[Ovmsdev] V3 progress
Geir Øyvind Vælidalo
geir at validalo.net
Mon Oct 23 14:05:03 HKT 2017
Great!
I missed the NL-part🙂
Is the poll functionality/framework in place, by the way?
Geir
Sendt fra min iPhone
> 23. okt. 2017 kl. 03:52 skrev Mark Webb-Johnson <mark at webb-johnson.net>:
> All good. I merged it, and changed NL->KS on line 41.
>> On 23 Oct 2017, at 9:19 AM, Tom Parker <tom at carrott.org> wrote:
>> Hi Geir,
>> I see you've got Soule on line 41, and you've used the NL vehicle code on line 63 of vehicle_kiasoulev.cpp.
>> Otherwise it looks good.
>> I've been porting the Leaf v2 logic with as few changes as possible. The changes are mostly simple, replacement of can_databuffer with d and replacing the global state variables with metrics setters. I can still make sense of a diff between the v3 .cpp file and the v2 .c file. Once I have full feature parity between v2 and v3, I'll probably refactor the cpp code some.
>>> On 23/10/17 09:50, Geir Øyvind Vælidalo wrote:
>>> Mark,
>>> I just sent a Pull request for the initial Kia Soul EV-stub.
>>> I’m still a newbie on GIT so forgive me if I make a mess! Most of the time spent so far is setting up esp-idf and trying to figure out GIT again 🙂
>>> Geir
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20171023/c4ea9912/attachment.htm>
