52 skrev Mark Webb-Johnson <mark at webb-johnson.net <mailto:mark at webb-johnson.net>>:
>> All good. I merged it, and changed NL->KS on line 41.
>>> On 23 Oct 2017, at 9:19 AM, Tom Parker <tom at carrott.org <mailto:tom at carrott.org>> wrote:
>>> Hi Geir,
>>> I see you've got Soule on line 41, and you've used the NL vehicle code on line 63 of vehicle_kiasoulev.cpp.
>>> Otherwise it looks good.
>>> I've been porting the Leaf v2 logic with as few changes as possible. The changes are mostly simple, replacement of can_databuffer with d and replacing the global state variables with metrics setters. I can still make sense of a diff between the v3 .cpp file and the v2 .c file. Once I have full feature parity between v2 and v3, I'll probably refactor the cpp code some.
>>> On 23/10/17 09:50, Geir Øyvind Vælidalo wrote:
>>>> Mark,
>>>> I just sent a Pull request for the initial Kia Soul EV-stub.
>>>> I’m still a newbie on GIT so forgive me if I make a mess! Most of the time spent so far is setting up esp-idf and trying to figure out GIT again 🙂
>>>> Geir
>>>> OvmsDev mailing list
>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171023/22dba444/attachment.htm>
